xwingz2 Posted September 13, 2014 Report Share Posted September 13, 2014 Hello, folks! When this engine is cool, maybe for the first 30 minutes, it has what I always thought was a turbo lag. After an hour or so, there is a miss between 3,000 and 4,500. It will "pull through" the miss...but it's almost like something thermal is influencing the ignition. Or, a fuel filter? New plugs, new wires and I see that someone replaced the injector clips. These leads are both white...could they be crossed??? Is this a coil going out? There is a new ignition module on eBay...is this the next step? Thx... Quote Link to comment Share on other sites More sharing options...
scott87star Posted September 13, 2014 Report Share Posted September 13, 2014 Injector clips aren't polarized, they can go either way. It's not the ignition module, they just flat out fail. I'd suggest cleaning and relubing the dizzy, the grease turns to glue and maybe its causing temperature related issues. Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted September 13, 2014 Author Report Share Posted September 13, 2014 Thanks, Scott. MUST this be an ESIr Distributor or can I replace it with any 2.6?? ed Quote Link to comment Share on other sites More sharing options...
StarquestRescue Posted September 13, 2014 Report Share Posted September 13, 2014 (edited) The intercooled and non intercooled cars had different advance curves. Edited September 13, 2014 by StarquestRescue Quote Link to comment Share on other sites More sharing options...
JAinsworth Posted September 13, 2014 Report Share Posted September 13, 2014 You cannot replace it with a non-turbo advance. A turbo car both advances and retards timing according to boost or not.Jimmy Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted September 13, 2014 Report Share Posted September 13, 2014 Check your distributor vacuum advance. Quote Link to comment Share on other sites More sharing options...
scott87star Posted September 13, 2014 Report Share Posted September 13, 2014 It isn't hard at all to take one apart, clean it up good and re-grease it. Just got to keep track of those pesky clips that hold the weights on. The springs can go back either way, they are different but it doesn't matter. Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted September 14, 2014 Author Report Share Posted September 14, 2014 Thanks, Jimmy...advance is working. I ordered a cap and rotor...if that does get it then I'll get a distributor...change the fuel filter...basics first..just so may of them. thx all Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted September 14, 2014 Author Report Share Posted September 14, 2014 Working around the distributor I see a rotor with three segments...it is only "hitting" on 1 and 1/2 ...the third one has no "shine" to it. The first one looks like it is hitting and the second one is pitted. The tabs in the distributor also look corroded. This is an easy first step... 2.) There is a 4" vacuum hose that Is not connected. It is attached to a manifold with three other vacuum hoses. I wish I could find the place here to attach pictures. Anyone have a suggestion where this 4 vac hose goes ??? (near the distributor but not long enough to reach the advance tab) 3.) I cannot attach pix...right?? Thx....ed Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted September 14, 2014 Author Report Share Posted September 14, 2014 Hey guys... There are two pix here. The first shows the rotor button...is this normal??? The second one has a yellow tie wrap on the 4" hose near the disty. Please...where does this attach? Thx... Quote Link to comment Share on other sites More sharing options...
T-Harps Posted September 15, 2014 Report Share Posted September 15, 2014 (edited) Just went out and checked my vac lines. That line is supposed to connect to the bottom of the black plastic thing threaded into the manifold (not sure what it does). I'm guessing yours is cracked off since you can't see it in the pic http://imagizer.imageshack.us/v2/320x240q90/909/9An2lP.png Edited September 15, 2014 by T-Harps Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted September 15, 2014 Report Share Posted September 15, 2014 Yeah two lines go to the thermo valve. It's an emissions thing. I have my charcoal canister line running to it. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted September 15, 2014 Report Share Posted September 15, 2014 (edited) http://www.starquest...pic=28042&st=40 read the last post.might help with the vac lines http://i139.photobucket.com/albums/q299/I-W/Quest_Parts_and_Info/Mani-Vac-Ports.gif Edited September 15, 2014 by importwarrior Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted September 15, 2014 Author Report Share Posted September 15, 2014 Thanks to all for the vacuum line question responses... Quote Link to comment Share on other sites More sharing options...
importwarrior Posted September 16, 2014 Report Share Posted September 16, 2014 (edited) What gap are you using for the plugs?Try .032 to .028 gap. Check the exhaust manifold for hair line cracks Check the vacuum advance with the suction test If it holds its fine. If it has a leak or slow leak or like sucking on a open straw it is BAD. Edited September 16, 2014 by importwarrior Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted September 29, 2014 Author Report Share Posted September 29, 2014 (edited) OK...I am back! My wife had surgery and I have just not had time to think about anything like "fun". The advance is working plugs gapped and re-gapped. I am not sure how to approach finding a hairline. Can this be valve adjustment? The engine seems t clear out at 4-5,000...it's jus getting there that is 'rough' like a miss. I changed the coil, wires, cap and rotor which DID help. Valve adjustment possible??? Edited October 2, 2014 by xwingz2 Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted October 3, 2014 Author Report Share Posted October 3, 2014 If I adjust the valves...do I disable the "jet valves"??? Quote Link to comment Share on other sites More sharing options...
FRO Posted October 3, 2014 Report Share Posted October 3, 2014 Have you checked your TPS sensor , there might be a bad spot in the sweep of the sensor. Quote Link to comment Share on other sites More sharing options...
FRO Posted October 3, 2014 Report Share Posted October 3, 2014 When you are describing the miss, is it like a flat spot in the throttle? is it just a certain spot? or is it all the way through the RPMs until you get to 3.5k- 4k? 1 Quote Link to comment Share on other sites More sharing options...
xwingz2 Posted October 9, 2014 Author Report Share Posted October 9, 2014 Thank you for responding. It just seems "flat" throughout the range. It's like one plug isn't firing...but that is not the case. I changed cap and rotor, wires and plugs and the thing wants to pull up to 5,000-5,550...but it seems like it is struggling. The plugs all have a nice "burn". Any chance this could be a "clogged" cat converter?? Is changing the throttle positioning sensor an "yes" or "no" thing...there is no "adjustment" or "test"...right? Do I sit behind the tailpipe and see if I get blown away??!!! Thanx...ed Quote Link to comment Share on other sites More sharing options...
FRO Posted October 10, 2014 Report Share Posted October 10, 2014 yes there is a test and adjustment.. Factory Service Manual section 13 dont have a link sorry Quote Link to comment Share on other sites More sharing options...
