88 Conquest TSi
93 GSX TURBO
  • Replies 152
  • Created
  • Last Reply
Top Posters In This Topic
How do you like it?
It's great man. No more wondering steering or having to constantly correct it. I just got done driving it and I got a chance to drive it on a straight flat road and just let go of the steering wheel and it tracked straight, I couldn't do that with old one.
  • 3 weeks later...
Still working on some little things. Im still having an issue with the wipers not stopping and its looking like the ETACS is bad. I went ahead remove dthe wiper motor and cleaned it out anyways.
Crazy filthy
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zps5rqaccrz.jpg
This bearing was almost seized, so I soaked it with PB Blaster and now it spins like new.
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpscbujfbcm.jpg
I could not find a replacement steering wheel so I picked one up from Plymouth Laser.
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpslqzvxz1h.jpg
I decided to add a little touch to it with the TSI logo.
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpstdwhqzv9.jpg
  • 2 weeks later...
Wow this has come along nicely
It has been a long process. I originally bought this car for myself, and then my dad got to liking it so I decided to build as gift for him (he is 69). I finally handed over the keys to him Saturday for the first time. Theres a little bit more work that needs to be done but its good for now. After he got home from his Sunday drive he asked what we could do to add more power. :)
Edited by 93 GSX TURBO
Took advantage of the nice weather to get some work done on the car today.
I jnstalled the GFB MBC and set at 11psi.
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsltg1yhpx.jpg
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpssttta8ae.jpg
  • 1 month later...
Rented a rug doctor this morning and got to work on the interior. This really helped with funky smell the car had from sitting for so long when I first bought it.
Getting it all ready
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsdrmhpvhh.jpg
Here a couple before pics
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zps91ptwfbj.jpg
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsbddab8l6.jpg
Getting to work with it
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpswgz6orya.jpg
Heres a shot of the nasty water after finishing up
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpszcxh0waq.jpg
Letting it air out
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsuvvmi9vz.jpg
Clean seats and that bacteria and dirt gone now
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsde9fy0j8.jpg
Even did the door panels
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsyfvio2lz.jpg
After I got finished with that I adjusted the OD Band
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zps3rd1b26f.jpg
The adjustment wasn't too far off but it correct the OD shift
  • 1 month later...
This happened to the car 4 weeks ago.
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsq8irhw6i.jpg
A car I just bought was being dropped off and well, things happen I guess. I should be getting it back sometime this week and hopefully in the same condition that it was in before the mishap.
  • 3 weeks later...
It's been hot as all hell around here lately to I decided to work on the A/C.
Started by checking and blowing out the drain hose under the carpet, it was clear but I guess it's good to check. Started by replacing the bad A/C pressure switch:
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsttqxprzw.jpg
The new switch
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsuokrsfn8.jpg
Switch installed
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsqxezmdjj.jpg
Also replaced the drier. Also replaced about 8 different seals
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsspq3jte2.jpg
The retrofit kit installed
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpspd5adrsx.jpg
This was the temp in the car before starting. Outside it was around 97
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zps5porgsvi.jpg
Got the manifold and pump hooked up
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpscnwihtgd.jpg
Put in 24oz of R134 and 3oz of oil
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsmbftx7hh.jpg
The temp after getting it all charged up. Its blurry but its around 50-52 degrees
http://i724.photobucket.com/albums/ww244/partsturbo/Mobile%20Uploads/image_zpsdkyi7reh.jpg
Great stuff on the AC. Love the pictures too! I need to do this because it is hot as hell around here too. Where did you get the drier and the vacuum pump and gauges?
I got te drier and switch from RockAuto.
The vacuum pump and gauges I got from Harbor Freight. It's the 100 dollar an pump, I think the smallest in their line up. I let it pull vacuum for around 30min. I've used this combo on five different cars so it's paid for itself a couple times over already. Just make sure to tighten up all the fittings on the manifold gauges before you use it, but other than that it's worked like a champ.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
