Treadstone cast after market manifold
20 replies to this topic
#1 03CL55AMG
03CL55AMG
  • 634 posts
  • Interests:cars and more cars, and hot girls
Posted 31 August 2014 - 09:14 PM
I will be swaping turbo's out and  going to a t3/t4, I have been looking at a nice treadstone that is setup for the t3/t4 and the flang for the external wastegate . Does anyone know if the runners on the treadstone are a larger diameter as compared to the stock manifold. Of course looking for more air flow for the bigger hot side, thanks
Forged motor, weisco pistons ,3" exhaust, garret 60 cold/ 70 hot turbo, bosch 1000cc injectors. meth kit. chads intake and header. holly EFI stand alone. *DM intercooler. grimspeed boost controler. stock cam.
#2 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 01 September 2014 - 01:47 AM
treadstone sucks. mod the stocker.
#3 03CL55AMG
03CL55AMG
  • 634 posts
Posted 01 September 2014 - 09:08 AM
Thanks Funky, when you say mod the stocker exactly what are you refering to.
#4 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 01 September 2014 - 09:50 AM
adapter plates
#5 scott87star
scott87star
  • 5,021 posts
Posted 01 September 2014 - 10:50 AM
#6 03CL55AMG
03CL55AMG
  • 634 posts
Posted 01 September 2014 - 03:33 PM
Thanks guys, star that pic is great appreciate that....I would think that a tial 38 would be big enough...the turbo that I am swapping is a airesearch  with a .96 hot and a 60 cold side...any thoughts or suggestions
#7 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 01 September 2014 - 07:31 PM
i prefer more space on the adapter. Gives you more room to work.
#8 importwarrior
  • 18,313 posts
Posted 01 September 2014 - 08:30 PM
I ran a 82 and 63 and a 48 AR
Think the 63 was best for daily driving.
But loved the spool if the 48.
Currently the turbo I run is a turbonetucs
Super H compressor 52 lb \min
With a similar to TD06 turbine size.
57 trim turbine
Edited by importwarrior, 01 September 2014 - 08:34 PM.
#9 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 01 September 2014 - 11:32 PM
Why does the treadstone suck? I've had one on my car for a long time and never had any issues.
#10 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 01 September 2014 - 11:41 PM
1. they crack as often as 25yo stockers
2. less directional influence than even stock.
3. poorly locate everything.
4. its my opinion so its a fact.
#11 starquestJOE
starquestJOE
  • 3,573 posts
Posted 01 September 2014 - 11:57 PM
Lets just say I have kept and put more miles on a junk smb then I did the treadstone I had. The only plus to the tread stone is cast, thats it. The placement of the turbo and wastegate are terrible. You HAVE too run a spacer for the wastegate to clear the down pipe. And you can not run a dump tube or route into downpipe without running it facing the valve cover.
Save your money and spend it on a JDL manifold or GATO. Yes they cost more, but you get what you pay for.
And what phil says goes around here!
IM STARQUEST 4 LIFE ....
88 esi-r-white-SOLD
88 tsi white 61k-SOLD
89 tsi-black-rip
87 tsi-black/red-SOLD
88 tsi yellow sold
89 tsi white parts car
88 esi-r-black-RIP
#12 starquestJOE
starquestJOE
  • 3,573 posts
Posted 02 September 2014 - 12:46 PM
88 esi-r-white-SOLD
89 tsi-black-rip
88 tsi yellow sold
88 esi-r-black-RIP
#13 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 02 September 2014 - 04:21 PM
I don't have that wg fitment issue.See my recent video. I have a synapse 40mm wastegate with a dump tube running down almost parallel with the downpipe.
https://www.youtube....M9otGwrdOH8WV3Q
#14 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 02 September 2014 - 09:40 PM
Is that a shutoff valve in your pcv system?
#15 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 02 September 2014 - 09:43 PM
Heres how mine was modified.
http://www.sqperform...php?topic=103.0
#16 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 03 September 2014 - 05:37 PM
I have ball valves to control the vacuum being pulled by the intake because it's just a fitting without a PCV valve on the front of the VC. I'm using krank vents also. Without controlling the flow, the engine pulls too much vacuum at idle and I don't want it to blow a gasket.
Edited by CaliConquestAlex, 03 September 2014 - 05:39 PM.
#17 03CL55AMG
03CL55AMG
  • 634 posts
Posted 04 September 2014 - 09:01 PM
That is some good info, thanks for the pics funky...let me ask when welding the cast what rods did you use..I know there are many cast metal combinations, thanks.
#18 Funky Phil
Funky Phil
    Super Pooper
  • 6,446 posts
Posted 19 September 2014 - 05:34 PM
Wow, sorry I never responded. Most have luck mig welding it. Regardless of method you need to use a proper preheat and heat maintenance, and slow cool down process to protect the cast. I can do it for you if you cant find anyone.
#19 03CL55AMG
03CL55AMG
  • 634 posts
Posted 20 September 2014 - 05:10 PM
Thanks funky...good to know, I may ask my neighbor who will be doing the modifications if he would do a header instead of moding a stock manifold...it will be up to him.  Just looking for the most exhuast flow .
#20 Fuze
Fuze
    AKA @Battlemagnet
  • 2,779 posts
  • Interests:Chess Boxing
Posted 24 September 2014 - 08:04 AM
I also had the Treadstone and had no problems with WG/dump tube clearance with a Tial 38mm. The turbo does mount lower that stock. The runners are bigger than a ported stocker and mine was stress-relieved. It's basically a copy of the more expensive and harder to find Turbonetics Starion manifold.
Insta = @battlemagnet
