4g64/63 Swap
133 replies to this topic
#1 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 31 August 2015 - 04:23 PM
I finally started messing around with my conquest this weekend. My buddy helped me push it into the shop Friday. Saturday the power went out, so I went into the shop and using a flashlight and outside light from the shop door I was able to pull the G54 out as well as a few other components I don’t need anymore. Then my buddy came back over excited to see the car and we decided to pull the 4g64 off the engine stand and see how it looks in conquest.
Edited by devilsfutbol17, 31 August 2015 - 04:25 PM.
796/2000 Summit White Galant VR-4
1994 Pear White 3000GT VR-4
1997 Eclipse Spyder GST (Wife's car)
1988 Fiji Blue Conquest TSi SHP
#2 importwarrior
  • 18,356 posts
Posted 31 August 2015 - 05:28 PM
nice start so far.
#3 TexasQuest
  • 9,111 posts
Posted 31 August 2015 - 07:35 PM
Lookin good. I'm diggin' the Mazda 323 GTX. B)
88 Fiji Blue -TSi
#4 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 31 August 2015 - 10:48 PM
Thanks. Yeah my friend is into Mazdas. He's got that, two AWD proteges, and an RX-7 FD.
I was planning on making this just a cheap cheap swap doing the bare minimums to get it running. I have another 6bolt 4g64 that I'll build up nicely when I get the cash. So I'm trying to decide what to do with the pistons. The SOHC pistons don't have the correct valve grooves and from what I can find on dsmtuners the valves will hit the pistons. I'm thinking about either getting DOHC 4g64 pistons, or possibly determining where the valves will exactly hit the pistons and take them to the machine shop to have valve reliefs cut into them.
Anyways, I pulled the motor back out so I can start cleaning stuff up, removing other items I don't need, and tinker with the motor to see what will work. Sorry the lens on my phone camera is messed up.
Edited by devilsfutbol17, 31 August 2015 - 10:49 PM.
#5 DSMracespeed
DSMracespeed
  • 1,127 posts
  • Interests:STARQUEST...CARS,CARS,CARS
Posted 02 September 2015 - 12:57 AM
Nice list of cars you got...and your friends 323 gtx is super rare!
I picked up a Conquest that had a 4g63 swap done already a few years ago that had jumped the timing belt and bent some of the valves.The head was pulled off when I got it and one day I will get to fixing it!
Jerry L.
'87 Starion
'88 Conquest TSI...4G63 swap
'86 Lotus Esprit Turbo...Restoring
'08 Evo X MR
'03 Evolution VIII
'03 350z
'95 Eclipse GSX
'00 Celica GTS
'02 Protege5
'88 CRX Si
'04 RX-8
#6 starquestJOE
starquestJOE
  • 3,586 posts
Posted 02 September 2015 - 03:32 AM
Very nice start! One day I will do a 4g swap just because it looks so right in there
IM STARQUEST 4 LIFE ....
88 esi-r-white-SOLD
88 tsi white 61k-SOLD
89 tsi-black-rip
87 tsi-black/red-SOLD
88 tsi yellow sold
89 tsi white parts car
88 esi-r-black-RIP
#7 importwarrior
  • 18,356 posts
Posted 02 September 2015 - 05:02 AM
all the info you need and then some
http://projectzerog.com/
should help with any issues you might have.
#8 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 02 September 2015 - 10:17 PM
Yeah that website has been helpful. So far I'm struggling to find information about power steering or lack thereof when people do the swap. I planned to go manual steering but I saw a bunch of people advising against it in the starquest. Right now the plan is to keep P/S and either use the starquest pump or a DSM pump relocated to where the alternator was.
#9 importwarrior
  • 18,356 posts
Posted 03 September 2015 - 05:02 AM
contact funkyphil. he could probably source the proper power steering hoses to reach the power steering gear box for you.
EASY. just measure the length you need to route them safely and give him the lengths.
he uses steel braided hoses so they have some flex to them.
#10 screemin eagle
screemin eagle
  • 1,007 posts
Posted 03 September 2015 - 09:16 AM
I used the 2g power steering pump and and high pressure line in stock dsm location. I made my own line high pressure line from the 2g line to the steering box with Russell Teflon stainless braided line and some adaptor fittings. For the low pressure line I used the factor Starion one and reservoir. It wasn't hard to do. If you search timsi's 5.0 build thread all the fittings sizes and part numbers are there.
88 TSI 4g63
03 GMC Denali the tow truck
#11 starion1991
starion1991
    Arizona sq hoarder
  • 1,991 posts
  • Interests:Rare japanese old school cars
Posted 03 September 2015 - 01:01 PM
You shoud concider doing a steering rack swap while doing the swap. im finishing up my s13 rack in my car, then im swapping in a 6bolt from a talon. In my case i should have no issues with p/s besides making lines.
85 flatty
86 silver widebody, the big project
87 red conquest
88 Palermo (awaiting 4g63 swap)
87 starion parts bucket
87 87 conquest wrecked parts car
2014 evo x, daily beater
#12 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 03 September 2015 - 10:35 PM
If I do a power steering rack swap, I'd go manual steering for sure. I'm going to go this route though since I've found someone else using it successfully. http://forums.austar...hp?f=13&t=12629
#13 Turbo Cary
Turbo Cary
  • 1,800 posts
Posted 28 September 2015 - 06:36 PM
What kind of clearance do you have between the rear of the head and the firewall? Still using the stock trans?
#14 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 04 October 2015 - 02:30 PM
Not enough for a 1g CAS. I am using the stock trans. I'll pull the CAS off and take another picture.
#15 importwarrior
  • 18,356 posts
Posted 05 October 2015 - 06:04 AM
what engine mounts are those?
could you use a 95 cam and crank sensor?
#16 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 05 October 2015 - 02:46 PM
Those are the truck brackets bolted to the 4G64, with the conquest mounts bolted to the frame. The truck mounts that bolt to the frame were the exact same as the conquest ones as far as I could tell with them side by side.
That is the plan so far. I purchased a 95 head last week with the cam sensor and I plan to use a kiggly 6 bolt crank sensor. I'm going to be using a 1g engine harness and 1g dsmlink since I already have both, so we'll see how well those sensors work with the 1g setup. I posted on tuners but haven't gotten any feedback yet.
#17 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 05 October 2015 - 02:47 PM
What I posted on tuners.
Using the below diagram, can I connect a 2g CAS and a 2g Crank sensor to the CAS connector on a 1g engine harness? It looks like I would need to connect the red positive and black negative wires on the 2g Cam sensor to the 1g CAS connector terminals 3 and 4. I'm planning to run 1G DSMLink with a 1g DSM wiring harness and would like to use the 2g sensors. Also, if I do this it looks like the cam signal will be inverted, so I think I'll need to switch the fuel injector pins on the ECU connector correct?
#18 devilsfutbol17
devilsfutbol17
  • 102 posts
Posted 05 October 2015 - 03:07 PM
Took the CAS out. This is with the engine in the mounts and bolted to the trans.
#19 Turbo Cary
Turbo Cary
  • 1,800 posts
Posted 05 October 2015 - 05:47 PM
Thanks for getting pics/measurements. How is the pan and steering clearance? Pretty much factory?
#20 importwarrior
  • 18,356 posts
Posted 05 October 2015 - 07:39 PM
Great info.
I was wanting to do this swap for sure.
Thanks very much.
