Quest 4 MPI
I've been mulling the idea over of getting a cheap android tablet for tuning purposes, but I'm worried that if I have a problem, I wouldn't have a computer nearby to troubleshoot via usb to serial port adapter. I'll most likely end up with a small netbook stored in the car for tuning purposes with a 12V car charger.
I'm sure there is a way to setup bluetooth to communicate with ms just like a serial port using the rs 232 to bluetooth adapter. One of these days I find some time to play around with it. may require some third party program but there must be a way. I'm currently using shadowlogger too
Im running 1.25" Wheel Adaptors from Adapt-IT-USA its a 5x144.3 to 5x120 to fit the old school BBS's
http://i1063.photobucket.com/albums/t508/jabbottonline/375072_10151466390929401_1632994645_n_zpsaf6aa543.jpg
What size are your tires?
PS you need these caps :)
http://store.blackfo...srelocafor.html
http://www.r3vlimited.com/board/attachment.php?attachmentid=59520&stc=1&d=1346158345
Edited by RonnieJ
  • 3 weeks later...
Teaser from Sat :P
http://jdlautodesign.net/wp-content/uploads/2013/05/SQ-Holset-and-Gates.jpg
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Top-Mount_1.jpg
Looking good ronnie keep up the good work.
On a side note the head showed up today and it looks great
It has 3.3l beehive springs and ls retainers i dont think anyone had run this setup on a g54b head before so im testing the waters here
Moar. Bandsaw blade bent so off to get a new one in the AM
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Topmounttttt_3.jpg
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Topmounttttt_1.jpg
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Topmounttttt_2.jpg
M28 njv head ported by Ed Kelly 3.3L turbo dodge springs and LS retainers
http://i1063.photobucket.com/albums/t508/jabbottonline/971200_10151515057904401_1876283051_n_zps8c4d3912.jpg
http://i1063.photobucket.com/albums/t508/jabbottonline/971042_10151515057279401_1393553830_n_zpsae299b09.jpg
http://i1063.photobucket.com/albums/t508/jabbottonline/969701_10151515058389401_462538233_n_zpsb349653b.jpg
http://i1063.photobucket.com/albums/t508/jabbottonline/397382_10151515057999401_91363959_n_zps9d2eb286.jpg
http://i1063.photobucket.com/albums/t508/jabbottonline/181275_10151515057579401_385686656_n_zps9eac8746.jpg
Working on the gates and dumps
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Hot-Parts-_1.jpg
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Hot-Parts-_2.jpg
Everything is done and getting welded. Here is a gate shot from ealier
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Hot-Parts-_3.jpg
Nice!!!! That's beautiful work.
Might have to jump on the bandwagon. How long does one take after the order?
We are pretty busy at the moment. Shoot me a PM and ill see what we can do
Down Pipe and Dump tubes finished up
http://i1063.photobucket.com/albums/t508/jabbottonline/StarQuest-Hot-Partsssss_1_zpsdba47c26.jpg
http://i1063.photobucket.com/albums/t508/jabbottonline/StarQuest-Hot-Partsssss_zps120759ca.jpg
Why does the porting look like sandpaper rather than silk? Or is it a camera angle?
A little rough is acctually better on the intake side supposedly it will mix the fuel and air better. however the exauhst side should be smooth as possible (as far as i know). Either way flow bench resaults have proven a little rough give better resaults than smooth.
Mike
Yeah I was surprised by the grit on the port as well and i looked into it and this was the best explanation i could find
"There is also the issue of "surface boundary layer." Air is sticky. It likes to stick to itself and it also sticks to other materials. With a smooth surface that creates little turbulence the air flowing along the surface of the tube tends to stick to it and slow down . It also sticks to other air flowing by and slows it down creating a gradual transition from the slowest air next to the surface toward the fastest air in the center of the tube. A rough surface can create a thin layer of turbulence just above the surface of the tube. This tends to create a sharp transition between the totally chaotic air next to the surface and the rest of the air that flows through the tube relatively unhindered. The effect is to increase the overall average velocity of air that does flow through the tube. However, the boundary layer reduces the effective cross-section of the tube and, thereby, the total effective volume."
Collector and runners welded just didnt get too many pics today. Crazy busy at the shop. Will have it all done and ported tomorrow
http://jdlautodesign.net/wp-content/uploads/2013/05/StarQuest-Collector.jpg
Haven't gotten to making it yet i want the motor in the car so i can length check all my wires for my harness. Motor should be done this weekend hopefully, then all that's felt is wiring it up and it will be ready to go.
Nice looks good ronnie cant wait to get it on the car.
Got my motor back together just gotta throw on the timing stuff and she will be good to go
http://i1063.photobucket.com/albums/t508/jabbottonline/936150_10151528671604401_431855501_n_zps7190abef.jpg
http://i1063.photobucket.com/albums/t508/jabbottonline/7798_10151528671434401_75299536_n_zps97a68b05.jpg
All ported
http://jdlautodesign.net/wp-content/uploads/2013/06/StarQuest-Top-Mount-Div.jpg
Ready to roll. Hurry up fedex :)
http://jdlautodesign.net/wp-content/uploads/2013/06/StarQuest-Top-Mount-Div-Kit-Boxed.jpg
