- 21 replies
- 5087 views
- 9 replies
- 759 views
- 445 views
- 6 replies
- 755 views
'89 SHP Sunroof 5 Speed Two Owner in Upstate SC
By theastronaut,
'89 Conquest TSi, has the SHP package with adjustable struts and 8/9" wide wheels. 5 speed with sunroof, still has the sunroof bag in the trunk. I bought it from the original owner in 2013. He parked it 2000 when the clutch started slipping. It did crank when I bought it by pouring gas in the throttle body. I removed and cleaned out the gas tank and bought a new Walbro fuel pump. The throttle body has been rebuilt. Will need both injectors and the soft fuel lines replaced. I removed the distribu
something off 180deg
By mbruneaux,
So I replaced the pickup coil and put the distributor back in, car starts but it looks like it's off a tooth because I can't get the base timing to retard any more than 10deg ATDC. I decided to take the valve cover off and distributor out and reset it per the manual. I line up the crank to 0, cam pin and the dot on the distributor but the distributor rotor is facing away from #1. I must have put the drive gear on 180 off. I correct the gear drive so everything lines up properly and when I
1987 CHYSLER CONQUEST TSI TURBO 5 SPEED - $1200 (JEFFERSONVILLE)
By NikoFab,
http://louisville.craigslist.org/cto/4883389235.html http://images.craigslist.org/00t0t_bHf9Nc3fUqr_600x450.jpg
1987 mitsubishi starion turbo 1 0wner 40, 000 miles - $4500 (torrance) - FLATTY ALERT!
By NikoFab,
http://losangeles.craigslist.org/wst/cto/4877915114.html http://images.craigslist.org/01515_dVeUhelInKW_600x450.jpg
