    3" exhaust
    4cylFury
    By 4cylFury,
    How much.
    Bunch of savages in this town..
    Skrilla
    By Skrilla,
    Couldn't resist the photo op http://i1273.photobucket.com/albums/y417/Skrilla000/clerks_zps90128887.jpg
    issues
    smallblock12
    By smallblock12,
    so my 86 has a new motor with around 1500 miles. been redoing tons of things and it was running great with the exception of leaks. i finally got the leaks all takin care of and it starts running choppy and dies in the middle of the road. finally got it bump started and made it home. its an all stock 86 car does throw a mas code, but i was told its because my tps isc reset isnt correct and its not pulling enough air at all time to read over 10hz. it will idle smooth but if you let it idle all the
    Good Aftermarket Catch Can?
    mstieg
    By mstieg,
    I'm finding that my plans to reinstall stock oil separator will not work as I need more vacc than it offers, plus it's far from clean inside.   Looking at those with the needed larger 3/4" (19mm) In/Out, this turned up as one of the only options without an open breather on top and without costing $170+.   http://www.ebay.com/...=item35d9872bc1 *EDIT: seller said it's not baffled. Cancel that.
  • Today's Birthdays
    1. ko929
      ko929
      (53 years old)
    No members to show
