Lizzord30 Posted June 3, 2012 Report Share Posted June 3, 2012 I have been trying to get my starter to work well but its been pretty intermentently working and not. Sometimes will work fine and other times just click and not do anything. But I figured when I add a power from the starter to the battry (the small wire) that it will always work. But even when Its not working the starter does get a signal power, but i would guess its not getting enof amps. What do you guys think the problem could be? and how to fix it! Thanks!! Link to comment Share on other sites More sharing options...
vbrad511 Posted June 3, 2012 Report Share Posted June 3, 2012 The contacts may be mucked up or burnt in your ignition switch. They're easy to remove and disassemble, but if you decide to tackle it remove it from the car and do it on a clean bench and take note of how it comes apart. It's the white portion of the switch, just takes a small phillips to separate it from the key cylinder. Link to comment Share on other sites More sharing options...
jason c Posted June 3, 2012 Report Share Posted June 3, 2012 mine has the same problem been trying to track it down, ill clean the contact and seems to work fine for 5 or 6 starts then click click then it eventully turns Link to comment Share on other sites More sharing options...
The Rabbit1 Posted June 3, 2012 Report Share Posted June 3, 2012 if it's auto then it's probably the neutral safety switch. when it doesn't want to start at the switch put it in neutral and see if it starts right up Link to comment Share on other sites More sharing options...
Tim_C. Posted June 3, 2012 Report Share Posted June 3, 2012 Bad battery grounds, or the big positive wire to the starter is corroded.Internal starter issue drawing too many amps.Could be a burned fuse link, or a bad fuse link connection too. Even a partially burned link will conduct something. Link to comment Share on other sites More sharing options...
Lizzord30 Posted June 4, 2012 Author Report Share Posted June 4, 2012 Bad battery grounds, or the big positive wire to the starter is corroded.Internal starter issue drawing too many amps.Could be a burned fuse link, or a bad fuse link connection too. Even a partially burned link will conduct something.Thanks I will look into that info, kinda make since becuse it gets power but just must have too much resistance, but like you said sometimes it will conduct. Link to comment Share on other sites More sharing options...
psu_Crash Posted June 4, 2012 Report Share Posted June 4, 2012 Mine acted like that when the spade connector to the starter solenoid was loose. Might want to check that out first. Link to comment Share on other sites More sharing options...
The Rabbit1 Posted June 4, 2012 Report Share Posted June 4, 2012 Mine acted like that when the spade connector to the starter solenoid was loose. Might want to check that out first.oil tends to drip on the connection also, may be the culprit Link to comment Share on other sites More sharing options...
Starfighterpilot Posted June 4, 2012 Report Share Posted June 4, 2012 If you think that your ignition switch is FUBAR then order a new one from Mitsu - they are still available. For the ignition switch Mitsu part number search thru the '88 Mitsu parts catalog. For What It's Worth. KEN Link to comment Share on other sites More sharing options...
Lizzord30 Posted June 7, 2012 Author Report Share Posted June 7, 2012 Well Replaced the ign switch and the switch works better feels more tight and had some wires that where bear fixed but didnt change the starting issue. I half fixed the Issue by using the wire that goes to the starter to trigger a relay that had direct battery power and hasnt clicked since, but I think I have a flex plate spacing issue since it still sometimes will grind but at lest it doesnt click lol. Link to comment Share on other sites More sharing options...
nycain Posted June 11, 2012 Report Share Posted June 11, 2012 (edited) i had this problem for so long on my first car , was so frustrating , the problem is not the starter or the ignition switch . first look at your fusable links if they r corroded r burnt , look at the wires , look at the one that says EGSW that means ingnition switch its the red wire in the connector .it might b burnt r no good ,it tend to get hot and melt in the connector , the wire might look good but its burnt on the inside.just pry it out and replace the wire . some car comes with the xtra red wire in the fusable links box some dont you can just replace it from the clip and the battery . {i changed starter , ignition switch and still had the problem until i chase the wires and found the problem}http://i1146.photobucket.com/albums/o538/nycain/IMG_20120530_160827.jpg Edited June 11, 2012 by nycain Link to comment Share on other sites More sharing options...
