1SICDSM Posted April 1, 2023 Report Share Posted April 1, 2023 stock engine,20g turbo,no balance shafts,tep valve springs,mechanical rocker head. Quote Link to comment Share on other sites More sharing options...
tux Posted April 2, 2023 Report Share Posted April 2, 2023 RPW i think it's the only option Quote Link to comment Share on other sites More sharing options...
kev Posted April 4, 2023 Report Share Posted April 4, 2023 Schneider 284F Quote Link to comment Share on other sites More sharing options...
1SICDSM Posted April 5, 2023 Author Report Share Posted April 5, 2023 (edited) my tep camshaft took a lobe off Edited April 5, 2023 by 1SICDSM Quote Link to comment Share on other sites More sharing options...
kev Posted April 6, 2023 Report Share Posted April 6, 2023 Are you sure you didn’t have one of your valve gaps too tight? If a valve were to hang open even the slightest bit, it wouldn’t take long to destroy a lobe. That’s a negative with mech lifters. Do you have the mechanical rocker shafts on there And not the oem hydraulic rocker shafts? tep cams have been pretty reliable over the years. I haven’t heard of many issues like this with their cams but you never know. there aren’t many options available anymore I’d suggest a Schneider 284f or go back with a stock cam for the time being Quote Link to comment Share on other sites More sharing options...
1SICDSM Posted April 7, 2023 Author Report Share Posted April 7, 2023 mechanical rocker shafts .its a minivan head.they were adjusted perfect.actually adjusted them like 5 times.they made more noise then anything ive ever heard.i spoke to schneider and im sending both the stock cam and tep cam to him to see if the ramps were incorrect. Quote Link to comment Share on other sites More sharing options...
Dad Posted April 18, 2023 Report Share Posted April 18, 2023 Zinc needs to be added to the oil to break in cam and rocker arms. Noisy usually means set too loose unless the cam is getting worn. Let us know what you find. Dad Quote Link to comment Share on other sites More sharing options...
1SICDSM Posted April 18, 2023 Author Report Share Posted April 18, 2023 i was running lucas hot rod oil with zinc.i had rockers adjusted properly.i actually adjusted multiple times then had my guru adjust them to make sure its not me.then i was going to adjust tight to see if noise gets better,then i found the camshaft was missing a lobe.also all the lobes had like pitting almost like air bubbles in the weld and regrind.the camshaft only has 600 miles on it.sent cams to schneider so i will see what they say. Quote Link to comment Share on other sites More sharing options...
