- 1275 views
- 18 replies
- 1928 views
- 7 replies
- 2374 views
- 8 replies
- 1545 views
Motor rebuild
By 86technicaflatty,
Hey guys been on the forum for a while I'm just new to posting. I have a 1986 dodge conquest technica that I've had for about 12 years. Drove it daily for the last 2 years. It is all original other than the normal wear and tear items. I'm wanting to bore the g54b .030 over and I'm not sure what pistons and rings I need for that bore. Can yall help me out???
MSD 6 VS.MSD6-BTM
By bender 702,
There has been a lot of discussion on using MSD 6 or 6al with mostly good results. Now the msd6-btm has an added vacumn port that when connected compensates for boost by retarding the spark by up to 15 degrees, however I understand that our own ECU does that to some extent already. The question is this: If you are upgrading to a 20G (using the stock TD05) will the increased CFM at 10psi still be compensated by our ECU? I have aslightly modded engine with upgraded head, vlaves, ARP, solid cam
pf16 spring fling
By Big John,
Spring meet April 29th, 30th, and may 1st at the vacation lodge. This will be an extra meet for those who can't make it on July 4th.
Fuel sending unit
By lgarbz,
Can someone tell me where the the fuel sending unit grounds? I chased the harness to a joint connector by the tail light harness and then it goes up the driver side of the body. Where does the harness ground to the chassis?
