JayR_NYC Posted August 28, 2010 Report Share Posted August 28, 2010 AFTERMARKET ALUMINUIM RADIATOR CAN I BUY THAT WILL FIT MY STARION AND NOT THAT EXPENSIVE?????? Link to comment Share on other sites More sharing options...
TexasQuest Posted August 28, 2010 Report Share Posted August 28, 2010 Cheapest route is one from somewhere like Jeg's for a small block chevy. Of course you'll have to modify it to fit. Link to comment Share on other sites More sharing options...
JayR_NYC Posted August 28, 2010 Author Report Share Posted August 28, 2010 Cheapest route is one from somewhere like Jeg's for a small block chevy. Of course you'll have to modify it to fit.GOT THE DIAMETER OF OUR RADIATOR... 15.75x25.5x1.25...EVERYTHING 19 IN LENGHT..AND 2.25 THICKER Link to comment Share on other sites More sharing options...
Scotty Dont Posted August 29, 2010 Report Share Posted August 29, 2010 Sr20 radiator for a 240sx, they are all over ebay just check the dimensions (they fit) Link to comment Share on other sites More sharing options...
JayR_NYC Posted August 29, 2010 Author Report Share Posted August 29, 2010 Sr20 radiator for a 240sx, they are all over ebay just check the dimensions (they fit)SCOTTY...i want an aluminuim radiator Link to comment Share on other sites More sharing options...
JayR_NYC Posted August 29, 2010 Author Report Share Posted August 29, 2010 Sr20 radiator for a 240sx, they are all over ebay just check the dimensions (they fit)wow..Scotty..i found one for $119.00 shipped from a 240sx...WOW...thanx Link to comment Share on other sites More sharing options...
MoltoMario Posted August 29, 2010 Report Share Posted August 29, 2010 You can also try a summit racing one. I know Jason had one in his truck and it worked fine. But I sure the truck radiator dimensions are different then a SQ's Link to comment Share on other sites More sharing options...
Cobalt60 Posted August 29, 2010 Report Share Posted August 29, 2010 ...the truck radiator dimensions are different then a SQ's they are very different. Not as wide, but taller. Link to comment Share on other sites More sharing options...
Scotty Dont Posted August 29, 2010 Report Share Posted August 29, 2010 You can also try a summit racing one. I know Jason had one in his truck and it worked fine. But I sure the truck radiator dimensions are different then a SQ's The summit radiator are very thick and I did not like the build quality compared to the sr20 rad Link to comment Share on other sites More sharing options...
slowspyder Posted August 29, 2010 Report Share Posted August 29, 2010 Sr20 radiator for a 240sx, they are all over ebay just check the dimensions (they fit) Hey scotty, do you have this radiator installed in you car? I like to see pics if you do Link to comment Share on other sites More sharing options...
Scotty Dont Posted August 29, 2010 Report Share Posted August 29, 2010 (edited) Hey scotty, do you have this radiator installed in you car? I like to see pics if you do I'm actually ordering mine this week but dstar88 (a local member) has one in his car. heres a link to that radiator. with a little bit of modding, it fits perfect. And has been working perfect so far. http://cgi.ebay.com/...RK%3AMEWNX%3AIT Daniel Edited August 29, 2010 by Scotty Dont Link to comment Share on other sites More sharing options...
dstar88 Posted August 29, 2010 Report Share Posted August 29, 2010 Still no complaints on it yet. Ill try to snap some pictures of it when I get a chance. Theres a little bit that you have to do To make it a true bolt in, but so far everything was well worth it. Daniel Link to comment Share on other sites More sharing options...
Dave-O Posted August 29, 2010 Report Share Posted August 29, 2010 yokomosQUEST has a Nissan SR20 aluminum radiator [from eBay] in his 1UZ-swapped car. http://www.starquestclub.com/forum/index.php?showtopic=98849&view=findpost&p=1057116 http://i122.photobucket.com/albums/o249/yokomo99/red%20car%20related/Photo1038.jpg http://i122.photobucket.com/albums/o249/yokomo99/red%20car%20related/Photo1042.jpg If anyone is worried about durability, I've seen the CXRacing [eBay brand] radiators on almost every SR-powered 240sx in Cali and Vegas drift events, and even sliding around at full-tilt in 110* weather, nobody's overheated due to a radiator issue, and nobody has had any failures. For what it's worth. Link to comment Share on other sites More sharing options...
garychoffmann Posted August 29, 2010 Report Share Posted August 29, 2010 I have a summit radiator. Unfortunately the frame rails had to be notched and welded for it to fit. SR is probably the way to go Link to comment Share on other sites More sharing options...
dstar88 Posted September 1, 2010 Report Share Posted September 1, 2010 heres the pictures of it in my car. I modded the lower radiator spout to look identical to the stock one, that way i wont have to worry about getting a different lower hose. the upper hose worked as well, it just needed to be cut shorter a bit to keep it from kinking. from the top:http://i636.photobucket.com/albums/uu89/daniels_zx6/2010-08-30112632.jpg pic of one of the side mounting brackets that we made up, just basically drilled two holes on the side of the radiator (theres a rail that goes down both sides that has some metal that sticks out about a quarter inch or so), lined it up with the stock location and bolted it down. :http://i636.photobucket.com/albums/uu89/daniels_zx6/2010-08-30112654.jpg heres a look at the bottom, we made an extra support to sit on top of the old radiator lower support since this one is not round, It wont sit in there. And we didnt want it to scrape on it(as a "just in case it moves" precaution). Then bent the end up so that it cant slide out twards the engine (another "just in case" precaution). So now it sits on a flat surface, instead of a.....what ever thats lower support would be called..lol:http://i636.photobucket.com/albums/uu89/daniels_zx6/2010-08-30112756.jpg and a closer picture of the modded lower radiator spout, that lower hose fit like a glove!: http://i636.photobucket.com/albums/uu89/daniels_zx6/2010-08-30112852-1.jpg Daniel Link to comment Share on other sites More sharing options...
importwarrior Posted September 1, 2010 Report Share Posted September 1, 2010 i do not see any radiator ground sensors for the fans. how did you ground the fans? Link to comment Share on other sites More sharing options...
ucw458 Posted September 1, 2010 Report Share Posted September 1, 2010 i do not see any radiator ground sensors for the fans. how did you ground the fans? easily, just 4 simple steps 1 dig hole2 throw fans into hole34 profit Link to comment Share on other sites More sharing options...
Scotty Dont Posted September 1, 2010 Report Share Posted September 1, 2010 i do not see any radiator ground sensors for the fans. how did you ground the fans? Dstar removed the egr thermovalve and stuck the stock primary thermoswitch there. Link to comment Share on other sites More sharing options...
dstar88 Posted September 1, 2010 Report Share Posted September 1, 2010 Dstar removed the egr thermovalve and stuck the stock primary thermoswitch there. Yup! Thanks Scotty. Forgot to add that part. since i need to get that thermo valve back in there eventually. I want to try to find a smaller temp sensor for the fans that can go into the thermostat housing. I figured since i dont have a A/C no more in the car. I can use that spot for the fan switch. or maybe just drill and re-tap the hole to accept the bigger stock temp sensor. Daniel Link to comment Share on other sites More sharing options...
Skullzaflare Posted September 1, 2010 Report Share Posted September 1, 2010 any modifications needed for the sr20 aluminum radiator to fit? (ignoring hoses and mounts) Link to comment Share on other sites More sharing options...
Scotty Dont Posted September 1, 2010 Report Share Posted September 1, 2010 any modifications needed for the sr20 aluminum radiator to fit? (ignoring hoses and mounts) Buy it a figure it out, people on this site get tired of having to hold everyones hands threw every single thing. Sorry for being a d*** but Dstar88 JUST POSTED a how to of installing it. The new and some older member seem like they cant do a damn thing with being told EXACTLY how to do everything. Link to comment Share on other sites More sharing options...
Skullzaflare Posted September 1, 2010 Report Share Posted September 1, 2010 Buy it a figure it out, people on this site get tired of having to hold everyones hands threw every single thing. Sorry for being a d*** but Dstar88 JUST POSTED a how to of installing it. The new and some older member seem like they cant do a damn thing with being told EXACTLY how to do everything.wel sorry mr grumpy, i forgot he posted a link to a thread after i searched ebay for the radiatorbesides that, all i asked was for a yes or no, does it require modifying the car Link to comment Share on other sites More sharing options...
dstar88 Posted September 1, 2010 Report Share Posted September 1, 2010 no, you dont need to modify anything in the car. you just have to mod the radiator. this sr20 radiator is a little bit wider and not as tall as the stock radiator, but the specs in length are practically the same. If you go back and look at the pictures and compare it to a picture with a stock radiator in it. you will see that the stock rad is a little taller. And this Radiator will be practically flush with the front support and a little wider in girth(going towards the engine). the only problem that i noticed is the drain plug area...when you drop the radiator in, that plug is practically placed right on top of the driver side frame rail..That was a big OPPS when we finished installing it. what i should have done is get that plugged up and move the plug twards the middle of the radiator, so it can be drained easily. Now i have to sort of make a mess to get the radiator drained..but im ok with that....sorta...for now. I still wouldnt consider it as having to modify anything to the car to get the radiator to fit...Unless you want to drill a hole in the frame rail instead of relocate the drain plug. I can take some pictures of that as well if you want, and post them up, so you can see what im talking about...if it makes it easier to understand. also keep in mind that i have the MK1 crank pully with trigger wheel, and the fans used are i believe 2 12" flexi light fans. And yet, i still have a substantial amount of room between the fans and the trigger pully with triger wheel. hopefully this info helps Daniel Link to comment Share on other sites More sharing options...
Skullzaflare Posted September 1, 2010 Report Share Posted September 1, 2010 this sr20 radiator is a little bit wider and not as tall as the stock radiator... the only problem that i noticed is the drain plug area..... hopefully this info helps Danielthat it does. so it does just drop in, no need to alter frame? the drainplug doesnt bother me as my car isnt a show car Link to comment Share on other sites More sharing options...
dstar88 Posted September 1, 2010 Report Share Posted September 1, 2010 yup, drops right in. Daniel Link to comment Share on other sites More sharing options...
