yousaveone Posted February 27, 2015 Report Share Posted February 27, 2015 My first car was a Conquest narrow with Voice. I drove it once and my parents sold it; I didn't have a license but couldn't resist. 20 some years later I picked up an 88 Starion. Not running. I have had it running and did a leak down. Bad compression to coolant between 2 and 3. A decked head, BSEK, ARP studs, and rebuilt turbo. It leaks worse then before. I'm thinking the head is cracked and ok with putting a new one on. What do you guys think? Quote Link to comment Share on other sites More sharing options...
Squrlsquash Posted February 27, 2015 Report Share Posted February 27, 2015 you had the head decked and it wasn't checked for cracks?give us some more info on how it was when you got it and what you've done so far diagnosing is hard to do over the internet, have to be specific so they sqc keyboard warriors can help you out best of luck Quote Link to comment Share on other sites More sharing options...
87redcat Posted February 27, 2015 Report Share Posted February 27, 2015 Congrats on your new baby. and Welcome aboard. any and all info helps...pics too Quote Link to comment Share on other sites More sharing options...
importwarrior Posted February 27, 2015 Report Share Posted February 27, 2015 yes the heads are known to crack between the valves.get a replacement fromhttp://www.enginemac...ms/conquest.php he is on here all the time and his name is Randy AKA DAD on this site. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted February 27, 2015 Report Share Posted February 27, 2015 some good reading http://www.starquestclub.com/forum/index.php?showtopic=66449 Quote Link to comment Share on other sites More sharing options...
Fuze Posted February 27, 2015 Report Share Posted February 27, 2015 Agreed, the head is the weak point. Sounds like it's cracked in the usual area unless something happened to your new head gasket while being installed or something.. Spring for a non-jet valve head and you should be in business, my guess at least. I got a nice head from Dad with some valve work, SS valves, HD springs, like a lot of people on here. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted February 27, 2015 Report Share Posted February 27, 2015 also make sure the radiator is in the best possible condition.if it is original get it cleaned - rodded out and or replaced withthe CX Racing unit. direct fit bolt on and uses stock fans.radiator might not be up to par. also fans are 25 years old andmight need to be checked as well. they may spin but might nothave as much torque to pull air like when they were new. http://www.ebay.com/...=mtr&rmvSB=true Quote Link to comment Share on other sites More sharing options...
mbruneaux Posted March 8, 2015 Report Share Posted March 8, 2015 (edited) Lalso make sure the radiator is in the best possible condition.if it is original get it cleaned - rodded out and or replaced withthe CX Racing unit. direct fit bolt on and uses stock fans.radiator might not be up to par. also fans are 25 years old andmight need to be checked as well. they may spin but might nothave as much torque to pull air like when they were new. http://www.ebay.com/...=mtr&rmvSB=true $1,300 ? Must be a typo they are usually about $200 - $300 Edited March 8, 2015 by mbruneaux Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted March 8, 2015 Report Share Posted March 8, 2015 Start taking pictures of the things you do so that we can see. LIke importwarrior said make sure the radiator is in the best condition it can be. Also check the thermo sensors and fans. All of theses were bad on my car. The head gasket failed for a reason which is most likely the car over heated. It the exhaust manifold cracked? by the number 4 cyclinder? For example, this was in my radiator: http://i1069.photobucket.com/albums/u467/tsi_tom/Radiator/DSC01571.jpg Crack in the cylinder head on this car http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Original%20Engine/Tear%20Down/G54B%20crack%20in%20head_zps5gtwhcqv.jpg Quote Link to comment Share on other sites More sharing options...
importwarrior Posted March 8, 2015 Report Share Posted March 8, 2015 Looks like the previous owner used rad stop leak. As far as head you need to probably get a new one from DaD On the site I linked to above. Quote Link to comment Share on other sites More sharing options...
