XADAMX Posted April 20, 2010 Report Share Posted April 20, 2010 Hi I've heard that adding a 88-89 ECU from a conquest or Starion into my 1987 conquest can improve engine function. I would like to know if this is true? I'm mainly concerned with prlonging the life of the current engine in the car. An engine swap isnt in the cards economically right now but shouldnt b for a lonng time as it only has 68xxx miles. Thanks for your help -ADAM Link to comment Share on other sites More sharing options...
Guest Posted April 20, 2010 Report Share Posted April 20, 2010 (edited) 88-89 ecus had an upgraded program with no fuel cut. I think that's the only difference. As far as engine life, that's up to you, your lead foot, how you maitain it and repair when needed. Edited April 21, 2010 by louswheel01 Link to comment Share on other sites More sharing options...
Coke Posted April 20, 2010 Report Share Posted April 20, 2010 Pretty much what louswheel said. If your not so much into the whole go fast scene, and more into the just keeping it alive "driver" kind of guy...then leave the 87 ecu in there since it will be no advantage to you to upgrade. Upgrading to the 88-89 ecu is for people who want to run more boost without running into a fuel cut. It's just removing a roadblock on the way to horsepower alley. Link to comment Share on other sites More sharing options...
Shelby Posted April 20, 2010 Report Share Posted April 20, 2010 if longjevity is what your after then as said you'l find no real advantage in swaping the ecus in stock form these engine can and do 2-300k on the clock easily,, the main thing is replace the t-chain and guides in a timely manner , and keeping the engine cool and with good oil Link to comment Share on other sites More sharing options...
Fanta Posted April 21, 2010 Report Share Posted April 21, 2010 Like everyone else said, its really just fuel cut. Technically you could spend $3 at Radio shack, buy a potentiometer and wire it into the ecu ( its what HKS FCD is ) Link to comment Share on other sites More sharing options...
Elkidmino Posted April 21, 2010 Report Share Posted April 21, 2010 The 88-89 ECU's still have a fuel cut, at 13psi in fact. It's when you add a 1G MAS that it goes away. About the only provision is the ability to read higher stock boost levels (11.5psi) and the ability to add a 3 port wastegate with the stock boost reference solenoid located on the MAS. You'd be better off adding an 88-89 knock box since the 87 plastic boxes break down internally over time. Link to comment Share on other sites More sharing options...
Starwolf Posted April 21, 2010 Report Share Posted April 21, 2010 ^^^ Lies. My car is an 89 and there is no fuel cut at 13psi to speak of....let alone 16psi Link to comment Share on other sites More sharing options...
rrperez10 Posted February 17, 2015 Report Share Posted February 17, 2015 I have a 1986 conquest and I'm replacing my knock box, can I just add another years knock box, or is there something else that needs to be done? Link to comment Share on other sites More sharing options...
Malykaii Posted February 17, 2015 Report Share Posted February 17, 2015 I also feel adding an 88/89 ecu without the matching distributor is not worth the effort. Add in the 88/89 knock box as well and you'll be set if your looking for a performance boost. However, like above, if your just driving like a gentleman and nothings broken, don't change anything. Money better spent on things like maintenance I'd your worried about the long term. Link to comment Share on other sites More sharing options...
clow340 Posted February 17, 2015 Report Share Posted February 17, 2015 It should be 18lbs for cut off, thats where mine would stop. Link to comment Share on other sites More sharing options...
StarquestRescue Posted February 18, 2015 Report Share Posted February 18, 2015 I have a 1986 conquest and I'm replacing my knock box, can I just add another years knock box, or is there something else that needs to be done?You can use 84-87. An 88-89 can be used if a different plug spliced on 1 Link to comment Share on other sites More sharing options...
rrperez10 Posted February 18, 2015 Report Share Posted February 18, 2015 So my car just turned off on me one day driving home, and it would crank but not start. I put a new coil in and it started but then it shut off after driving it for a little. The coil was under warranty and replaced it. It ran fine for 20 minutes and then turned off again. I found out that coil coil keeps shorting out and not producing spark. Will replacing the knock box fix the problem? If not, does anyone know what will? Link to comment Share on other sites More sharing options...
Shelby Posted February 18, 2015 Report Share Posted February 18, 2015 ign system has few parts , but they all must work , the load for coil charging is carried by the igniter , excludeing the wireing you have the dist pick up , the igniter box , coil and cap and wires one poor connection can kill the entire systtem Link to comment Share on other sites More sharing options...
ucw458 Posted February 18, 2015 Report Share Posted February 18, 2015 83-87 plastic ignitors are prone to failure. The 88-89 units are more reliable but use a different connector so they require a little re-wiring. Link to comment Share on other sites More sharing options...
