slowspyder
Everything posted by slowspyder
I need a crank pulley and a power steering pump pulley shipped to los angeles CA
I need a good crank pulley and a power steering pulley preferrably out of either the 88 or the 89
The thermostat will start to open at what its rated at. It fully opens about 20 degs above what its rated at. So a 192 deg thermostat begins to open at 192 and fully opens at 212.
A/c override switch
skillz and scottygibbs new smb headers
slowspyder replied to S.M.B's topic in Engine and Performance Mods
Whats the thickness of the pipes? Id be careful about about bolting a bracket from that header to the motor mount. While the manifolds gonna expand and contract, the part attached to the motor mount wont as much. Eventually somethings gonna break and its probably going to be that plate with the bolt. -
Good guy to deal with. +1 for feedback
PArting Out a Mint 88 TSi I might have what You Need?
slowspyder replied to Turbo Nine Performance's topic in Parts for sale
How much for both front left/right spindle/strut housings (no shocks/springs/upper hats) shipped to 90042 los angeles? -
That is correct!!! with that rubber gasket too!! -
Nothing wrong with a 3/4 wire heated o2 sensor right after the turbo. Alot of oem turbo cars have a heated o2 sensor right after the turbo.
That flange that bolts to the downpipe should be threaded for an o2 sensor. Atleast mine was.
I need the pick up tube that bolts to the fuel tank. Let me know a price shipped to Los angeles 90042 -
I need the alternator and plug with about 6" of wire. Preferrably out of the 88
Hey scotty, do you have this radiator installed in you car? I like to see pics if you do
Whats the shape of the connector on the alternator? T or oval?
Are you measuring lip to lip? If you measure from lip to lip the stock 7" wheels measure 8" and the 8" wheels measure 9". Just show a picture of the back. It will tell you the size of the wheel behind one of the spokes.
Another LED third brake light
slowspyder replied to slowspyder's topic in Stereo and Electrical Mods
http://www.lshlights.com/itemCombination.asp?GroupCode=3500-SERIES $69.99 plus shipping for amber or red -
Shot of the light without the lense. -
I saw the group buy for the led brake light and was thinking of jumping in but I came across some Led directional light from ecco lights at work. The model number is 3510 and it comes in amber,red,blue and white. These are sealed with a power module wired inline, 24 1 watt leds, 16 flash patterns including a solid on. I think i saw them go for 69.99+shipping on the internet http://www.eccolink.com/ProductPages/DOTHMPG.cfm Before I installed them on the truck i was working on i ran to my car and did a quick mock up and it looks like it would fit. Next thing i wanted to was how bright these things were so i wired everything up(4 wire connection, only 2 necessary for operation) and turned them on. They were pretty bright, bright enough to set my welding helmet off in broad daylight. I figured give it a shot since i got a discount through work and this is what the outcome was. Minor trimming was required, the plastic slots that hold the metal tab have to go. Other than that the light was held on to the black plastic piece by the two screws supplied with the light. The screws just threaded onto the plastic and it seems pretty solid. First two pics are just brake lights on. 3rd one is brake lights with the led third brake light and the last one is brake lights without the led light
anyone have a trashed center link?
slowspyder replied to 89PalermoSHP's topic in Just plain ol' B.S.
Ive never checked mistubishi on that but im assuming since you got one that they are still available through the dealer?? -
Bought an idler arm and a couple of distributors. Responded to every pm/email quick. Definitely would buy from again.
Resurfaced ACT and Fidanza won't release!
slowspyder replied to mstieg's topic in Advanced Virtual Mechanic
Sounds like the clutch disk was put on backwards. The thick hub with the springs in it sticks out further on one side than it does on the other. The side that sticks out the most on the disk faces the transmission. -
how long does the sealant last on the wheels??? Just wondering if its possible to make these in a 2 piece configuration instead of a 3 piece??? Although i must say those look beautiful
MOOKEEH MK1 AJUSTABLE SUSPENSION PROJECT
slowspyder replied to 101PROPOSE's topic in Group Purchase Info
Caster on any starquest is adjustable -
GP: MOOKEEH MK1 2.5" & 3" SS EXHAUST SYSTEMS
Partial deposit sent!! This is for 3" ss 304 exhaust system without the muffler. Thank you 101 Thanks, Mychal -
I want in on the group buy!! Mookeh, is it possible to send you a part of the deposit now and the rest of the deposit on the 21st of june? If your ok with that then put me down for a 3" sus304 exhaust system without the muffler. By the way i tried sending you a pm but your inbox is full
