17" wheels OEM look
on4now4
well im thinking something like 17x8 on the front and 18x11or12 on the rear with a more fin kind of design on the spokes that would suck air in to cool the breaks.
this is a quick drawing i did of how the spokes might look
http://i129.photobucket.com/albums/p209/on4now4/untitled-3-1.jpg
what i need to know is what offset i would need to get these to fit can anyone tell me that so that i can try and get a price estimate this week.
this was started in the custom tires thread http://www.starquestclub.com/forum/index.php?showtopic=92301
people that would want some
alexnyc
Edited by on4now4
How close do you want them to the fenders??
I'm running 16x8 -10's with 225/50's... and it's about 15mm too far out.
Rears, I'm also running the same size but with a 25mm spacer, and it's just about perfect.
Front: 17x8 +5
Rear: 17x8 -35
That's what I'd like to see.
-Robert
Id be in for 17s or 18s, 9j front with a -3 offset and a 10j rear with -18 offset
Not everyone wants the lip of the rim flush with the outside of the fender, as many of us want to go lower, and those offsets just won't work with out ungodly amounts of neg camber (also what most of us try to eliminate).
for the front of a 17, or 18 x 9, you'll want about a 10mm t be right to the inside of the fender, it will require rolling if lowered though.
and on a 17 or 18 x 10, you'll want about a 0mm or -5mm to go with the front. will also require fender rolling if lowering.
now this should allow you to run tires that are NOT stretched on the rim (which I do NOT like) with just fender rolling for lowering
Derek
Derek
I can understand that(everyone has their taste) but in a couple of months Ill show everyone how good it will look :thumbsup: I was thinking that you would be able to get a custom offset since these would be manufactured.
To do them individually then the cost would be to high instead a run of lets say 20 sets all the same should be cheaper...
yeah...I say, if you're going to do this, make them just like the stock wheels, only bigger.
Those do look like Iroc wheels...though...
but, as far as better cooling for the brakes....
1. If you're getting your brakes that hot that the wheels are what stands between them not disintegrating...theres bigger problems...
2. Mitsu seemed to design everything on these cars pretty well, so, I'd venture to say that the stock wheels are pretty good for cooling.
3. Bigger wheels = less confined space around brakes...so...already better cooling
4. Tell people to get better pads/rotors
Like I said...take the stock wheel...just make it larger. The unique spoke design is what makes our wheels cool.
Thats just me though.
Tyler is right keep them like the OE as much as possible...Just bump up the size from a 16" to 17"8fr & 18"10rr..Offer different coatings or polish to make them more unique
It will be easier to construct and fit on our cars....
If the brakes get that hot switch to slotted rotors and Hawk pads or something...
I'm interested in a set of 17" rims that mimic OEM. The 18" OEM rims on my Audi 2.7T daily driver have had 2 tires bubble and 1 blowout due to their low profile in the last 12 months. Replacement tires are expensive and 17"s are more forgiving than 18"s.
Derek
Agreed if your trying to make your wheel lips flush your sitting to high.
Is there really a need for a 9" wide front rim?
Also price out 17 x 8 front and 17 x 9 rear with OEM offset.
Thanks,
Dan
am i really the only one that has a prob with heat in the breaks alright i guess i will try and get prices for a oem 17x9x10 and a 17x10x0
I doubt there is a need for anything wider then a 17 X 8 upfront. I would say the widest you could run (and still run them hard, be lowered and not rub when turning hard) would be a 245 maybe a 255 upfront and a 8" wide rim is plenty for that.
Nah, Ive calculated those offsets from experience. Im running 17x9 -1 offset right now and its flush in the front.. 17x9 -20 in the back and theres still room. im factoring in the negative camber when I go lower.
what do you guys think of this still able to suck in air as in the original design but more oem looking
http://i129.photobucket.com/albums/p209/on4now4/rim2copy.jpg
Nice cad drawing. Re-designing them to help cooling is an unneeded complication.
Just so you know...
This has been tried or looked into at least three different times and I think someone even has cnc ready designs (mookie?), but the problem is the cost
and the fact that no one wants commit before a prototype is done, and it takes $$ to get that done.
Plus not enough people can afford to buy wheels that are worth more than the blue book value of the car.
And the few people who can afford them cant all agree on sizes or offsets.
here are a few of the wheel threads:
http://www.starquestclub.com/forum/index.p...9&hl=wheels
http://www.starquestclub.com/forum/index.p...6&hl=wheels
I think if someone put up there own money (+ some GP members) to get them produced and made available, people would buy them.
It might take a while to sell them all.... but they would sell eventually.
I STILL DONT UNDERSTAND WHY EVERYONE WANTS TO DO THIS THE HARDWAY?!?!?!?!
just machine the centers, WITHOUT the cooling garbage. you only need to machine 1 type of center, not something different for front and read. then, just use a standard bolt pattern for the lips/shells and just get whatever size you want. that's the beauty of three peice rims. christ on a crutch no wonder no ones completed this task yet.
that may be what i end up doing i was just going to get in contact with the guy that i know that makes rims and ask him for a price and what the best/cheapest way to do it is. i just haven't gotten in contact with him yet
the cooling was just a neat idea i came up with when i took the car to the track and did have heat being an issue if really nobody is interested i will not do it i just thought i would throw it out there.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
