2jzgte is going to happen!!!!!!!
Highly Boosted
hey what color is your car??? I was hearing storys last weekend from some tuner guys in appleton area about a 2jz swap happening in a quest lol... that musta been you...
i was down there all weekend in oshkosh helping my sister move...
Im sure they were talking about me. why dident you stop buy and see it in person hu!!! :twisted: JK heres some pics of it befor the swap
http://www.starquestclub.com/forums/viewtopic.php?t=50777
yeah i asked my buddy.. thats the car they were talking about..
I woulda loved to see that sweet thing but i didnt know anyone from here was in the oshkosh area... im down there alot visiting my sister and seeing friends.. we'll have to hook up sometime and go out when im down there
well here are the pics of the engine mounts.
I also had to modify the TB. I cut off a good chunk of it for a couple of reasons.
1. I dont need the traction control lol
2. weight reduction
3. and the real reason is that I will have more room to make the IC pipeing fit.
http://img299.imageshack.us/img299/3295/1000423ny3.th.jpg
http://img299.imageshack.us/img299/7759/1000422yg1.th.jpg
http://img299.imageshack.us/img299/733/1000421sn5.th.jpg
http://img299.imageshack.us/img299/6186/1000420ui5.th.jpg
I got the batter box mounted as of yeasterday too. ems was orderd so now craig87 can start the wirring :D
awesome man!!!
what you got planned for radiator fitment??
I am going to try to fit the stock rad in back of the intercooler. If I move my IC forward a 1inch or 2 the rad should fit good but i will need to change the fans to some smaller ones. the rad fitment is going to be a pain in the butt
I'd throw the stock radiator in the trash. I wouldn't trust it with a $6-7K build at all..
Get a two row Griffen, cut the stock radiator support and tilt the radiator. Or get a custom built one(shorter) and put it in front of the stock radiator support.
I have the griffen alum rad for the starquest but i was going to mod a stock rad first to make sure everything would work befor I cut into a $300 rad. I dont want to cut either core support so i can keep the OEM look. I had 160ECT temps with th 2.6l so cooling the 2jz should be fine on my griffen
I want to make it look like it came that way from the factory. It would be so much quicker to just cut the upper support but i just never liked doing that. Any one have any ideas on what fuel system I should use for 600WHP+
Just to let you know im useing the stock gas tank and the fuel rail gets feed form both sides with the return in the middle heres my choices
2 255lph walbro pumps
2 -8 feed lines
2 -8 fuel filters
-6 return
OR
Aeromotive A1000 pump 600lbs/hr 370lph est
all -10 single feed line
-10 filter
-10 to -8,-8 Y block
dual -8 lines out of the Y block to the rail
-6 return
That car is gonna scream :!:
But I wouldn't feel to good about that radiator (espicially with smaller fans), unless you don't plan on DD it.
If you want to keep it looking stock under the hood I would go with something from like (a radiator from) a 7MGTE, or something. But obviously thats up to you.
-GCN.
well the rad is mounted and the IC is almost done getting mounted. I had to cut the rad cap off to make room for the hood latch so i am getting a remote filler cap that gets mounted in the upper rad hose. I can even fit the 2 small stock fans in there. Heres some more pics for ya
http://img125.imageshack.us/img125/8858/1000424iz9.th.jpg
http://img125.imageshack.us/img125/5186/1000426xb4.th.jpg
http://img125.imageshack.us/img125/9494/1000427gs8.th.jpg
http://img125.imageshack.us/img125/8149/1000428kw9.th.jpg
http://img125.imageshack.us/img125/6117/1000429yv0.th.jpg
http://img125.imageshack.us/img125/8463/1000430tg0.th.jpg
http://img125.imageshack.us/img125/2913/1000431eo1.th.jpg
awww I'm sorry...........................................................................'
NOT
but I will find time next week to get her going hmmmmmmmmmmmmmmm
normal sept 9th?????????????????????
If I ask jessica she might let you go.
ha whats taking so long? lol jk. damn i miss that motor. Hope you get it done b4 the snow flys gotta let me know when u get it all done. I actually moved now. Live down kinda by milwaukee but in sussex. Got a better job and better girl haha. O well but ya keep me updated I don't usually come on here alot so talk to ya soon.
Jeff
well it seems to be going slow but some work is getting done on it.
whats done
mounted fuel pump and filter
mounted NOS bottle
ran all fuel and nos lines
mounted line lock and fuel pressure reg and have ALL fuel lines hooked up.
MSD dis 4 box is mounted all halteck wires are ran to where thay need to go but are not hooked up yet.
I was able to make my upper rad house out of my stock lower hose lol that was pretty cool. im just kinda slacking on makeing the tranny cross member but i'll get that done some time soon
well the throttle cabe is done. I shortened it quite a bit but I should have took 1 more inch out of it but its too late now. I used a bmx bike cable end to make the connection to the thottle body. I also made one of the heater core hoses out of my stock ones I just needed to buy a hose barb. I also got the all the nitrous,fuel and purge valves mounted and the micro switch mounted to the TB. Tomarrow I will grab some injector clips and map clip from the scrap yard along with a couple factory GM strut tower braces to use as my tranny crossmember. This wed and friday craig87 is coming over to finish up all the wireing.
