Megasquirt questions? How to set-up? Just ask! Diagram post!
106 replies to this topic
#41 Indiana
Indiana
    Addicted Starquester
  • 14,757 posts
Posted 18 November 2006 - 01:03 AM
QUOTE (cashsaudio)
If this wiring diagram I posted in the first post doesn't help then you shouldn't be putting this system together. This is the far most easiest setup I've done.
I'm sorry my post was in reply to the one about using a stock dist. for COP not about using an 80.00 tach adapter
#42 cashsaudio
cashsaudio
  • 1,238 posts
  • Interests:It wasn't me!!!
Posted 19 November 2006 - 04:58 PM
QUOTE (tux)
QUOTE (cashsaudio)
QUOTE (Indiana)
Go with MSII and use a magna dist that way you have your sensors for later that you need and you can just run a single coil for now, I bet it won't be long you'll have to run that setup
http://www.b2600turbo.com/k110506.mpg
works just fine
You can not get the magna dist. that easy. Some people do not like to wait. If this wiring diagram I posted in the first post doesn't help then you shouldn't be putting this system together. This is the far most easiest setup I've done.
was easily acquired from www.ebay.com.au
yea but they don't really do international i'm quite surprise that they sent it out for ya
2006 Dodge Viper SRT-10 Coupe
#43 kfitts
kfitts
  • 152 posts
Posted 05 January 2007 - 06:18 PM
I have the full FIP setup and my car runs great!
Here are a few maps if you want to try them.
Remember every car is not alike :!:
This was my current map for the stock cam setup.
You may need to add or take away 5% fuel from the VE table
80 pka and under, at all RPM range.
88 Quest, FIP MPI, ED-IS-ON, T62, O Ring Wisco Block, Tial WG/BOV, Tim Cam, KDM 3" SX Fuel System
#44 importwarrior
  • 18,360 posts
Posted 11 February 2007 - 07:19 AM
MSD-8509- click me
MSD-8509
part number 121-8509
76.99
Edited by importwarrior, 26 May 2010 - 05:26 PM.
#45 importwarrior
  • 18,360 posts
Posted 01 March 2007 - 12:15 PM
would this work on our cars? MSNS -E MS-1 PCB v 3.0
http://megasquirt.sourceforge.net/extra/pi...ank-trigger.gif
http://megasquirt.sourceforge.net/extra/setup-msns.html
#46 cashsaudio
cashsaudio
  • 1,238 posts
Posted 01 March 2007 - 04:37 PM
QUOTE (importwarrior)
as for triggering, no. Its been tried. I never really looked too much into it and you will have to some mods inside the MS. As for the single coil, you could make it work but I did it once and it worked like crap so thats y I went msd 6a route. I know this would be a cheaper route but do you really wanna deal with the hard stuff? This is the whole reason I set this up its probably the most simple way to go.
#47 importwarrior
  • 18,360 posts
Posted 08 April 2007 - 07:53 PM
i just noticed that this diagram states MS@ not MS1. will this still work withthe MS-1 V3.0?
#48 bigmandsm
bigmandsm
  • Banned
  • 280 posts
Posted 22 April 2007 - 01:58 PM
The problem is no one ever says exactly how to hook up anything the right way it is always left open what wires go where? what wheres do you leave?where do the ones you leave go, how do they go I mean this has a sticky for what it is a very poor informative trend
Learning something new everyday
#49 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 22 April 2007 - 03:44 PM
I setup my ignition system exactly as documented by cashaudio and my car runs perfectly. I have megasquirt 2 v3.0 using a VR sensor output. Setting up the fuel system is very straightforward and the documentation that is available in the megamanual online gives a great explanation of how to do things right and what to do if there are problems. When you criticize member's threads, you make them not want to post information that might be usefull to another member. I have found a wealth of information on this site.
#50 importwarrior
  • 18,360 posts
Posted 22 April 2007 - 06:02 PM
i am doing the exact same thing. only MS-1 V3.
#51 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 22 April 2007 - 06:33 PM
The hardware and code is different between the two versions. You should ask a similar question on the msefi.com forums.
#52 quest96
quest96
  • 94 posts
  • Interests:cars & motorcycles
Posted 30 May 2007 - 10:46 PM
Hey guys whats up I'm having some issues with stalling but thats another story. I am running the stock ignition with a mallory box and a tach adapter to the ms 1 v3.0. and was wondering whats the best was to upgrade to control spark? I'm using msns with the 12+12 tables. Can I still use this setup or do I need to upgrade to ms 2 I'd rather not if I dont have to. Thanks...
#53 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 30 May 2007 - 11:12 PM
Pm Button on the boards. He's running megasquirt and spark with a 7 pin module from a GM dizzy controlling the ignition. There's a write up of his whole setup. I tried it initially, but I was having issues frying the GM HEI 7 pin modules so I upgraded to the MS2.
#54 quest96
quest96
  • 94 posts
Posted 02 June 2007 - 10:36 PM
hey guys I just picked up my msd adapter 8509 like cash used to create the same output as the msd 6al with the stock pickup in the dizzy. I wired it in and I have my rpm input to my ms1 v3.0 using my hall opt input on the megasquirt. my question is how do I wire the output ckt inside the ms to the white wire pin #36? do I wire the vb921 with the 330 ohm from r26 to igbtin, igbtout to ign and jump r43? also what settings in the spark sections do I use for this settup in msns? do I use led17 to sparka and led18 to irq trigger? not quite sure what else to set. I locked the dizzy like the diagram from fip I guess. the ms is getting a good signal from the 8509 just not sure about the output part of the settup any help would be greatly appeaciated... Thanks...
#55 importwarrior
  • 18,360 posts
Posted 03 June 2007 - 06:45 AM
we are in the same boat. when i talked to CashAudio, he said to make sure the MS had VR-in and VR-out. that was it. then wire it up like he showed in the diagram in the first post.
#56 button
button
  • 2,028 posts
  • Interests:1978 Plymouth Arrow
    1974 Dodge Colt
    1990 F45 Tow Rig
    2011 Honda CR-Z
Posted 03 June 2007 - 12:04 PM
if you have a ms board version 3.0, a 6al is a waste of money.. plain and simple.. The onboard VB921 will push more than enough power.
but the 6al does look a lot cooler...  :roll:
-Jay
#57 quest96
quest96
  • 94 posts
Posted 03 June 2007 - 09:08 PM
I installed the msd 8509 and it works pretty well with the hall opt input on the ms. I have rpm signal on the ms and I wired up the vb 921 output and set led 17 to spark output and fixed dwell with 50% and I got it to start but I need to adjust the dizzy and get the trigger angle right. I also am having some trouble with the ms reseting somtimes but that shouldn't be a big deal. But at least it's running. If you need any info on how to set it up with ms1 v3.0 and the 8509 let me know. I'll keep you posted on how it's running.
#58 importwarrior
  • 18,360 posts
Posted 04 June 2007 - 04:57 AM
thanks,
Button you used the 7 pin GM ?
#59 button
button
  • 2,028 posts
    1974 Dodge Colt
    1990 F45 Tow Rig
    2011 Honda CR-Z
Posted 04 June 2007 - 09:00 AM
thanks,
indeed, its cheaper than an 8509  :wink:
-Jay
#60 bigmandsm
bigmandsm
  • Banned
  • 280 posts
Posted 07 June 2007 - 09:09 PM
Maybe someone can help me out a litlle I fell like a dumb a** but here I go I am installing a ms1 2.2 fuel only my question is this what exacltly do you recomend I do with the ingition setup I have a 6al but I have come across so many diffrent ways to do but do not know which one I should do because eveyone else is using a ms2 or ms1 v3.0 what rout should I do everything is done but the ingnition setup.
