Everything posted by ultraflexxj
do you have a spare 88/89 ingition box
i am about ready to get this set up unless there is negative feed back on it http://jdlautodesign.net/shop/starion-conquest-top-mount/
am running into major issues with the stock holset waste gate i can not get it to clear the power steering reservoir and vacuum reservoir
No it won't
issues with clearance for waist gate actuator with stock holset actuator
thanks phil thats the turbo im going to run did you have to clock the exhaust houseing
has anyone here used them and or heard any problems with them? hear is the one im looking at http://www.amazon.com/Godspeed-Turbo-Conversion-Adaptor-Flange/dp/B005GQN5M8/ref=sr_1_4?s=automotive&ie=UTF8&qid=1373824134&sr=1-4&keywords=td05+turbo+adapter
dred are you running an oil ristictor
i ended up getting a gated hx35w
How well does it spool
Dred can I see some pics of your set up I just got an hx35w
i found an off brand hx35 for sale locally for cheap and get an adapter
i called mike turbo they said 375+
has anyone on the form run a holset hx40w
tonight the rubber ring around the intake some how ended up going through the intake of my turbo destroying my 18g fp turbo. im starting think i wasn't ment to have a starquest first my engine took a s*** with the je pistons now my turbo took a s*** whats worse is i dont have the money to fix it and its my dd
no spark after car warms up 88 quest
ultraflexxj replied to ultraflexxj's topic in Advanced Virtual Mechanic
only problem is my tack doesnt work now -
switched it out for my msd 6al box with an 8920 adapter -
damn my knock box is R.I.P. -
all the wiring and connectors look good -
Voltage stays the same the ground is what stops triggering -
Yes
