michael hollen Posted February 27, 2011 Report Share Posted February 27, 2011 I don't where else to ask this question but here! I have a 5 speed trans that seems to make a type of whining noise while going up through the gears, but nothing going down in gears----I have changed the gear oil to full synthetic(proper weight asked for from manual) prior to noticing the noise, the car has about 250,000 miles on it and as far as I know the trans has never been gone through, just clutch changes! Link to comment Share on other sites More sharing options...
The Rabbit1 Posted February 27, 2011 Report Share Posted February 27, 2011 mitsu transmissions don't like synthetic oil.get some gl5 oil. Link to comment Share on other sites More sharing options...
slowquest Posted February 28, 2011 Report Share Posted February 28, 2011 mitsu transmissions don't like synthetic oil.get some gl5 oil. The manual transmissions actually take GL4, not GL5. This is posted in the auto trans forum, but you say a 5 speed?? Link to comment Share on other sites More sharing options...
michael hollen Posted March 1, 2011 Author Report Share Posted March 1, 2011 The manual transmissions actually take GL4, not GL5. This is posted in the auto trans forum, but you say a 5 speed?? Sorry, there is no manual trans forum as far as I can tell, did not know where else to ask question! Link to comment Share on other sites More sharing options...
The Rabbit1 Posted March 1, 2011 Report Share Posted March 1, 2011 GL5 is actually a grade above GL4, I always use that instead so it's just habit. But they both have the syncromesh additive. Link to comment Share on other sites More sharing options...
Skullzaflare Posted March 1, 2011 Report Share Posted March 1, 2011 GL5 is actually a grade above GL4, I always use that instead so it's just habit. But they both have the syncromesh additive.ill have to get it, i too have synthetic in mine, and its got a slight whine in gears, but has a rumble in neutral if clutch it out, like a pilot bearing noise, but its not the pilot. clicks in reverse too yes we needa a manual section lol Link to comment Share on other sites More sharing options...
Technology Posted March 1, 2011 Report Share Posted March 1, 2011 Sounds like bad bearings. It might last a long time if you don't pound on it, but it should be replaced or rebuilt. New bearings, and while it's apart, put new synchros in it. I think using synthetic is just fine, I have used that in all my trannies and they break from too much power or load changes while driving "aggressively" not normal use (which includes flooring it often). I'd say abnormal use is a hard launch or lower gear engine braking in a road-race type situation. But somethimes they just go bad. Link to comment Share on other sites More sharing options...
The Rabbit1 Posted March 2, 2011 Report Share Posted March 2, 2011 I'd say abnormal use is a hard launch or lower gear engine braking in a road-race type situation. But somethimes they just go bad.I know other mitsu and chrysler trans last a few weeks without the syncromesh additive, so if the FSM calls for it I would say it's a safe bet to use it. Go to the 3000gt forums and find the threads where someone put synthetic fluid in a manual and ate the syncros in a matter of days. Link to comment Share on other sites More sharing options...
michael hollen Posted March 2, 2011 Author Report Share Posted March 2, 2011 I know other mitsu and chrysler trans last a few weeks without the syncromesh additive, so if the FSM calls for it I would say it's a safe bet to use it. Go to the 3000gt forums and find the threads where someone put synthetic fluid in a manual and ate the syncros in a matter of days. Does it matter that the synthetic oil I used is GL5 and above rated? Link to comment Share on other sites More sharing options...
slowquest Posted March 2, 2011 Report Share Posted March 2, 2011 GL5 is not an "upgrade" to GL4, it's a totally different fluid. If it was just an upgrade, why would Mitsu have put GL5 in the diff, and GL4 in the trans? Wouldn't it have been alot easier and simpler to just have one type of fluid in the plant when building the cars? GL5 fluid will eat "yellow metal" which in our case, is the brass synchro's. Link to comment Share on other sites More sharing options...
The Rabbit1 Posted March 3, 2011 Report Share Posted March 3, 2011 GL5 is not an "upgrade" to GL4, it's a totally different fluid. If it was just an upgrade, why would Mitsu have put GL5 in the diff, and GL4 in the trans? Wouldn't it have been alot easier and simpler to just have one type of fluid in the plant when building the cars? GL5 fluid will eat "yellow metal" which in our case, is the brass synchro's.I stand corrected, according to API specifications for GL4 and GL5: they are the same oil, but GL5 has twice the extreme pressure additive, this high concentration is what eats "yellow metal". I misunderstood that part. Link to comment Share on other sites More sharing options...
Skullzaflare Posted March 3, 2011 Report Share Posted March 3, 2011 oh? then where do we buy gl4? Link to comment Share on other sites More sharing options...
slowquest Posted March 3, 2011 Report Share Posted March 3, 2011 Advance Auto Parts, but I don't recall the exact name on the bottle at the moment. Most dealers can also get it, but VERY expensive, usually around $25 a quart. Link to comment Share on other sites More sharing options...
The Rabbit1 Posted March 4, 2011 Report Share Posted March 4, 2011 There are synthetics that can be used instead of GL4.. But be careful what you put into your trans. When in doubt, go to the dealer. It may be a bit pricey, but a trans rebuild costs a helluva lot more. Or buy online: My shopping link Link to comment Share on other sites More sharing options...
michael hollen Posted March 7, 2011 Author Report Share Posted March 7, 2011 There are synthetics that can be used instead of GL4.. But be careful what you put into your trans. When in doubt, go to the dealer. It may be a bit pricey, but a trans rebuild costs a helluva lot more. Or buy online: My shopping link Thanks for all the help everyone! I changed the gear oil in trans and diff with the proper spec oil for each and seems to have gotten a little quieter, hopefully I didn't do any damage to the trans. Link to comment Share on other sites More sharing options...
Blue Posted March 8, 2011 Report Share Posted March 8, 2011 Makes me wonder what exactly is in my tranny... might as well drain and fill it while the car is down. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 12, 2011 Report Share Posted March 12, 2011 http://www.synthetic-oil-tech.com/Gear%20Lube%20White%20Paper.pdf Link to comment Share on other sites More sharing options...
Dad Posted March 12, 2011 Report Share Posted March 12, 2011 GL-4 VS Gl-5 debate continues... http://wiki.answers.com/Q/Whats_the_difference_between_gl4_and_gl5_gear_oils Link to comment Share on other sites More sharing options...
Technology Posted March 12, 2011 Report Share Posted March 12, 2011 In my personal experience, I have never had shifting problems develop over a period of time and use. I have had trans problems unrelated to shifting though, but I've been using Redline MT90 synthetic for years. Link to comment Share on other sites More sharing options...
