tim si Posted July 23, 2007 Report Share Posted July 23, 2007 Ok ive held off on posting this til i gathered up enough parts to get started.im starting out with a stock 5.0 short block.installed an e-303 cam today.im going with trick flow twisted wedge heads,a BBk SSi intake,42lb injectors,70mm mass+throttle body,MSD 6 btm i got from chad to help retard timing,new turbonetics 60 mm turbo,and a brand new t-5 from ford racing.all this is going in my black 89 quest.ill add pics as i go and ill try to take as many as i can because this will be the biggest build ive ever done.if any one has any request for certain pics let me know.this is my second v-8 swap and ill try to share any info i can.any advice will also be greatly appreciated. Link to comment Share on other sites More sharing options...
Crazy larry Posted July 23, 2007 Report Share Posted July 23, 2007 Awesome good luck with your project 8) Link to comment Share on other sites More sharing options...
ls1project Posted July 23, 2007 Report Share Posted July 23, 2007 Hope all goes well... sounds like a fun car. Link to comment Share on other sites More sharing options...
TSI_SVT Posted July 23, 2007 Report Share Posted July 23, 2007 Can't wait to see the progress. Mine will get boost of some sort in a year or two. Link to comment Share on other sites More sharing options...
Star_V8_Quest Posted July 23, 2007 Report Share Posted July 23, 2007 post pics....and I thought you were going to SC it....must have been someone else :shock: Link to comment Share on other sites More sharing options...
tim si Posted July 24, 2007 Author Report Share Posted July 24, 2007 (edited) I have to admit s.c. would be easier and be good on a 5.0 but the better you make the engine breath the more boost you lose,then you have to start changing pullies.the turbo just keeps pushin.I think the turbo will look alot cooler under there.i dont think ill go with an innercooler though.cant find room.hows this to start with? http://i159.photobucket.com/albums/t126/timtsi/newpics012.jpg Edited June 14, 2008 by tim si Link to comment Share on other sites More sharing options...
TSI_SVT Posted July 24, 2007 Report Share Posted July 24, 2007 I may swap to that intake just for the looks alone. Link to comment Share on other sites More sharing options...
tim si Posted July 24, 2007 Author Report Share Posted July 24, 2007 Id almost give you the intake if youd tell me where to get those wheels.i believe itll work good,the runners are pretty straight,but if you get one,check it close.a few holes thats been tapped in the ports has little jags of aluminum just waiting to fall off into the cyls.im gonna have to do some deburring before i do a final install.im not 100% on clearence yet but its only 1'' taller than stock.the thing is most other intakes have to have a spacer to run taller valve covers with adj rockers but this one has no problems,comes nowhere near the valve covers Link to comment Share on other sites More sharing options...
Star_V8_Quest Posted July 24, 2007 Report Share Posted July 24, 2007 I will tell you where to get wheels like that if you give that intake to me..lmaoI know the seret...hehe Link to comment Share on other sites More sharing options...
TSI_SVT Posted July 24, 2007 Report Share Posted July 24, 2007 They were on the car when I purchased it but I'll provide a link below where they can be purchased. http://superbuytires.com/Boze/Doons/ Link to comment Share on other sites More sharing options...
tim si Posted August 9, 2007 Author Report Share Posted August 9, 2007 Well i finally got it in Im going to go ahead and break the motor in and work out all the bugs before i put the turbo on.hopefully i can get that done in the next couple weeks after the pipes are built ill have to have them jet coated so itll be down for a few weeks.then its off to the paint shop.the heat has slowed me down alot.i think the index was like 102 today and its miserable without a shop but heres a couple picshttp://i159.photobucket.com/albums/t126/timtsi/ImportedPhotos00031.jpg Link to comment Share on other sites More sharing options...
tim si Posted August 9, 2007 Author Report Share Posted August 9, 2007 I cut notches in the stands on the engine cradle and set the stock ford mounts right in.http://i159.photobucket.com/albums/t126/timtsi/ImportedPhotos00032.jpg Link to comment Share on other sites More sharing options...
tim si Posted August 9, 2007 Author Report Share Posted August 9, 2007 I did have to bend the rib on the firewall to get the intake to clear.Ill try to get some pics of the trans tomorrow.the t-5 fits way better than the aod.http://i159.photobucket.com/albums/t126/timtsi/ImportedPhotos00029.jpg Link to comment Share on other sites More sharing options...
TSI_SVT Posted August 10, 2007 Report Share Posted August 10, 2007 Well i finally got it in Im going to go ahead and break the motor in and work out all the bugs before i put the turbo on.hopefully i can get that done in the next couple weeks after the pipes are built ill have to have them jet coated so itll be down for a few weeks.then its off to the paint shop.the heat has slowed me down alot.i think the index was like 102 today and its miserable without a shop but heres a couple picshttp://i159.photobucket.com/albums/t126/timtsi/ImportedPhotos00031.jpgThose engines look so nice there. Link to comment Share on other sites More sharing options...
83_project_toy Posted August 10, 2007 Report Share Posted August 10, 2007 is that oil pan chrome or polished? if it's chrome you may want to change it to a painted on. chromed parts have problems dispensing heat. Link to comment Share on other sites More sharing options...
tim si Posted August 11, 2007 Author Report Share Posted August 11, 2007 its chrome but i dont think ill have much trouble.its the only front sump i could find at the time.my other 5.0 swap ran @180 with the a/c on and never got above 190 with one fan.im going to run three on this setup.also have a new alum.radiator from summit.ofcourse theres more heat with a turbo. Link to comment Share on other sites More sharing options...
tim si Posted August 21, 2007 Author Report Share Posted August 21, 2007 heres a few pics i took today http://i159.photobucket.com/albums/t126/timtsi/P1010034.jpg Link to comment Share on other sites More sharing options...
Highly Boosted Posted August 21, 2007 Report Share Posted August 21, 2007 what did you do for the fuel pickup tube and screen? cus im doing -10 but i cant find a -10 with a fuel screen or anything to filter it in the tank. thanks much Matt Link to comment Share on other sites More sharing options...
tim si Posted August 21, 2007 Author Report Share Posted August 21, 2007 heres the tranny http://i159.photobucket.com/albums/t126/timtsi/P1010037.jpg Link to comment Share on other sites More sharing options...
tim si Posted August 21, 2007 Author Report Share Posted August 21, 2007 mine is -8 an so i just used a couplind and hooked on to the factory pick up.the pickup is metric size but i think i got a good enough seal.i dont know how youd do it with 10 an.what if you just ran a line down there and ran an inline filter before the pump? Link to comment Share on other sites More sharing options...
Highly Boosted Posted August 21, 2007 Report Share Posted August 21, 2007 mine is -8 an so i just used a couplind and hooked on to the factory pick up.the pickup is metric size but i think i got a good enough seal.i dont know how youd do it with 10 an.what if you just ran a line down there and ran an inline filter before the pump? you would think they would just make a filter/screen in AN size to hook up to the hose fitting. I though about doing that too. Link to comment Share on other sites More sharing options...
mrdodge01 Posted August 21, 2007 Report Share Posted August 21, 2007 That's what I've seen done on other fuel pump installs like that... run a big -an line down into the tank long enough to go to the bottom, then just run an inline filter plumbed into the inlet of the fuel pump... Link to comment Share on other sites More sharing options...
tim si Posted August 22, 2007 Author Report Share Posted August 22, 2007 http://i159.photobucket.com/albums/t126/timtsi/newpics030.jpg heres a pic of the stock mustang mounts i used Link to comment Share on other sites More sharing options...
tim si Posted August 22, 2007 Author Report Share Posted August 22, 2007 http://i159.photobucket.com/albums/t126/timtsi/newpics031.jpg I just slotted the quest stands in an ''L'' shape to sit the engine down then slide back.with these mounts i had no trouble with the front sump oil pan clearing everything.theres a good inch and half between the oil pan and engine cradle.you will have to use fords small starter instead of the big one.steering linkage is no problem.I just hope the metal holds up at the mount.i put a huge washer on the back Link to comment Share on other sites More sharing options...
tim si Posted August 22, 2007 Author Report Share Posted August 22, 2007 If any of you guys want pics of anything in particular nows a good time Link to comment Share on other sites More sharing options...
