FS: KM132 - 5 Speed Strengthening Pans Available
plh
Strengthen the 5 Speed behind the 2.6l in your Conquests and Starions. These pans are tooled from Aluminum 6061-T6 alloy and measure 19mm thickness. They come with 12 pieces grade 8.8 M8 mounting studs and serrated flange nuts. A M18 threaded hole is included for your OEM drain plug. The pans will also fit the KM145 in Gen 1 Raiders - Monteros - Pajeros. For best performance to use Loctite #518 and no gasket when installing.
please paypal USD $110.00 including shipping within the USA. International shipping at variable rates email questions to: nsm.paul(at)gmail.com or PM for further information.
Premium kit now available includes Loctite 518, Pro Seal Blue Thread Lock, and a fiber drain plug gasket. Add $10 to order (USD $120 total within USA). Will ship international.
I am a regular poster at 4x4wire with the same user name. (I am a Raider aficionado)
http://www.ns-micro.com/~phanson/pics/640_480/PanTop_prof_sm.JPG
http://www.ns-micro.com/~phanson/pics/640_480/PanBottom_plug_sm.JPG
http://www.ns-micro.com/~phanson/pics/640_480/PanBottom_sm.JPG
Edited by plh
The only thing I can see in difference between a 87 & 88 transmission is.....Mitsubishi started stamping vin numbers on the 88 & 89 transmissions.
Mitsu added the cast pans in 88 & 89 to reduce case flex with the higher output engines. The cast pans are getting pretty difficult to find, so I tooled the stronger 6061-T6 billet pans.
http://i37.photobucket.com/albums/e82/silverquest/PQ%20manual%20pics/album_pic.jpg
88-89 had several improvements most notable the cast aluminum "waffle" pan and a different design on the input shaft bearing. Alot of the differences you won't see but can tell if start measuring different internal components. With the tight tolerances found in a transmission, even a small amount of movement can cause big problems. Case flex was apparently a problem and the "waffle" pan was the fix. PLH's pan is intended to serve this same function and is a bit overkill, but is that really a bad thing. This is mostly an upgrade for those with 87 and older cars, but with the thickness on his, 88-89's could benefit as well. If you need proof, push on a body panel (stamped steel), then push on say your valve cover (cast aluminum).
Kane
do you have prooof to show that this helps??
Well, I don't have a cast pan from the '88 / '89 series. Anyone have a measurement of the wall thickness? I built these for the KM145 transmission which all came with the stamped steel pan. As a plus they are interchangable with the KM132 as you probably already know. I'm running strain gauge testing comparing the billet 6061-T6 pans to the OEM stamped steel units and will publish the results in early February over at 4x4wire(dot)com. If you have a spare 88/89 cast pan I could borrow for a couple weeks I'll include it in the data.
Thanks! -Paul
19mm to english is what.. 3/4's of an inch thick? I could see this adding some strength to the overall structure of our transmissions, but not significantly. Correct me if I am wrong, but I think the transmission is 3/4's thick as well?
actually mm would be english, they use the metric system. 19mm = .7480"
I might be a noob here, but this looks like a good idea.
And usually 4x4 guys know how to make s*** strong.
Only thing is, us pavement guys like stuff light. Any chance of getting you to whack some webbing out of some of these? maybe with a slight bevel to keep the stress risers down?
Hey, you should be banned for using fancy engineering parlance like that. And can't you see, there is no webbing on the piece he's offering, it's just got a milled depression to hold tranny fluid.
I looked into an option with ribbing on the exterior but that adds a bunch of expense - more than double due to the extra machining time. These plate now weigh about 5 lbs with the hardware. Would there be interest in a lighter version for around $200 +/-? Probably would be somewhere around 1.0lb lighter.
I'm not sure if by ribbing you mean cooling fins, but if so, you can buy aluminum bar stock with pre-extruded fins and save a bunch on machining.
Something like this, but obviously with less extreme fins and a thicker base:
http://www.accelthermal.com/dynimages/pages/sample133.jpg
seriously?
Hmm, yea maybe it's not worth it. I imagined it being a bit heavier. Maybe I should actually look at my plate first HAHA.
Thanks for the reply, I'll probably order one soon seeing how fairly priced you have them.
Thanks, let me know if you want one as they are today.
  • 3 weeks later...
  • 1 month later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
