Squrlsquash Posted September 30, 2014 Report Share Posted September 30, 2014 (edited) go to last post got timing marks lined upunsure what marks to line up for distributor advice?thanks in advance http://i1297.photobucket.com/albums/ag24/Squrlsquash/TIMINGGURR_zps6aba25d0.jpg Edited November 22, 2014 by Squrlsquash Link to comment Share on other sites More sharing options...
Dad Posted October 1, 2014 Report Share Posted October 1, 2014 Looks right, you may have to turn that over like 60 times to align them again, and it might be the crankshaft link you are looking at., If you are going to pull the head now, just mark gear and a link with a paint marker. Be sure you have the little shelf for the gear to sit on. Dad Link to comment Share on other sites More sharing options...
Squrlsquash Posted October 1, 2014 Author Report Share Posted October 1, 2014 okay, will have someone else turn it over a few times while i watch the gear- forgot there were two marked links Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted October 1, 2014 Report Share Posted October 1, 2014 There's two plated links. One for the crank and one for the cam. I can't remember how many rotations it takes for the marks to line up correctly again, but it's something in the 30-40 range I believe. Like Randy said, just mark the link and gear and you should be fine. Fyi...if the crank is at TDC, the cam will have that dowel just before 12 o'clock. If it's the opposite side at just before 6 o'clock, then spin the crank around one more time. - Charles Link to comment Share on other sites More sharing options...
Squrlsquash Posted October 2, 2014 Author Report Share Posted October 2, 2014 cam gear rest is missing on this motor - thinking i can stick a shim between the timing gear and the chain guide to hold it up while i pop the head off. anyone have tips on how to change the head gasket like this without screwing up the timing? Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted October 2, 2014 Report Share Posted October 2, 2014 If you can find a string or wire small enough to fit through the dowel oin in the gear, you can feed it through at tie it to the hood. You'll have to undo it momentarily when pulling the head off and then retie it, but that's one way to do it. Definitely will need more than one person for that. - Charles Link to comment Share on other sites More sharing options...
Squrlsquash Posted October 7, 2014 Author Report Share Posted October 7, 2014 UnrelatedAnyone know where to pick up tach signal and 12v switched on the instrument panel? cant find a useful pinout and have a ways to go before i can start her up and poke around with a multimeter http://i1297.photobucket.com/albums/ag24/Squrlsquash/IMG_7214_zps79d407ea.jpg Link to comment Share on other sites More sharing options...
Tim_C. Posted October 9, 2014 Report Share Posted October 9, 2014 You can pull the cam gear out too, or wedge a block down where the shelf goes, between the chain to keep it from falling in after removing the gear. As long as you put the head back on with the cam in the same place, it really doesn't matter if the chain slips off of the crank gear and then doesn't go back on exactly the same. You can always pull the chain back on the crank gear. You will need to push the tensioner plunger back in before you can get the cam gear back on. Link to comment Share on other sites More sharing options...
Squrlsquash Posted October 10, 2014 Author Report Share Posted October 10, 2014 pulled the head, used a zip tie to pull up the chain slack and don't believe the crank gear could have jumped a tooth dark yellow staining on the spark plugs and nice wet deposits on the combustion chamber usually means burning some oil?probably just because i haven't done any long trips with it yet, might just be granny syndrome... valve seals looked dry, but there was some oil/fuel on the pistons my plan is to pop it together and do some serious driving to break the deposits loose sound good? Link to comment Share on other sites More sharing options...
Shelby Posted October 11, 2014 Report Share Posted October 11, 2014 (edited) ok while the head is off,, put a cam gear holder back on the engine block,, if you have not got one,, post and some of will get an used one for you , that holder is worth it's weight in gold dude now checking cam timeing , turn engine until the cam is in time,, then check the crank pully timeing not before if the cam is in time the crank pully mark will be with in a couple of degrees of tdc , one tooth on crank will change the mark 9 degrees at the crank , rotatr the engine 2 complete turns , back to tdc , this time watch the mark on crank pully after making sure the cam is right, install the dist dist will have to be in to set it to tdc #1 after the cam is set and befor the valve cover is install'd ( so you can watch the drive as you incert it ) chain can be walk'd around gear one tooth at a time is need be , it's all very easy and simple to do note do not have pistons at tdc when installing head,, back the block up to btdc say 10 degrees , you can rotate it to tdc just before timing the cam this insures no piston to valve interference Edited October 11, 2014 by Shelby Link to comment Share on other sites More sharing options...
Squrlsquash Posted October 14, 2014 Author Report Share Posted October 14, 2014 Would the valves hit the pistons if it was off a tooth? turns over fine without binding Otherwise i have to pull the timing cover to reset the chainany problem with putting it in gear to hold the crank and pulling the crank bolt? Link to comment Share on other sites More sharing options...
Squrlsquash Posted October 14, 2014 Author Report Share Posted October 14, 2014 Okay, no more mr. nice guyi want this done, and done right can i set the timing marks without taking off the oil pump gear?should i pop the cam gear off to line up the chain, then rotate the crank/cam to match?i'll be back at it tomorrow, any tips would be helpful http://i1297.photobucket.com/albums/ag24/Squrlsquash/timingbits_zps14eb388e.jpg Link to comment Share on other sites More sharing options...
Squrlsquash Posted October 31, 2014 Author Report Share Posted October 31, 2014 There is no timing mark on the crank gear... i have another crank gear that does have the mark, should i swap the gears out? or just put a mark in the same place on the un-marked gear? To do that id have to pull the oil pump crank gear. can it be pulled and reinstalled without removing the oil pump? Link to comment Share on other sites More sharing options...
Dad Posted October 31, 2014 Report Share Posted October 31, 2014 Pump does not need to be removed Link to comment Share on other sites More sharing options...
Squrlsquash Posted November 22, 2014 Author Report Share Posted November 22, 2014 Turned engine over a few more times and the marks all lined up like the picture in the service manualwhich i believe is TDC cyl 1 how do i line up the distributor?do i line up the dimple in the gear with the mark on the shaft? Link to comment Share on other sites More sharing options...
DSMracespeed Posted November 22, 2014 Report Share Posted November 22, 2014 You line up the dimple on the gear with the mark on the shaft before installing on the head and the gear will turn slightly when it comes in contact with the cam gear.Make sure the adjustment bolt is at the center of the adjustment hole when installing the distributor onto the head!!! Jerry L. Link to comment Share on other sites More sharing options...
tsi_tom Posted November 22, 2014 Report Share Posted November 22, 2014 (edited) This is where the dimple ended up when I installed the distibutor. Indiana had a good picture too but his page isn't working anymore. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/distributorandcamtiming_zps523a9395.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/distributortimingmark_zps5a0efcad.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/rotoranddistributoralignment_zps368b6c53.jpg Edited November 22, 2014 by tsi_tom Link to comment Share on other sites More sharing options...
DSMracespeed Posted November 23, 2014 Report Share Posted November 23, 2014 That looks about right...rotor should be pointing at the adjustment bolt. Jerry L. Link to comment Share on other sites More sharing options...
