Burton Posted April 10, 2009 Report Share Posted April 10, 2009 (edited) It's not really parts, but I'm for sale LOL. Need to make some loot to get this shop finished up, and I got spare time on my hands so I'm looking to take on some work. -Antenna delete- $75 http://www.26liter.us/gallery/albums/userpics/10087/stereo_019.jpg -Rear wiper delete- $100 (pic also shows antenna delete) http://www.26liter.us/gallery/albums/userpics/10087/1258744059_5d0861d773.jpg -Shaved license plate lights on plate trim piece- $75- includes new LED plate lights wired to stock plug. Comes in satin black (like stock) or primer http://www.26liter.us/gallery/albums/userpics/10087/5-18-09_003.jpg -Header panel mods- $150 on up depending on intricacy of design http://www.26liter.us/gallery/albums/userpics/10087/87%20quest2%20039.jpg http://www.26liter.us/gallery/albums/userpics/10087/header-grille_001.jpg -Smoothed rear bumper step- $200 http://www.26liter.us/gallery/albums/userpics/10087/stereo_016.jpg -Shaved rear bumper step- $250 http://www.26liter.us/gallery/albums/userpics/10087/8-18-07_(14).jpg -Larger IC opening on front bumper (no airdam)- $250 -Larger IC opening and molded in airdam- $350 on up depending on if there is any damage to the airdam http://www.26liter.us/gallery/albums/userpics/10087/DSCF0028~7.JPG http://www.26liter.us/gallery/albums/userpics/10087/1258742191_205b6d5ceb.jpg Prices are based on you supplying the parts and being responsible for shipping. The larger, heavier parts like the bumpers, will not be cheap to ship- at least on the way back when I will insist on going above and beyond in packaging it to be sure it is safe from damage. For the bumper mods, I also require that the bumpers come assembled with the support included, as the covers need the supports to maintain straight bodywork. Prices include all materials and labor, but prices listed are for the parts to be finished out in primer only, unless otherwise noted. I can paint the parts as well for an extra fee- about $50 for the small parts on up to $100+ for larger parts like bumpers. Sadly, due to the fact that materials make up a majority of these prices, I require full payment when you send your part. I'm also looking to take on paint jobs. I have a temporary booth I am setting up to use while the shop is being built. It's not perfect, but it should be at least as good as the one I had set up in my garage in MI. Now, I can do about anything from scuff and shoots up to really slicking it out for a show shine. Every car is different, so it's had to have "set pricing" for something like this. I will, however, give you an idea as best I can... -If you've got a car with minor dings and faded or mismatched paint, but the paint hasn't failed (i.e. flaking off, cracking, clouding, etc...), it can get a simple scuff and shoot. Something like that I can do for about $1000. You're probably thinking "I can go to maaco and get it done for $300". That's true, you can, but they won't do any of the ding fixing or extra prep work- they paint right over scratches and dings. They also use very cheap paints and many times only single stage paint. All of my paint jobs are basecoat/clearcoat, and are done with the care of a fellow SQ enthusiast. I have yet to see a Maaco job that can come close to matching what I can do- Not trying to bragg, just saying that I don't do $300 paint jobs. If my name is going to be on it, it's gonna be up to my standards. Any dust nibs and such will be spot sanded and polished as necessary, but no major wetsanding and polishing is included in this price. -Maybe your car is a little rougher. Maybe it's got flaking paint, a messed up airdam and big ol' dents. In this case, I'll metalwork out the big dents and fill them and any other small dings. Panels with failing paint will get stripped and bodyworked as necessary. Those repair areas will get filler primed, blocked smooth, filler primed again and wetsanded to perfection. From there the entire car will be sealer primed and painted with basecoat/clearcoat. After curing, it will receive a general wetsanding and polishing which will give you an OEM finish or better. Something like this, I can do for about $2k. -Maybe you're looking to have yourself a car that's going to be seeing some shows. For that you want it to be super smooth and super straight. All bodywork will be done, and the entire car will be blocked with 180 grit. From there, the entire car will be filler primed and blocked with 180 again. After another couple coats of surface primer, it will be block wetsanded, sealed, and sprayed with basecoat/clearcoat. I will then wetsand the entire car after curing and apply 2 more coats of clear. After that's cured, I will wetsand and polish to a smooth as glass shine. The car will end up with a straighter body than stock, as well as a FAR better than OEM finish with killer depth. Something like this would be $3k+. I know that sounds like a ton of cash, but honestly, I should probably charge closer to $4k. This is pretty much a full, body-on, paint restoration. At the hot rod shop I used to work at, something like this would cost $11-15k. For this sort of job, I would likely actually rent an honest to goodness paint booth. I have a connection for one if I need to. Prices listed above are including labor and materials. For primers and paints I would be using some good quality, yet fairly inexpensive paint brands, Like NAPA Crossfire, Sherwin Williams, Nason, Matrix, etc... If you want the higher dollar, super high quality paints like House of Kolors, DuPont, and PPG, the material cost would be higher, and therefore the job would cost more. For all paint jobs, I require 50% up front, because that's about the cost of materials. The rest is due upon completion The car needs to be at least driveable around my yard. Let me know what you got and we'll see what we can work out. Here's a link to an online body manual I have started. You can scroll down to the links to the chapters to see the various steps and processes I use. There's also some info on my background..... http://www.26liter.us/forum/index.php/topic,1604.0.html Thanks! Edited May 27, 2009 by Burton Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted April 10, 2009 Report Share Posted April 10, 2009 You just HAD to move to friggin Texas, didn't you......grrr.. Quote Link to comment Share on other sites More sharing options...
Burton Posted April 10, 2009 Author Report Share Posted April 10, 2009 You just HAD to move to friggin Texas, didn't you......grrr.. Yep, and since I've been here, I've been working at a hot rod shop doing frame off restorations and $20,000 custom paint jobs. My work now makes the stuff that came out of my garage in MI look like backyard ghetto work. Sorry, that's probably not helping your frustration, is it? Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted April 10, 2009 Report Share Posted April 10, 2009 Yep, and since I've been here, I've been working at a hot rod shop doing frame off restorations and $20,000 custom paint jobs. My work now makes the stuff that came out of my garage in MI look like backyard ghetto work. Sorry, that's probably not helping your frustration, is it? Not really, lol... I always loved what you did with Kate's car. Still got it? Quote Link to comment Share on other sites More sharing options...
Burton Posted April 11, 2009 Author Report Share Posted April 11, 2009 Not really, lol... I always loved what you did with Kate's car. Still got it? Yep, still have it. It's pretty much sat since the move, but is getting a new clutch in a couple weeks, some paint touch-ups and be hittin the shows this summer. Quote Link to comment Share on other sites More sharing options...
michael knight Posted April 11, 2009 Report Share Posted April 11, 2009 nice stuff. Quote Link to comment Share on other sites More sharing options...
Burton Posted April 12, 2009 Author Report Share Posted April 12, 2009 nice stuff. Thank you very much! To the top Quote Link to comment Share on other sites More sharing options...
Gencha Posted April 13, 2009 Report Share Posted April 13, 2009 Well I'm a painter myself and even though I only have a couple of years behind my back I can assure you that the prices listed are WAAAYYY lower than what any respected shop would charge for the quality described. And no MAACO is not a shop (the only thing they can paint is taxi cabs). You'd be better off spray-painting your car in your backyard. I dont mean to sound like I am promoting something here as I don't even know the guy but judging by the pictures I would definately let him work on my car. Anyway good luck with everything and I might be sending you out some bumpers this summer! Quote Link to comment Share on other sites More sharing options...
NotStock88 Posted April 15, 2009 Report Share Posted April 15, 2009 Well I'm a painter myself and even though I only have a couple of years behind my back I can assure you that the prices listed are WAAAYYY lower than what any respected shop would charge for the quality described. And no MAACO is not a shop (the only thing they can paint is taxi cabs). You'd be better off spray-painting your car in your backyard. I dont mean to sound like I am promoting something here as I don't even know the guy but judging by the pictures I would definately let him work on my car. Anyway good luck with everything and I might be sending you out some bumpers this summer! PM sent - I have been looking for someone to send my header panel too.... Quote Link to comment Share on other sites More sharing options...
starquestJOE Posted April 15, 2009 Report Share Posted April 15, 2009 i was just goin to pm you about a full body color change. but being i live in PA thats a trip and a half. shipping would likely kill me. i really would love to have you do it. know you know the cars very well. and are very good at what you do. i've read all of your manual you started. would you be open to giving advice. or even a list of stuff need to do on my own. i used to do it for awhile but its been 4 years since i used a gun. pm me if your willing to help Quote Link to comment Share on other sites More sharing options...
Xtreme Industries Posted April 15, 2009 Report Share Posted April 15, 2009 too bad your soo far away, i would go for a 2k paint job, even though my car has no major issues, just some minor dings. and i would love to have all the mods you listed. you do awesome work. cant find anyone around here willing to modify anything without your first born on the line. Quote Link to comment Share on other sites More sharing options...
Burton Posted April 17, 2009 Author Report Share Posted April 17, 2009 Bump Quote Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted April 17, 2009 Report Share Posted April 17, 2009 Its too bad your so far away, my blue 88 is at the stage its ready for some paint lovin. mm Quote Link to comment Share on other sites More sharing options...
Burton Posted April 18, 2009 Author Report Share Posted April 18, 2009 Its too bad your so far away, my blue 88 is at the stage its ready for some paint lovin. mm That's no excuse LOL. At my prices, you can ship the car back and forth, pay me, and still pay less than you would at a body shop. Granted, not much less, but then you know that the guy who is doing the work is doing it with SQ love and not half assing stuff. You also know you will have somebody who stands behind their work. To the top. I'm glad to see that I'm getting some interest in this stuff. However, most of it is little stuff like antenna deletes, grille work, and such. I'd really love to see some full repaints, though. 5 full repaints would pay for my concrete slab, and that would come close to getting the shop finished. Maybe y'all are concerned that I won't be able to lay paint well once the temporary booth is up? http://www.26liter.us/gallery/albums/userpics/10087/4-15-09_001.jpg http://www.26liter.us/gallery/albums/userpics/10087/4-15-09_003.jpg http://www.26liter.us/gallery/albums/userpics/10087/4-15-09_002.jpg That was sprayed OUTSIDE, with NO booth and during 10-15 MPH wind gusts. Suprisingly, There wasn't too much trash in it. There was a few dust nibs and two bugs that decided to swim around in the wet clear before they died. All those flaws are easily handled with a little wetsanding and polishing. Imagine what I can do in a controlled painting environment, even if it is "temporary". Let me know, we can make a deal. Quote Link to comment Share on other sites More sharing options...
Burton Posted April 18, 2009 Author Report Share Posted April 18, 2009 And here's some pics of full cars I have done, not just the pieces/parts. That way you can get a better idea what sort of stuff I can do. 71 GTO- Rust repair and frame on body restoration... http://www.26liter.us/gallery/albums/userpics/10087/done_006.jpg http://www.26liter.us/gallery/albums/userpics/10087/done_002.jpg 60 El Camino- custom extended cab, finalist in PPG's Paint Your Ride contest, and currently in PPG's 09 calendar- multiple award winner.... http://www.26liter.us/gallery/albums/userpics/10087/4-30-08_003.jpg http://www.26liter.us/gallery/albums/userpics/10087/4-30-08_006.jpg 64 Chevy Pick up- Multiple award winner.... http://www.26liter.us/gallery/albums/userpics/10087/0115091349-00.jpg http://www.26liter.us/gallery/albums/userpics/10087/0115091350-00.jpg Sully's SQ- winner of ugliest SQ at 07 Nationals which won a body refresh from me for materials only... http://www.26liter.us/gallery/albums/userpics/10087/houses_016.jpg Slowquest's SQ- http://www.26liter.us/gallery/albums/userpics/10087/1259593494_590e327341_o.jpg Tainter's car- from this.... http://www.26liter.us/gallery/albums/userpics/10087/DSCF0080.JPG to this... http://www.26liter.us/gallery/albums/userpics/10087/DSCF0063.JPG And of course, the wife's car... http://www.26liter.us/gallery/albums/userpics/10087/Picture_095.jpg Quote Link to comment Share on other sites More sharing options...
boogie Posted April 18, 2009 Report Share Posted April 18, 2009 Man you do some amazing work. Quote Link to comment Share on other sites More sharing options...
J_Copeland Posted April 18, 2009 Report Share Posted April 18, 2009 +1 Great work. I just need the cash and I'll be hooking up with you on my 1 owner 87. Quote Link to comment Share on other sites More sharing options...
rctraining Posted April 20, 2009 Report Share Posted April 20, 2009 damn, i would def pay you tomorow for a new paint job, haha too bad im in boston... Quote Link to comment Share on other sites More sharing options...
Big Al Posted April 20, 2009 Report Share Posted April 20, 2009 If I had another daily driver, I'd drop mine off and let you give it a good workover. Unfortunately all she needs bodywise is going to take longer to do than I have vaca time on the books I'm sure. Quote Link to comment Share on other sites More sharing options...
Burton Posted April 20, 2009 Author Report Share Posted April 20, 2009 For those of you saying you're too far away, I can help with that. I have another SQ owner who can help haul cars across the country and get them to me safely, at a fair price and with the love of a fellow SQ owner. You have no excuse now except money. The economy is bad now, but I'm also doing things for half or less what body shops charge, so if anything by having me do it you're saving money. And what's better in these tough economic times than saving money! Anyway, these prices may not be what they are forever. This is where I'm starting out, but once things pick up, my prices will go up along with the demand. A couple years from now, I may be charging body shop prices. Put those tax returns and stimulus checks to good use! Quote Link to comment Share on other sites More sharing options...
RWDAddict Posted April 20, 2009 Report Share Posted April 20, 2009 Just sent you a PM about a full restoration. I can have the black one to you next week if your guy spots a good shipping price so you can pace yourself on the job. More details in your PM. Talking a full bolt off restoration. :woot: Quote Link to comment Share on other sites More sharing options...
Burton Posted April 22, 2009 Author Report Share Posted April 22, 2009 OK, looks like I have a BIG resto coming up. In the meantime, I still can do some parts/pieces for y'all. Get em done now before my shop, demand for my services, and my hourly rate go up! Quote Link to comment Share on other sites More sharing options...
Burton Posted April 26, 2009 Author Report Share Posted April 26, 2009 TTT Quote Link to comment Share on other sites More sharing options...
Burton Posted April 28, 2009 Author Report Share Posted April 28, 2009 BUMP! Quote Link to comment Share on other sites More sharing options...
tim si Posted April 29, 2009 Report Share Posted April 29, 2009 burton,is there anything that can be done for the rear spoilers with the little swirl cracks.mine is coming back through the new paint Quote Link to comment Share on other sites More sharing options...
