Indiana Posted April 11, 2012 Report Share Posted April 11, 2012 Pull the valve cover and see if you have a dying/dead lifter or a screw that is backing off and moving in/out. The jam nut will be loose and the screw can also chew up the valve cover. A jet valve couldn't have caused this. A dead WG actuator won't allow the flapper to open and you'll have lots of boost. A loose one it won't make boost. A dead turbo it won't rev up and will overheat quickly. A dead mechanical advance on your distributor might cause this but I doubt that's it. A major crack in a manifold or blown out exhaust manifold or turbine housig gasket. When its cold it won't boost but after its heated up and the parts expand it might make some boost. Link to comment Share on other sites More sharing options...
lionbull Posted April 11, 2012 Report Share Posted April 11, 2012 sounds like you have leak before the turbo, but could be something mechanical. Time to start the process of elimination Link to comment Share on other sites More sharing options...
jszucs Posted April 11, 2012 Report Share Posted April 11, 2012 How does both wheels of the turbo look? Shaft play side side in out? Link to comment Share on other sites More sharing options...
ultraflexxj Posted April 11, 2012 Author Report Share Posted April 11, 2012 (edited) intake side looks fine havent had the time to check the exhaust side and as for the leak before the turbo no cracks in the mani or gaskets blown. its not just when its cold its erratic it is both when its cold and hot. Edited April 11, 2012 by ultraflexxj Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted April 12, 2012 Report Share Posted April 12, 2012 Be sure to check the vacuum advance and the vacuum line attached to it. Also, check your injector clips. Link to comment Share on other sites More sharing options...
ultraflexxj Posted April 12, 2012 Author Report Share Posted April 12, 2012 new injector clips all vacuum lines are new. started investigating tonight since its not raining and started wiggling the exhaust around and i think i found out the problem it sounds like i got rocks in the exhaust pipe meaning my cat blew up probably causing an exhaust restriction Link to comment Share on other sites More sharing options...
Technology Posted April 12, 2012 Report Share Posted April 12, 2012 If it's the cats, it should be easy to remove at least Link to comment Share on other sites More sharing options...
ultraflexxj Posted April 12, 2012 Author Report Share Posted April 12, 2012 only got the down stream cat so really easy especially since i had the exhaust shop weld in flanges on the cat Link to comment Share on other sites More sharing options...
Indiana Posted April 12, 2012 Report Share Posted April 12, 2012 Call Animal Control in the morning. Have that smelly Cat removed. Link to comment Share on other sites More sharing options...
