Convette Posted May 23, 2010 Report Share Posted May 23, 2010 http://i177.photobucket.com/albums/w239/johnboy9788/1273668915.jpg Link to comment Share on other sites More sharing options...
HotrodTSi Posted May 30, 2010 Report Share Posted May 30, 2010 WedSports Cerebus Link to comment Share on other sites More sharing options...
chiplee Posted June 27, 2010 Report Share Posted June 27, 2010 Ok this thread rocks but it's making my head hurt. Can someone who is smart on this stuff please tell me what size adapter I need to run to make these wheels work. FRONT 18X8REAR 18X9OFFSET 20MM Link to comment Share on other sites More sharing options...
Dave-O Posted June 27, 2010 Report Share Posted June 27, 2010 Fronts would be good without a spacer I believe, and rears would probably be good with a 20/25mm spacer. My 17x9 +24 fits just barely up front, the strut perch will be your first obstacle though. Link to comment Share on other sites More sharing options...
chiplee Posted June 27, 2010 Report Share Posted June 27, 2010 Fronts would be good without a spacer I believe, and rears would probably be good with a 20/25mm spacer. My 17x9 +24 fits just barely up front, the strut perch will be your first obstacle though. Problem is they're 5x120, so I think I have to use an adapter to go from 5x114.3 to 5x120. You think a half inch would work with a 245/40? Or would it hit the fender? Link to comment Share on other sites More sharing options...
D_Venable Posted June 27, 2010 Report Share Posted June 27, 2010 Problem is they're 5x120, so I think I have to use an adapter to go from 5x114.3 to 5x120. You think a half inch would work with a 245/40? Or would it hit the fender? most adaptors like what your gonna need start at 20-25mm, which means your gonna be flush with the outside of the fender, if not a slight poke (depending on camber) up front If you can find a 15mm adaptor for the front, you'd be good, then I'd go 30mm out back. Only issue you might have is the stock stud clearance to the wheel (yes through the spacer). a 15mm spacer on the stock wheels require about 10mm to be cut off the stock studs, so you might be able to use the stock wheels' clearance on the back between the stud holes to compare to the new wheels' to gauge how much clearance to the stock studs you will have Here's a 15mm spacer with stock length studs... http://26liter.us/gallery/albums/userpics/10030/DSCF6219.jpg and trimmed 10mm (7mm minimum needed to fit stock wheels) http://26liter.us/gallery/albums/userpics/10030/P7100091.jpg hope that helps some Link to comment Share on other sites More sharing options...
chiplee Posted June 27, 2010 Report Share Posted June 27, 2010 (edited) hope that helps some Sure does, and I found them in the right bolt pattern and a 40 offset now so I might not have to use a spacer/adapter at all if my math is right. I hadn't considered the stock studs poking through the bolt on adapters. (I've always heard the bolt on version called an adapter and the slip over one called a spacer) Anyway, what would be the perfect offset to bolt onto the front without using a spacer? Looking at a 18x9.5 rear with a 40 offset (3in lip BTW). Front would be a 17 or 18x8 with a 40 offset (1.5in lip). Edited June 27, 2010 by chiplee Link to comment Share on other sites More sharing options...
D_Venable Posted June 27, 2010 Report Share Posted June 27, 2010 (edited) Sure does, and I found them in the right bolt pattern and a 40 offset now so I might not have to use a spacer/adapter at all if my math is right. I hadn't considered the stock studs poking through the bolt on adapters. (I've always heard the bolt on version called an adapter and the slip over one called a spacer) Anyway, what would be the perfect offset to bolt onto the front without using a spacer? Looking at a 18x9.5 rear with a 40 offset (3in lip BTW). Front would be a 17 or 18x8 with a 40 offset (1.5in lip). That really depends on how you want them to sit, and the tires your gonna use. My Durban car, I've got an 18x9.5 with a 265/35 on it, combined offset of -11, tire just rubs a non-rolled fender... before is -3 combined (25mm spacer) after is the -11 combined (33mm spacer), wheels have a 22mm offset http://26liter.us/gallery/albums/userpics/10030/NewSpacer.jpg to be on the safe side for tire fitment, I'd shoot for +10 up front on that 17x8, and 0mm out back. That should give you plenty of wiggle room for tire choice. what size tires you thinking of? 245/35r18 and 285/30r18 ??? Edited June 27, 2010 by D_Venable Link to comment Share on other sites More sharing options...
Komeuppance Posted June 28, 2010 Report Share Posted June 28, 2010 (edited) http://home.comcast.net/~Komeuppance/HdrSun1.jpg http://home.comcast.net/~Komeuppance/HdrSun2.jpg http://home.comcast.net/~Komeuppance/HDRNight1.jpg http://home.comcast.net/~Komeuppance/HDRNight2.jpg http://home.comcast.net/~Komeuppance/HDRNight3.jpg Wheels/Tires:Front: 16x8 -10mm, 205/55-16Rear: 16x8 -10mm, 225/50-16 + 25mm hub/wheel centric bolt on spacer (Combined offset -35mm) Suspension:MK1 sleeveoversMK1 front camber platesMK1 roll center adjustersMR-2 Tokico Illumina struts in custom shortened (2") housingsArt's rear camber plates Various:All fenders rolled with eastwood fender roller... and hammer.All camber plates maxed outFront wheel wells modified to allow for full turning radiusLowered... a bit. -Robert Edited June 28, 2010 by Komeuppance Link to comment Share on other sites More sharing options...
Komeuppance Posted June 28, 2010 Report Share Posted June 28, 2010 (edited) Sure does, and I found them in the right bolt pattern and a 40 offset now so I might not have to use a spacer/adapter at all if my math is right. I hadn't considered the stock studs poking through the bolt on adapters. (I've always heard the bolt on version called an adapter and the slip over one called a spacer) Anyway, what would be the perfect offset to bolt onto the front without using a spacer? Looking at a 18x9.5 rear with a 40 offset (3in lip BTW). Front would be a 17 or 18x8 with a 40 offset (1.5in lip). Awww... +40 offset... nooooooo!! Way too high. You will rub the strut most likely with the high 40mm offset on the front without a spacer. The less spacer you have to use, the better. I'd say use the 18x9's +20 offset all around with a 245/35 tire (+0.43% speedo error). Maybe a 5mm spacer on the front, Rear spacer 40mm. This will be a slightly aggressive ("flusher" to the fenders) fitment aka "perfect" offset. The ideal offsets you'd want on 9" wheels are, front +20 to -0 and rear -0 to -20. (Near stock fitment to aggressive fitment, respectively) -Robert Edited June 28, 2010 by Komeuppance Link to comment Share on other sites More sharing options...
Dave-O Posted June 28, 2010 Report Share Posted June 28, 2010 With a 30mm spacer on my front 17x9" +24, they sit just BARELY outside of the fender. A 25mm adapter is plenty to go from 114 to 120, and will allow them to sit almost perfectly. Link to comment Share on other sites More sharing options...
nomad Posted June 28, 2010 Report Share Posted June 28, 2010 http://home.comcast.net/~Komeuppance/HDRNight1.jpg Robert, I'd like to see some close up pics of the flare that you rolled into the front fender. Exterior and interior if you please. I have an eastwood too and just rolled the fenders yesterday, but did not add the flare like you have. It looks really good with the flared edge. Link to comment Share on other sites More sharing options...
Convette Posted June 28, 2010 Report Share Posted June 28, 2010 yeah any pics where you can actually see your car and its not crazy exposed..., would be awesome. Link to comment Share on other sites More sharing options...
creakyjoints Posted June 30, 2010 Report Share Posted June 30, 2010 (edited) Go to jegs.com Look up (percys 01201). It costs 70 bucks but you can take the size tire you want to run and use it to tell you what offset wheel you need. Or in you case what spacer you need. I would also recommend using the ones that JusPaus used. Do it once and be done. Idrftjunk. I hope you NEVER use those wheels for drifting! Those bad boys scream 80'S! Edited June 30, 2010 by creakyjoints Link to comment Share on other sites More sharing options...
Komeuppance Posted July 1, 2010 Report Share Posted July 1, 2010 yeah any pics where you can actually see your car and its not crazy exposed..., would be awesome. That's what my car looks like in real life... it's got these crazy dark and light contrasting thing going on with it. No wonder people stare hard whenever I roll by. LOL... I'll get some pics in a while. -Robert Link to comment Share on other sites More sharing options...
starquestJOE Posted September 2, 2010 Report Share Posted September 2, 2010 tsw thruxtons 18x9 18x10 et20. 32mm spacer in rearhttp://i713.photobucket.com/albums/ww135/starquestJOE/sq1.jpg Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted September 2, 2010 Report Share Posted September 2, 2010 nice gun metal center with polish lip.what size tires?now get a paint job... Link to comment Share on other sites More sharing options...
starquestJOE Posted September 2, 2010 Report Share Posted September 2, 2010 245/40/18 up front and 275/40/18 rear. i was goin to bring up that we need to start listing tires. i went on and got the same size tires as IDRIFTJUNK. he has the same size rims i have, and wanted the same streach on the tires. but i went and got nexen n3000 and have no where near the streach he has. this would be on the 17's i just put on. i'll have pics up later. ITS A MOST TO POST TIRE BRAND AND SIZE.......AS WELL AS RIM BRAND AND SIZE And i know it needs a paint job. burton's all over that Link to comment Share on other sites More sharing options...
MoltoMario Posted September 2, 2010 Report Share Posted September 2, 2010 Yea certain tires are known to not stretch well at all while other stretch great. My BFG KDWs dont stretch too nice but my Freddy's on the front are one of the best stretching tires. Falken 912s and 512s along with the FK series Falken has are known to be great for stretching. Ive stretched Azenis are they were decent. Not the best but no where near bad. Once I burn up the KDWs Im for sure going with Azenis again. Link to comment Share on other sites More sharing options...
starquestJOE Posted September 2, 2010 Report Share Posted September 2, 2010 17x9.5 et35 front and 17x11 et33 rear. Nexen N3000 all around, front 245/40/17 and rear 275/40/1732mm spacers all around http://i713.photobucket.com/albums/ww135/starquestJOE/P9021125.jpghttp://i713.photobucket.com/albums/ww135/starquestJOE/P9021127.jpghttp://i713.photobucket.com/albums/ww135/starquestJOE/P9021124.jpghttp://i713.photobucket.com/albums/ww135/starquestJOE/P9011123.jpghttp://i713.photobucket.com/albums/ww135/starquestJOE/P9021126.jpghttp://i713.photobucket.com/albums/ww135/starquestJOE/P9011123.jpg Link to comment Share on other sites More sharing options...
Dave-O Posted September 2, 2010 Report Share Posted September 2, 2010 Very nice, looks and fits great! On a related note, I noticed you have one of 101's carbon airdams. I'm going to buy one, looks to fit well. Link to comment Share on other sites More sharing options...
Convette Posted September 3, 2010 Report Share Posted September 3, 2010 Joe got those coil overs on yet? Link to comment Share on other sites More sharing options...
nomad Posted September 10, 2010 Report Share Posted September 10, 2010 RED CARS ONLY ON THIS PAGE HAHAHAHA. ALL OTHER COLORS GTFO! BBS RG-R Front: 18x8.5 +23 with 7mm spacer wearing Goodyear Eagle All-season 245/40/18Rear: 18x9.5 +25 with 25mm spacer wearing Goodyear Eagle All-season 275/35/18 I'm going to chage the spacers and get the stance right soon. And the flare is a work in progress. Its close to perfect, but needs improvement. I might change the stripe to silver too. http://i289.photobucket.com/albums/ll231/nomad1856/bbssiged.jpghttp://i289.photobucket.com/albums/ll231/nomad1856/IMG_3898.jpghttp://i289.photobucket.com/albums/ll231/nomad1856/IMG_3899.jpghttp://i289.photobucket.com/albums/ll231/nomad1856/IMG_3906.jpghttp://i289.photobucket.com/albums/ll231/nomad1856/IMG_3903.jpg Link to comment Share on other sites More sharing options...
starquestJOE Posted September 10, 2010 Report Share Posted September 10, 2010 D2's wt.... http://i713.photobucket.com/albums/ww135/starquestJOE/P9100024.jpg Link to comment Share on other sites More sharing options...
boostaholic13b Posted September 29, 2010 Report Share Posted September 29, 2010 Starquest + fr500 = Pics please... Link to comment Share on other sites More sharing options...
