autotr8er2 Posted April 21, 2013 Report Share Posted April 21, 2013 So I was driving and shifted from 2nd to third. Engine acted like it locked up. Wouldn't turn. If I set for a sec it will turn but very laboriously. No foreign material in oil. New battery, starter checks out. Any Ideas what I'm up against? I appreciate your help. Thanks, Richard Link to comment Share on other sites More sharing options...
Dad Posted April 21, 2013 Report Share Posted April 21, 2013 not a lot of info to go by.. what did gauges say? Link to comment Share on other sites More sharing options...
autotr8er2 Posted April 21, 2013 Author Report Share Posted April 21, 2013 gauges were reading fine. Oil pressure, temp was fine, only drove 3 miles. I was running then next thing I knew, nothing. Link to comment Share on other sites More sharing options...
autotr8er2 Posted April 21, 2013 Author Report Share Posted April 21, 2013 I thought I may have lost oil pressure, but oil is present in the head. No galling. Timing chain is tight. Link to comment Share on other sites More sharing options...
Cloud81918 Posted April 21, 2013 Report Share Posted April 21, 2013 Having spun bearings, you tend to hear then as a loud click as the bearing knocks back and for other in the small amount of space made after is spins. The rotation isn't labored. many time an engine will run for a long time before locking up. Could is be exhaust side. Perhaps a failing cat? sometime cats will break lose and rotate sideways in the body of the cat. It will really choke the engine. Link to comment Share on other sites More sharing options...
ShadowTSi Posted April 21, 2013 Report Share Posted April 21, 2013 There's always the possibility that an electrical connection came apart somewhere or that a ground came loose and isn't allowing all the systems to function normally. An electrical issue might explain why there doesn't seem to be anything mechanically wrong with the car, other than the slow cranking being the only symptom. Link to comment Share on other sites More sharing options...
Komeuppance Posted April 21, 2013 Report Share Posted April 21, 2013 Use a ratchet and turn the engine over by hand. Remove the spark plugs, and try it that way too. -Robert Link to comment Share on other sites More sharing options...
Dad Posted April 21, 2013 Report Share Posted April 21, 2013 ^^^^ Then see if it spins free with the starter enough to try a compression test. If it over heated it can seize up then turn free after it's cold again. Not saying that's what the problem is, but you need to do some inspections on it. Dad Link to comment Share on other sites More sharing options...
autotr8er2 Posted April 21, 2013 Author Report Share Posted April 21, 2013 Ok, I'll try the compression test. I tried to turn the motor over by hand once, no go. The spark plugs were removed, no change. I'll also check the electrical side as well. Wires were hot, but I figured it was due to the increased torque the starter was "seeing" I appreciate all of your help guys. the previous owner spent a lot of money and time into this motor so I don't want to give up on it. Link to comment Share on other sites More sharing options...
Dad Posted April 21, 2013 Report Share Posted April 21, 2013 If you can't turn it over by hand then forget trying a comp test. You are going to have to find out what the bind is. Link to comment Share on other sites More sharing options...
Komeuppance Posted April 21, 2013 Report Share Posted April 21, 2013 Doesn't sound to good if it can't be spun by hand. Like Dad said you're gonna have to inspect and test to eliminate what component is causing the problem. Remove all belts, just in case an accessory has locked up, though unlikely. Pull the valve cover and inspect, try turning the engine from the cam bolt just a bit. It sounds like its an auto transmission?? -Robert Link to comment Share on other sites More sharing options...
Dad Posted April 21, 2013 Report Share Posted April 21, 2013 I'd use a 7/8 socket on the crank bolt. Link to comment Share on other sites More sharing options...
tsi_tom Posted April 23, 2013 Report Share Posted April 23, 2013 (edited) I once saw an alternator lock up on a Toyota MR2. Try what Robert said and remove the belts. Edited April 24, 2013 by tsi_tom Link to comment Share on other sites More sharing options...
Shelby Posted April 24, 2013 Report Share Posted April 24, 2013 what ever you do do not try to spin the engine with starter any more until you fix problem also if a brg has spun,, that rod will have to be remove'd from the engine and resize'd and crank check'd for damage,, more or less the engine needs to come apart Link to comment Share on other sites More sharing options...
TopDawg_43 Posted May 9, 2013 Report Share Posted May 9, 2013 Sounds like it's time for you to pull the oil pan and pull a cap or two. Link to comment Share on other sites More sharing options...
