- 84 replies
- 12320 views
- 7 replies
- 1072 views
- 32 replies
- 33661 views
- 26 replies
- 4148 views
headlight conversion
By MoMagnum,
I love the looks of our StarQuests-except when the headlights are up. There has to be someone with the ability to make a new unit the just bolts in place of the stock ones. There looks to be enough room for a projector style low and high beam, and there should be some kind of acrylic cover with the same shape as the headlight-meaning that looking at the car from the side, there would be no change in the profile. I have seen that picture on the web of that Quest with the 3000GT lights, but I want
What About Links?????
By Tim_C.,
I must be blind or something, but I can't find any links???
Tim C.
Wheel Offset and Tire Size (87-89)
By KO,
Posted By 88 ESI-R
Tire Size
FRONT: 205/55/VR16 (7" front wheel) or 225/50/VR16 (8" front wheel)
REAR: 225/50/VR16 (8" rear wheel) or 245/45/VR16 (9" rear wheel)
Wheel Size
Front: 7"x16" (7J-16) or 8"x16" (8J-16)
Rear: 8"x16" (8J-16) or 9"x16" (9J-16)
Wheel Offset
Front:
7"x16" mm (in.) 18 (.7)
8"x16" mm (in.) 18 (.7)
Rear:
8"x16" mm (in.) -10 (-.4)
9"x16" mm (in.) 0 (0)
Torque Specifications
Wheel Nuts
Nm 90-110
Ft.lbs. 65-80
8
DSM Turbo Conversion
By Rick_Tross,
Hey all just got done fitting an Eclipse 16g to my Starion with the help of a few of my friends. I've never experienced a 16g before but the eclpise wastegate is much better then a conquest one. The factory boost is set higher for one thing and the turbo is more responsive. I plan on turning out a few of these conversion kits as an alternative to buying turbos made for starquests as they are more expensive also you can go to a boneyard and pick up eclipse stock turbo with my kit and have a 14g b
