Magna Intake Gasket Installed
So a while back I ordered a few sets of Magna intake gaskets from Repco in Australia. Finally got around to changing the gasket and now it leaks coolant. It seems to be leaking right out of the intake gasket under #4 runner, but i can't really get in there to see. When i say leak I mean it couldn't come out any faster if I was just dumping the coolant right on the ground. I coated the gasket with Gray RTV and double checked that all coolant lines are still connected and tight. The coolant passage in the back of the head on the magna gasket is larger but i looked like it would seal up alright, guess not?? Is the larger coolant passage in the new gasket possibly large enough that part of it doesn't seal against anything on my marnel head? It is not letting any water into cylinder 4.
Here is a pic of the gasket before install. Any ideas? I REALLY don't want to pull the intake again but it looks like i may have to.
http://img291.imageshack.us/img291/4184/magnaitakegasket.jpg
US head or magna head? you can't mix/match
Here are some pics to show others the differences:
http://webpages.charter.net/catsamuel/DCP00856.JPG
http://webpages.charter.net/catsamuel/DCP00857.JPG
http://webpages.charter.net/catsamuel/DCP00858.JPG
http://webpages.charter.net/catsamuel/DCP00859.JPG
Well Son of A @#$! Looks like I'm getting dirty on Easter!
Thanks Chad. I am running an AMC casting marnel. I see now where my problem lies. thank God i have 2 more intake sets! lol
So how about I take the piece of gasket that popped out of the rear coolant hole and cut out the middle then rtv the sucker in there. That should do the trick I think.
The only reason I am trying to use the AU magna gasket is so that the hole in the head that used to be covered by a plate and serperate gasket is covered all with one gasket. I have been having issues with an oil leak there.
Edited by psu_Crash
most of us use the fuel pump gasket from a 70's colt to cover that hole (they are under $2). If you use that blue felpro gasket I have pictured, you'll need to double stack them, or use lots of RTV on it (what I did on mine).
That's the first I have heard of using the 70's fuel pump gasket. If I had known that i never would have went through the trouble and high expense of having magna gaskets shipped from Australia.
Thanks again Chad
You can sel those to members with magna heads as it's the only gasket that will work on those.
Any mechanical fuel pump G54B aplication will work when you ask for that gasket. The colt for sure, and probalby the sapporo and fire arrow too.
I tack mine on with some RTV (thin layer) so it stays in place. Let it dry, then put a 2nd layer of RTV on the outside of it for the added thickeness, and put on the main gasket and bolt on the intake manifold.
Mike, if you're will to sell like Chad suggested, I have a magna head that I'm about to put on.
And not to hijack, but Chad if you read this, do you foresee a problem with reopening the rear coolant passage on the intake (head was originally welded up for the US head by you) or should I just leave as is?
I ordered the gaskets through a company called Repco in Australia. It was expensive and very slow shipping. I had to wire $$ to them and that was a big part of the cost.
I currently have 2 complete Magna intake sets. They come with all of the gaskets to rebuild your magna intake.
Richy i sent you a PM I am willing to sell one of the sets
Wish I would have know you needed one. They were with me in Scranton
Edited by psu_Crash
For anyone else who needs these gaskets.
Email Craig at this address: rapoz@repco.com.au
Great guy and easy to deal with.
Tell him you want the same gasket set that Jason and Mike bought. He will send you 3 complete sets then.
The part number is JC511 and it's made by ACL
Edited by psu_Crash
I just use a couple of the fuel pump gaskets like Chad mentioned. Even if that is a Marnel head there are still the jet valve passages cast into the intake flange area because they only made the one casting and they just don't bore out the hole for the jet valves so when you hear it was cast for no jet valves that's bullchit cause they sell Marnel jet valve heads and I have one. I don't know what they do for a Marnel Magna head, since they do cast the rear water port large and they didn't have jet valves at all for those then the mold I'd assume doesn't include the passages in the head for the air to pass under the intake manifold. You sure your intake flange is flat? Yes you have to put a film of sealant on the flange and head at water passages.
Oh the joy, and to answer BOHO's question, you can get the gasket for the magna intake and marnel head at any parts store, just tell them you have an 88 starion or conquest and you need the intake manifold gasket! ;)
You don't even have to use a gasket for the fuel pump block off. Just goop it up with RTV, careful not to get it in the intake ports.
So where can I get a gasket for magna intake and marnel head....?
You'll need to fill in the rear port on the intake, or make an adapter flange like Gled did for his intakes. There is no other way...
Do you see any problems with just doing this? I will be sure to RTV it very well
http://img27.imageshack.us/img27/9336/magnaintakegasketmodifi.jpg
That woudl work, but you'ld always wonder about it. I'd just get the US gaskets (1 intake and 2 fuel pump, or 1 intake and 1 fuel pump with RTV) and sell that magna gasket.
Anyone with a magna head needs that gasket as nothing else stateside will work for them.
I wouldn't do anythig to mod the head, then it's useless for anything else, or to anyone else.
You could always just get a roll of gasket paper and make it yourself.
DING DING DING! We have a winner!
I am not patient enough to wait for NAPA to get gaskets in so I took some gasket paper and spent an afternoon tracing and cutting a one piece gasket to my liking. Checked for flatness and all looks good. Put a thin layer of gray RTV around the water passages and intake ports. Bolted everything down last night and let it sit to cure before filling it with coolant. Went for a test run and all is well.
Thanks for all your help guys! especially to you Chad for the quick reply with pics
I still have one complete magna intake gasket set that I am willing to sell. It comes with all the gaskets to rebuild the intake manifold. Wish I would have known all this before I had them shipped from AU. It was crazy expensive.
PM me if anyone is interested, I'll be posting in the FS forum soon.
