TexasQuest Posted August 17, 2013 Report Share Posted August 17, 2013 Is there anywhere on the firewall I can run a boost gauge line thru? I really don't want to drill a hole and put a grommet if I don't have to. Link to comment Share on other sites More sharing options...
Speedy2222 Posted August 17, 2013 Report Share Posted August 17, 2013 i ran mine through where the speedo cable goes through if i remember correctly, think i jammed a screw driver thru to make a start than fed the line through. Link to comment Share on other sites More sharing options...
speedyquest Posted August 17, 2013 Report Share Posted August 17, 2013 You are not going to find an "easy" place to run it through sadly. Your best best is to find an already present grommet and feed your vac line through there. But be wary to not have it get pinched. Allen Link to comment Share on other sites More sharing options...
TexasQuest Posted August 17, 2013 Author Report Share Posted August 17, 2013 What grommet would you recommend running it thru? Link to comment Share on other sites More sharing options...
button Posted August 17, 2013 Report Share Posted August 17, 2013 poke a hole in the heater core grommet if you are using the hard type small line.if you are using squishy line, get the harder line, because the squishy stuff will collapse during vacuum and may stay squished, especially if it is ran near something hot. Link to comment Share on other sites More sharing options...
aknorthstar Posted August 18, 2013 Report Share Posted August 18, 2013 (edited) If you removed the a/c unit inside you can use the bolt hole or thru the plug http://i614.photobucket.com/albums/tt230/gguy84/DSCN1119_zpsbb51e3ce.jpg Edited August 18, 2013 by aknorthstar Link to comment Share on other sites More sharing options...
TexasQuest Posted August 18, 2013 Author Report Share Posted August 18, 2013 LOL that's a picture of my car from the a/c evaporator how to. I'm gonna use that hole for the wideband since it's near the exhaust. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted August 19, 2013 Report Share Posted August 19, 2013 I ran nearly all of my MPI wiring through there. Link to comment Share on other sites More sharing options...
jszucs Posted August 23, 2013 Report Share Posted August 23, 2013 You could pretty easy run it down the hole in the fender well too. Link to comment Share on other sites More sharing options...
joey_crandall Posted September 21, 2013 Report Share Posted September 21, 2013 The bracket for the cruise control cable on the fire wall, the bolt hole goes into the cabin, that's where I ran mine through Link to comment Share on other sites More sharing options...
TexasQuest Posted September 22, 2013 Author Report Share Posted September 22, 2013 I ended up running it thru the hole next to the firewall plug that is pictured. I had enough vacuum line to run it all the way around. Link to comment Share on other sites More sharing options...
