TougeWarrior88 Posted August 9, 2013 Report Share Posted August 9, 2013 so i drove my 88 sq this morning she was fine. then in the afternoon i drove her again my brake pedal became stiff after the first stop. then it became regular again so on and so forth. i was wondering if anyone had this happen to better help me pinpoint my problem. shes my daily driver so i need to find problem and fix within a days worth of work hopefully on saturday night or sunday. i checked my lines they seem fine no disconnection by the way. thanks!! Link to comment Share on other sites More sharing options...
BC_99 Posted August 9, 2013 Report Share Posted August 9, 2013 Did the brakes seem to stay engaged after the first stop? took awhile for the pressure to release? BC_99 1 Link to comment Share on other sites More sharing options...
TougeWarrior88 Posted August 9, 2013 Author Report Share Posted August 9, 2013 Did the brakes seem to stay engaged after the first stop? took awhile for the pressure to release? BC_99 The first stop was normal then after that the pedal became stiff and would only press in about a quarter of the way, slowing down was harder. i would pump it then next stop would be normal again. but it seemed to happen randomly. Link to comment Share on other sites More sharing options...
importwarrior Posted August 9, 2013 Report Share Posted August 9, 2013 (edited) becareful it sounds like a long shot but the ABS mightbe stuck in the on position. that was a common problemin the s10 blazers pedal got real stiff and the brakes tookallot to get them to work. Edited August 9, 2013 by importwarrior 1 Link to comment Share on other sites More sharing options...
TougeWarrior88 Posted August 9, 2013 Author Report Share Posted August 9, 2013 becareful it sounds like a long shot but the ABS mightbe stuck in the on position. that was a common problemin the s10 blazers pedal got real stiff and the brakes tookallot to get them to work. ABS was deleted but i know what your talking about Link to comment Share on other sites More sharing options...
scott87star Posted August 9, 2013 Report Share Posted August 9, 2013 Brake booster, check it for leaks (vacuum leaks) and check the hose going to the intake plus the check valve. 1 Link to comment Share on other sites More sharing options...
TougeWarrior88 Posted August 9, 2013 Author Report Share Posted August 9, 2013 Brake booster, check it for leaks (vacuum leaks) and check the hose going to the intake plus the check valve.I was thinking the same. brake booster. but i dont wanna replace just like that. last this happened i ran my car hard then a vacuum line that went from the booster to engine came off and the pedal felt the same way. but this time no vacuum lines are unplugged. Link to comment Share on other sites More sharing options...
scott87star Posted August 9, 2013 Report Share Posted August 9, 2013 You need to somehow pull a vacuum on the booster and see if it holds. A Mighty-vac works but a real vacuum pump and gauge is better. 1 Link to comment Share on other sites More sharing options...
2fast2six Posted August 9, 2013 Report Share Posted August 9, 2013 HAD SAME ISSUE. BRAKE BOOSTER was FILLED with brake fluid lol 1 Link to comment Share on other sites More sharing options...
TougeWarrior88 Posted August 9, 2013 Author Report Share Posted August 9, 2013 thanks for al lthe help guys i will try all that when i get home! Link to comment Share on other sites More sharing options...
Shelby Posted August 11, 2013 Report Share Posted August 11, 2013 being full of brake fluid may not mean it's dead,, replace master cyl if nessarry and then suck the brake fluid out of the booster assy , most will live again Link to comment Share on other sites More sharing options...
