- 1413 views
- 9 replies
- 1048 views
- 19 replies
- 1360 views
- 7 replies
- 1168 views
jet valve removal
By TexasQuest,
The FSM says I need special tool MD998309 to remove the jet valves?
Measles "OutBreak": Cali Disney
By Guest,
I'm sure all of you have seen the news on the recent measles outbreat that is said to have originated from a visiter of Disney. I was born in '75 and I recall as a kid, vaccinations were a big deal. It was so important to be vaccinated. But I've noticed in recent years there has been an anti vaccination movement. Some people seem to believe they are unnecessary and in fact blame vaccinations for autism. Don't know about you guys. But I am sure glad myself and my family had all the
full throttle problems
By maximum_overdrive,
i have been having some problems with the car lately , i did a full tune up with all the good stuff brass cap, rotor, ngk wires ,ngk 7031 plugs gapped to .32, ntk o2 sensor, timing at 10* and did the tps reset,and its running good under part throttle but under boost i get a hard mifire 3500ish rpm then it accelerates to 5k rpm and starts to break up. . i have had 2 different sets of injectors and its done the same thing. i haven't had the time to check fuel pressure yet but the regulator is
fuel injector clinic stock replacement injectors
fuel injector clinic stock replacement injectors , i only put 1000 miles on these and i replaced them with good stock injectors. they did make my car run alittle rich, you might want to have them flow tested but they are the 650cc and 950cc injectors. have paypal, $150 shipped http://i134.photobucket.com/albums/q104/Drift_300ZX/001-1.jpg http://i134.photobucket.com/albums/q104/Drift_300ZX/002-2.jpg http://i134.photobucket.com/albums/q104/Drift_300ZX/003-2.jpg
