- 6 replies
- 774 views
- 7 replies
- 990 views
- 6 replies
- 1176 views
- 17 replies
- 1465 views
What is required for the cruise control to work when swapping to mpfi?
By Mike7447,
As stated, I’m converting over to a DIY made mpfi intake manifold. I’ll be using a universal 65 mm throttle body.
Since I’m making the intake, I can design the thing to mount the TB where I want it. While I haven’t looked closely at the old throttle body, I’m sure I’m going to have to try and adapt the cruise control servo/solenoid/actuator to the new TB.
Ignition will no longer rely on the old distributor, and the coil will go in favor of a crank trigger/coil near plug system con
Why would I get rid of the balance shaft..
By Mike7447,
Simple enough it seems, I’m gonna have the timing chain cover off when I remove the balancer to modify it for a trigger wheel. Also gonna remove the head, and convert it to studs and the add back the Ajusa mls head gasket.
What benefit do I gain by omitting the balance shaft?
FREE short block
By Turbo Cary,
Located in Charleston SC. I found an old short block in the shed. Free to anyone willing to come pick it up. Don't ask me the condition. I didn't look hard enough at it. I'm pretty sure the crank is there along with the main caps and maybe pistons/rods
Drivers window stuck down - Need Help??
By techboy,
I feel like it's been a long time since I've put a post up looking for help ... but I need help guys. Went to a car show about 2 weeks ago and put my windows down. My drivers window has been stuck down ever since.
I took the switch off tonight to look at it, but I don't see how it would come apart to look inside at the contacts.
I don't have another switch. When I installed the new interior last summer the interior I bought didn't come with switches, so I swapped over my
