- 1 reply
- 839 views
- 8 replies
- 3191 views
- 11 replies
- 1933 views
- 820 views
find members by location
By wastegate,
It would be really cool to know who is local around you. It would be a great help
in planning meets to know who to contact in the area. Thanks!
-wastegate-
Headlights won't go down
By SQF,
  This is a VERY common problem.  The headlights will go off but the popups refuse to drop.  If you run into this problem run out to the car depress the OFF switch and "wiggle" the ON switch.  Normally this will get the popups to drop.  The cause is that the switch contacts get corroded and lose contact. Â
  If the popups drop when you "wiggle" the On switch then the following proceedure will more than likely cure the problem.
Remove the left bank of switches (remove screws and
Intercooler Piping Size when using Magna
By kev,
What is everyone going to use for intercooler piping when they get their Magna?
Just curious, before with the stock intake it was found by experiment that there was better spoolup and horsepower gains by using a 2.25" hardpipe rather than a 2.5" hardpipe. I guess this is due to the bottleneck of the 52mm TB remaining and also the larger area which takes longer to pressurize. However with the Magna, we will have a 65mm (~2.6") TB. Thus will it be more beneficial to use a 2.5" hardpipe?
Part Number Xreference with other Mitsu's
By DrkRaven,
I know that Mitsu interchanged parts on the StarQuests with other vehicles like Monteros, Cordias, Tredias, Galants, etc. And since they are MUCH more common than our cars... perhaps if we know what can be found on what.... we can be much more successful locating those much needed small things that the dealer charges exponentially for.
For instance.... does the radiators or clutch fans from the others have the same part numbers as those used on StarQuests? We should have an index or search
