quickStarion
Everything posted by quickStarion
Yesterday was a beautiful day, UNTIL...
quickStarion replied to kidjc's topic in Just plain ol' B.S.
Thread is useless with out pics also Too long didn't read. -
Oh yeah what words are misspelled exactly? I don't think you know how to spell exactly. And second of I'm am just trying to prove a point using facts. No trying to sound smart, just spoke of what exactly is done there. Spoke to plenty of friends to get the gist of boot camp. They teach you how to become a good little drone while making you think you are being creative. I have never tried to get in and have no bitterness. Why? Because I went to school and college to get an education.
LOTS of parts for sale! Aftermarket, OEM and 87 SQ part-out
quickStarion replied to ShadowTSi's topic in Parts for sale
Pm'd you about the headlights again.- 36 replies
I have 3 sets of 86 injectors, I would ideally like 90shipped a set.
Free Starion and Conquest parts from Singapore.
quickStarion replied to lester's topic in Parts for sale
Pm'd on that too. -
Carquest sells fusible link wire. Buy that and on connectors Then get a guage of fusible like 2 guages down from the wire you are protecting, so for a brown link you would need 16 guage fusible link wire. A Brown fusible link is used to protect an 18ga wire. A Green fusible link is used to protect a 16ga wire. A Red fusible link is used to protect a 14ga wire. A Black fusible link is used to protect a 12ga wire.
http://www.jdmeuro.com/cst-precedeo-demon-camber-mitsubishi-starion/
So you learned how to use a tool that has no application outside the military sounds great. Also those who wouldn't conform mentally to being told what to think and having no opinions of their own were weeded out, sounds even better. That state of mind is having a blank mind doing what you are told and what your state of mind is. Those who choose not to submit to deindividuation are deemed not good enough because they make creating cognitive dissonance harder for the military leaders. So if you want to make sweating your tail off in a humvee while some dude yells at you or sweating your tail of while you run around while some dude yells at you, sound like the best time of your life go ahead, but I'm not drinking the coolaid.
Can a collapsed lifter cause engine vibration?
quickStarion replied to quickStarion's topic in Just plain ol' B.S.
It was the top tranny/engine bolts rattled loose, thanks for your help everybody. -
I am running stock catch can setup. And I just rebuilt my motor like 900 miles ago. Maybe my rings haven't seated because I used chromoly.
I am getting clouds of smoke smells like oil of varying intensity out of the exhaust on deceleration while in gear. I am thinking that my PCV or Catch Can need to be replace/cleaned? My valve stem seals are brand new, unless I installed them wrong or mashed them?
You should have someone in the us receive parts for you and ship them out in big bundles.
I already PM'd on those last night. -
I mean not really pass rate for Marine bootcamp is 90%-95% which is pretty much the majority of those who enlist, pass.
How would I check the looseness? Prybar? -
Bad or unbalanced. Mine also has no dowel pin. -
When I bled them a year ago one had a lot of play and was really loose. I also am running a second hand fidanza what is flywheel vibration like? -
Yeah but I push the clutch pedal in which disengages and takes the input shaft out of the situation. I think a lifter is down. -
Why fourth? And it does it not in gear. I did also replace the input shaft SEAL. -
Filled it though the shifter 1 day 20miles ago until the side fill hole leaked. Plus it happens when trans is in neutral and the clutch is pressed in. Used stalube gl4 85w-90 -
It happened suddenly after a acceleration run from 20-60mph. Just manual swapped the car. Poly trans mount engine mounts wouldn't just become that noticeable. Balance shafts eliminated. No new plugs or anything car ran fine for 20miles after swap. I've had some lifter tick before I didn't take care of because focused on other things. Kind of sounds close to rod knock could maybe be a miss, but goes away after 2.5k and no metal in the oil and oil pressure is good. Knock sensor is unplugged. The plug got ripped. What does a flywheel out of balance feel like? -
I have a vibration from 1200rpm-2400 or so, then it gets less pronounced. It is very noticeable in that rpm range and I can feel it in the chassis and through the shifter. Its there when the clutch is in and out, both idling and moving, so I know know its not the rear end, driveshaft, or tranny. Its somewhere in the engine or flywheel.
wow that is all useless stuff then. besides the flywheel. Offer him 150 max and walk away.
That's how I like my dog and gator cooked.
