The Official SQC Wheel Thread
401 replies to this topic
#1 Sully
Sully
    is SQ and Headache free!!
  • 4,739 posts
  • Interests:88 KBS MKIV F500
    03 Chevy S-10
    92 Mazda Miata
Posted 24 May 2008 - 09:55 PM
Ok... since there's so many questions on what fits, I think a thread would be good. This way members can find this info without searching through a bunch of threads. Chances are, if theres a wheel your thinking about getting, someone on here has one the same size.
Please post:
1. a pic of your Car
2. Front wheel dimensions
3. Front spacer dimension if used
4. Front tire dimension
5. If coilovers w/ cut spring perches are necessary on the front
6. Rear wheel dimensions
7. Rear spacer dimension if used
8. Rear tire dimension
9. If coilovers w/ cut spring perches are necessary on the rear
lastly.... please do not muck the thread up. Personally I'd like for you all to post the above only. No questions unless you feel it is pertinant to the thread.
No "what kind of tires" or "where did you get those" "damn..... those are tight dawg!" or those would look better in black"
I know there are still going to be people in the BS section asking if certain rims will fit. Rather than going through it all, we can just post this link.
Thanks
EDIT:  Ok I can add mine now that I have it sorted out.  I don't have any pics of the car sitting still but these still show a bit.
Front
2. 17x9 +25
3. 15mm spacer
4. 275/40/17 Kumho VictoRacer
5. Cosmo Coilovers w/ cut perches.  There is very little room betweel the tire and the strut.  I can't even fit my pinky finger between them so make sure your wheels bearings are tight.  Front fenders could use a roll IF you plan on putting high stresses on it.  During normal autocrosses I haven't had any problems but, in the pic above, the landing scraped the tire up.  Also, If your running street tires you don't want to go with 275mm wide up front.  They have a thicker sidewalls and WILL cause clearance issues.
Rear
6. 17x9 +25
7. 1" I believe.  They're Dereks old spacers.
8. 275/40/17 Kumho VictoRacer
9. Cosmo Coilovers w/ cut perches.  Not sure if its necessary.  No roll needed.
295's will fit if your using race tires.  315's won't fit in the fenders.  I haven't tried 305's yet.  These tires are over kill so don't expect improvements in turns.  They're good if your going in a straightline though.
Edited by Sully, 23 August 2008 - 12:10 PM.
QUOTE (dstar88 @ May 4 2009, 11:55 AM)
I woke up naked with a dead deer next to me and blood everywhere..so i think i had fun..
A wise man once said:
"if you cant afford to do it right the first time, you damn sure cant afford to do it TWICE"
#2 88TSI_Rob
88TSI_Rob
    Super Potential
  • 3,002 posts
Posted 25 May 2008 - 12:42 AM
17" Work Equip wheels
Front:
17x7 +10 w/ 225/45 tires (soon to be 225/35)
Rear:
17x8 +20 w/ 245/35 tires and a 1" (25.6mm) spacer adapter which gives me a -5.6 offset
Suspension:
Ground Control coilovers. 7" long / 375 lb/in. springs in the front, 8" long / 275lb/in. in the rear. Lower perches were not trimmed.
#3 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 25 May 2008 - 04:41 AM
This thread is soooo long over due..
Wheels/Tires:
19x8.5(+15mm), 235/35/19's...
19x10.5(-3mm), 275/30/19's... 1" spacer in rear. Spacer is hub and rim bore centric. Stock SQ hub diameter is 67.1mm.
Suspension:
Anti-M-Power coilovers, 7" unsprung lengths front and back. 450lb/in front and 350lb/in rear spring rates. KYB struts. Cusco camber plates(front), Anti-M-Power camber plates(rear). S&M tri bar STB's.
Various:
All spring perches cut. Rear fender lips were rolled.  The perches didn't absolutely need to be cut, but I did so for more adjustment from coilovers. Fender lips have to be cut/rolled/shaved with the rear width and offset.  I cut the rear strut towers(notched) for more camber adjustment, so that brings the tops of the rims/tires closer to the fenders.
#4 hdam
hdam
  • 215 posts
  • Interests:Flying low....
Posted 25 May 2008 - 02:24 PM
New whells arrived yesterday....
8,5 x 19 (ET+18) tyres 235/35 x 19
10 x 19 (ET -2) tyres 275/30 x 19
Car currently under rerstoration, but wheels will be mounted in 3 weeks....pictures of that to come..
Edited by hdam, 02 April 2009 - 02:38 PM.
#5 D_Venable
D_Venable
  • 6,588 posts
Posted 26 May 2008 - 12:42 AM
These are racingSparco NS06
Wheels/Tires
Front:
18x8.5
22mm offset
NO spacer
235/40/18
Rear:
18x9.5
22mm offset (combine offset with spacer, approx. -3mm
25mm (possibly a 1", not sure) bolt on spacer
265/35/18
Suspension
Anti-M coilovers (set to stock ride height, for camber issues)
lower stock spring perches are UNcut (front tire clearance is tight, CAN'T fit index finger between tire and perch)
I plan to lower it within a couple weeks after fitting the RCAs from the GP on the front
Edited by D_Venable, 26 May 2008 - 12:46 AM.
2011 Silverado
88 TSI parts car
#6 Mingo1
Mingo1
  • 1,086 posts
Posted 27 May 2008 - 09:41 AM
        The wheels are Motorsport Rsi wheels.  Front are 17x8 and rears are 18x10.  Sits on Eibach Springs and adjustable struts.   Name brand of tire is Federal and I am gonna have to get back on yall with tire size.  Offset us unknown do have spacer in all for corners.  I think they are 1" or 2" spacers.
6g72 swap in progress
#7 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 28 July 2008 - 06:26 PM
Front wheels - 18 x 10.5 +3 offset 255/35/18s
Rear wheels - 18 x 11.5 -16 offset 265/35/18s
This is JAS from AuStarion.
#8 SFBMX88
SFBMX88
  • 1,556 posts
Posted 28 July 2008 - 09:07 PM
Is it okay If I have stock wheels?
SHP 8"+9" wheels on the flatty....
Front 16"x8"   225/50r16   +18
Rear 16"x9"     245/45r16   0
Full widebody suspension with sleeve over kit, 8kg front, 6kg rear
rear with stock springs:
now lowered on sleeve overs:
More info at:  http://www.starquestclub.com/forum/index.php?showtopic=76965
Edited by SFBMX88, 30 March 2009 - 09:34 PM.
#9 dem0ntsi
dem0ntsi
  • 883 posts
Posted 28 July 2008 - 11:56 PM
Gravity Gullflames in Gold
18x8.5 +25 fronts with 225/35/18s
18x9.5 +15 rears with 255/35/18s
last 2 pictures is with 20mm spacers front/ 25mm spacers rear
#10 ky_black_tsi
ky_black_tsi
  • 90 posts
Posted 23 August 2008 - 02:35 AM
QUOTE (JustPaus_88TSi @ May 25 2008, 05:41 AM) <{POST_SNAPBACK}>
Wheels/Tires:
Suspension:
Various:
what kind of wheels are these ?
1987 black/black conquest with a RB25det (sitting in it at the moment soon to be bolted in lol )
#11 Funky Phil
Funky Phil
    Super Pooper
  • 6,423 posts
Posted 23 August 2008 - 03:45 AM
QUOTE (SFBMX88 @ Jul 28 2008, 09:07 PM) <{POST_SNAPBACK}>
Front 16"x8"   225/50r16   -18
SHP WB rims on NB,s look so at home and badass! You definatly need some lower profiles and to get a bit closer to the pave.
phil
#12 Sully
Sully
  • 4,739 posts
    03 Chevy S-10
    92 Mazda Miata
Posted 23 August 2008 - 10:14 AM
QUOTE (phinko @ Aug 23 2008, 04:45 AM) <{POST_SNAPBACK}>
phil
or 16x8's.   the same size tires all the way around make the car soooooooooooo  much more balanced in the turns.  you'll be surprised how much 20-30 extra mm's of rubber in the rear increases understeeer. atleast a half a second in a 45 second Autox course.
Edited by Sully, 23 August 2008 - 10:18 AM.
#13 AndyW
AndyW
    Badda Bing
  • 3,392 posts
  • Interests:Stuff, things & other items of different sorts
Posted 23 August 2008 - 10:28 AM
QUOTE (Sully @ Aug 23 2008, 11:14 AM) <{POST_SNAPBACK}>
Iv been contemplating doing this for next year, I have a full set of four 245/45 Victoracers and was thinking of using my SHP 8s up front and normal 8"s in the rear instead of dumping a stupid amount of cash for 2 more 265's.  i think you just swayed my decision
AndyW
#14 D_Venable
D_Venable
  • 6,588 posts
Posted 23 August 2008 - 11:10 AM
since this thread has popped back to the top. I'm gonna update mine a bit.
Same Sparco NS06 wheels.
18x9.5 rear wheel 22mm offset
     now with a 33mm spacer for a combined -11mm offset
     265/35-18 Kumho Escta Supra (I HATE THIS TIRE, IT'S HARD AS HELL)
18x8.5 front wheel 22mm offset
     no spacers (but I want to run a 10-15mm spacer)
     235/40-18 Toyo T1S (great traction, but it's too narrow, and too tall. I want a 245/35-18)
Derek
2011 Silverado
88 TSI parts car
#15 Sully
Sully
  • 4,739 posts
    03 Chevy S-10
    92 Mazda Miata
Posted 23 August 2008 - 11:42 AM
Don't go 15mm  I have 15mm on mine with 17x9 +25's.  In that pic of my jump it put alot of load on the RF and I rubbed the fender wearing the tire down to the cord on the outside edge.  Granted it was under special circumstances but still.. yours will be out a few more MM than mine.  the problem with 10mm.... is their not bolt on.  15mm was the smallest available in a bolt on.   Unless you get them machined down a bit but they're already pretty thin.
EDIT: my local Murray's  (a CSK parts store)  have plate style spacers in stock for 10ea.  that should be good enough if you want to go that route.  even with the largest one there is still plenty of thread left
Edited by Sully, 23 August 2008 - 11:47 AM.
#16 D_Venable
D_Venable
  • 6,588 posts
Posted 23 August 2008 - 11:52 AM
are your fenders rolled yet? And what size tire, the 255? Because I already need to roll the rear fenders (blown strut is causing the tire to rub on the driver's side) might as well do it on the front too.
when I get back home, I've got access to a metal lathe (next door at my grandpa's) so if I need to, I can machine a 15mm down a bit.
2011 Silverado
88 TSI parts car
#17 Sully
Sully
  • 4,739 posts
    03 Chevy S-10
    92 Mazda Miata
Posted 23 August 2008 - 12:25 PM
no.. they're not rolled but they could use it if I do more Supermoto type events.   Otherwise, it'll stay like it is.  I run 275's all around but construction wise.... they're about the same as 255 street tires, sidewal to side wall.
These are the spacers that I got and they SUCK!  I went with these because they're $30 cheaper than the std. lug type spacer.  The second time I torqued them down the bit thing started to bend and mess up the lugs.  Std lugs fit in the holes but there isn't enough room to fit a socket in to tighten them down.  Also make sure you have enough room for the stock lugs to fit in the back of the wheel.  They explain it in the auction.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=320281919259
#18 Tman
Tman
    SQC Bum
  • 3,518 posts
  • Interests:starquests ,fishing , computers
Posted 23 August 2008 - 03:43 PM
my turn
17x8 all the way around
front 0 offest no spacer
rear 0 offset like 3/4 spacer no 100 % sure
tires michelin pilots
front 225/45/17
rear 245/40/17
struts  kybs  i believe
springs cosmos
Edited by Tman, 23 August 2008 - 03:48 PM.
http://www.26liter.u...r_and_sig_3.JPG
I have come here to chew bubble gum and kick some tail and im Allllll outta bubble gum
You know what Ole jack burton says at a time like this
Dad's Starquest Parts: http://www.enginemac...m/conquest.html
(cokedr) Seriously...Teddy makes me wanna punch a baby.
#19 spltscnd95sol
spltscnd95sol
  • 39 posts
Posted 17 October 2008 - 04:52 PM
Will a 17x11 fit in the rear? if so, what tire would you recommend?
The size are 17x9.5+6 and 17x11+18
#20 dem0ntsi
dem0ntsi
  • 883 posts
Posted 22 October 2008 - 11:58 PM
Hot Wheels 68s
17x9 +24 fronts with 225/35/17 Yokohama S Drives with 25mm spacer
17x9 +0 rears with 245/40/17 Yokohama S Drives with 20mm spacer
Edited by dem0ntsi, 30 October 2008 - 08:14 PM.
