Techboy's 88 Starion SHP Save ....
758 replies to this topic
#701 techboy
techboy
  • 3,838 posts
Posted 07 October 2020 - 08:27 AM
 tsi_tom, on 06 October 2020 - 07:08 PM, said:
I have mine in.  Don't change stock stuff until it is right.  When my MAF was disconnected it fell on its face upon throttle.
I wonder if your fuel pressure is off.
I don't know how it could be.  The gauge I have installed says its perfect at idle.  Like 38 or something like that.  It's a stock regulator w/ stock injectors, so I'm not sure how it could be off.
I can tell you I'm very much running out of patience with this car.
Edited by techboy, 22 October 2020 - 07:21 AM.
#702 Preludedude
Preludedude
  • 3,713 posts
Posted 07 October 2020 - 02:36 PM
4 :ph34r:
#703 Preludedude
Preludedude
  • 3,713 posts
Posted 07 October 2020 - 02:37 PM
G :blink:
#704 Preludedude
Preludedude
  • 3,713 posts
6 :unsure:
#705 Preludedude
Preludedude
  • 3,713 posts
3 :D
#706 techboy
techboy
  • 3,838 posts
Posted 07 October 2020 - 06:26 PM
You're reading my mind. My wife is so sick of hearing me talk about swapping that car with a 4G63. Its a BEAUTIFUL car, it really is, but my power plant has been suspect from the beginning and its no fun to stare at it in the garage. I'm really over the G54B. I might just leave it in there for now and start building a 4G63. I got enough parts in the garage and attic I could probably piece one together in a week.
#707 kev
kev
    Moderator
  • 5,279 posts
Posted 08 October 2020 - 11:37 AM
It's probably the MAS.  It has to be something simple.
#708 techboy
techboy
  • 3,838 posts
Posted 08 October 2020 - 01:26 PM
I'm really hoping your right kev.  And I'm really thinking it is the MAS too.  I can't test it right now, I dropped my OVCP off at JMFab the day after I last drove the car to have a 1G BOV flange welded on.  The flange that came on the pipe was a Greddy style flange, so I couldn't run my BOV.  So, I'm having that corrected.  When I first called the shop the plan was to drop the whole car off, but since it's not really drivable yet I just took the pipe off and took it down.  Once I get it back from them I'll put the pipe on, swap the MAS and try again.
I'm pretty confident I fixed the oil leak, b/c even on the short drive I took the other day it didn't leak or spot anything (I put a fresh sheet of cardboard underneath so I could see)  It idles better than it ever has since I've owned it. Now, if we could just get it moving.
#709 Turbo Cary
Turbo Cary
  • 1,909 posts
Posted 08 October 2020 - 06:25 PM
When you changed the rear camshaft plug did you put a bunch of gray RTV on it? I did that to mine and it never leaked for years.
Have you considered going to a megasquirt ECU and just run off of a MAP sensor rather than an old DSM maf?
#710 techboy
techboy
  • 3,838 posts
Posted 08 October 2020 - 09:15 PM
After doing some research on here and reading that some other guys have done that I did.  Everything I read said very THIN coat.  So that's what I did.  Seems good so far.  Like I said, I also replaced the valve cover gasket which I had intentionally NOT replaced b/c I was waiting to heat cycle the engine and check the torque on the ARP head bolts.
I haven't, but it might be something to look into.  My tentative plan moving forward was to install the SAFC-II out of my Eclipse (which is ancient technology at this point too) after upgrading that car to the DSM Link.  However, due to COVID, there's been lots of delays at ECM Turning, and I just found out last week my extra EPROM ECU I bought for this is now missing.  Even if I switch the car to a SAFC though, it would still be running off the MAF - although I would have some control over the tune.
Thanks of the input.  I'll have to look into that.  I know several people run that setup, and I've seen them for sale on here every now and then.
#711 kev
kev
    Moderator
  • 5,279 posts
Posted 02 November 2020 - 01:32 PM
any luck?
#712 techboy
techboy
  • 3,838 posts
Posted 03 November 2020 - 09:58 AM
 kev, on 02 November 2020 - 01:32 PM, said:
any luck?
Thanks for asking kev.  Here's where I'm at ... I had a OVCP pipe made and flanged for a 1G BOV at JMFab and I got that back.  I got that installed and that seemed to solve the drivability issue.  There must have been a boost or vacuum leak with the makeshift pipe I was trying to use while I was waiting.   The oil leak from the cam seal seems to fixed as well.
I was even able to drive the car for the first time this year and take it to a C&C last Saturday.
While that stuff is all good, the car is still not running right, it's running super-rich just like it was before I tore it all apart.  When I have a chance, I'm going to make a separate post about to get some input from other board members b/c I am at a loss at this point.
EDIT: I forgot to mention, I did swap the MAS back to the one I was using, and then swapped it again to my spare.  No difference with either MAS on how the car drives.
Edited by techboy, 03 November 2020 - 10:03 AM.
#713 BuGG
BuGG
  • 2,006 posts
Posted 03 November 2020 - 10:52 AM
Try Recirculating the BOV.  Your venting metered air.
#714 techboy
techboy
  • 3,838 posts
Posted 03 November 2020 - 12:57 PM
That is definitely on my to-do list.  I'm just still trying to sort out how I'm going to make that happen.  My intake pipe is a soft silicone MK1 pipe, so I think I'm going to have to make a custom pipe so that I have a way to plumb a recirculation tube back into the intake.  I was planning to JMFab take care of that at the same time as OVCP, but his fab person is leaving and only working part-time right now, so it wasn't in the cards scheduling wise.
However, what doesn't make sense to me is that I am getting an AFR of 11 or less at a traffic light at idle when nothing venting. BOV is closed, so all metered air is accounted for, it should not be rich at idle.  Something else other than the BOV venting to the atmosphere is wrong ... and has been wrong with this car for a long time.
#715 Turbo Cary
Turbo Cary
  • 1,909 posts
Posted 03 November 2020 - 05:26 PM
It could be the ECU temp sensor has failed causing the engine to think it's cold at all times.
#716 techboy
techboy
  • 3,838 posts
Posted 03 November 2020 - 10:26 PM
Funny you mention that Cary.  Tsi_Tom and I were just talking about this possibility the other week. We found the pins on the ECU for the CTS are 6 and 4.  Do you know if there is a way to test the signal at the ECU?  I've replaced caps and things like that on boards before, not sure if I can find a problem if it can be repaired.  If not, would the idea be to try another ECU and see how the car behaves?  When I get a chance, I want to disconnect the CTS completely and take the car for a drive and see if it drives any different with the CTS unplugged.
My opinion, and my gut is telling me that the car is stuck in closed loop.
Edited by techboy, 03 November 2020 - 10:28 PM.
#717 kev
kev
    Moderator
  • 5,279 posts
Posted 04 November 2020 - 07:29 AM
Here is some good info from mike c:  http://www.starquest...or#entry1577626
He states to use a 270 ohm resistor but I've always used a simple 300 ohm.   Get it up to temperature, unplug the CTS and add the resister to the two leads on the harness.   Then see how your afr fares.
#718 Turbo Cary
Turbo Cary
  • 1,909 posts
Posted 04 November 2020 - 08:54 AM
I never tried using a resistor to test the temp sensor but that is a good idea. You could always get a potentiometer and vary the resistance to see how the ECU reacts to the change. It sucks these cars dont give a data reading or that the coolant gauge isnt tied directly to the temp sensor for the ECU.
When mine failed it suddenly went stupid rich at idle. Had been running fine for a while and all of a sudden at a light my AFR went to 9-10 and I barely made it home. I checked for injector leakage etc but no issue there. I bought a new ECT and installed it. That corrected the issue.
For the cost of a new ECT sensor it may not be bad to just replace it. The test kev mentioned would be easiest if you can get to an electronics store to buy a resistor.
Edited by Turbo Cary, 04 November 2020 - 08:57 AM.
#719 tsi_tom
tsi_tom
  • 2,517 posts
Posted 04 November 2020 - 09:28 AM
What I want to test is that the applied resistance matches what is  at the ECU harness connection.
Engine
20 over forged pistons
Stock injection system
#720 techboy
techboy
  • 3,838 posts
Posted 04 November 2020 - 11:23 AM
I'll definitely try the resistor trick.  I probably have a 270 or 300 ohm laying around at home already. What I want to know though, is what Tom is talking about.  Am I getting a signal at the ECU from the CTS?  I've replaced the CTS 3 times, and I've checked them in a pot of hot water and on the car cold and after being up to operating temp, and they ohm out just fine.  I think the problem is with the receiving of the signal.
Edited by techboy, 04 November 2020 - 11:41 AM.
