- 468 views
- 10 replies
- 1071 views
- 61 replies
- 9075 views
- 6 replies
- 1036 views
small HID issue
By Turbo Cary,
I had a set of 35w 6k hid but the ballast went bad so I decided to upgrade to a 55w 8k system. My 6k kit I forgot to order dual beam bulbs but this time I made sure I did. My high beam function is not working. I used a dvom to measure voltage and stuff at the connector and all wires are set up accordingly. On the low beam side of the harness it reads 10v (with the car off) and on the HB side it reads .023v when my low beams are on. When I switch to HB it reads the same 10v on the HB side. Also
Braketubes partnumbers??
By Starionboy84,
Im replacing the braketubes (front and rear). Enyone knows the partnumbers ??
parting out black '88 shp 5-speed car
By joebeckham,
Small parts list on bottom of this post! Call or text 530-519-8001, email joebeckham08@gmail.com, or pm me here Located in Orland, Ca 95963 just off I5 90 miles north of Sac, 60 miles south of Redding Had a small engine backfire and burned a fair share of the wiring/throttle body area and dash area. Parts that have been sold: -fuel pump -flywheel & clutch -passenger door window -driver door window -turbo & intercooler -rear hatch carpet -PS reservoir -oil cooler -ship wheels -d
Intercooler..... What kind should be used???
By questtuner82,
Ok so im getting ready to get all my new stuff in..... Fully built motor .60 over with je forged pistons pauter rods lightened and knife edged crank bse balanced with lightweight flywheel, ported non jet head with 2mm oversized ferrea stainless valves beehive springs crower custom roller cam with 6g72 roller lifters custom mpi intake a gt35r turbo edis ign 2.5" hardpipe 3" exhaust with apexi muffler. Just wondering what kind of intercooler i should use and can fit in there with little to no mods
