Left turn signal indicator doesn't indicate
tux
Has anyone run into this one? The left turn signal indicator doesn't illuminate. A new bulb was placed in but still no dice, tried swapping a bulb holder from the drivers side indicator, still no dice.
All turn signals do function and flashers do make their clickity clack noises.
Check the trace on the plastic circuit board on the back of the cluster. Mine burnt out somehow. If you find a break, scrape the green coating off a little where the break is and solder a chunk of wire to it.
Wierd,,,, mine did the same. and i repaired it the same. it has been 2 yrs and still holding........ ^_^
