FIP TB PRO2R gurus needed please
25 replies to this topic
#1 CarlosFley
CarlosFley
  • 622 posts
  • Interests:-Class Culture-
    Sinatra, Wu-Tang, Keys N Krates
Posted 22 September 2015 - 10:41 PM
Hey guys, I recently swapped over to standalone with a Fuel Injection Pro TBPRO2 and am needing some help figuring out a no start condition. I am getting fuel, however my injectors aren't firing and red LED on ECU that is supposed to flash when cranking isn't. Odd thing is she ran just fine before for a few minutes, no hesitation, no problem whether I turned her off or not. Now she won't budge, only on very rare occasion she'll fire for about a second and die. Please help. Also I know this is Murica and there's freedom of speech blah blah blah but if you can refrain from bashing me for buying a system that no longer has support from a company that is no longer in service when for a little more money I could've gotten MegaSquirt, that'd be great. Thanks guys. Btw, you can text me for faster communication at 7072673473
'87 Chrysler Conquest TSI NON-SHP "Diamond"-Walbro 255, rebuilt TB, OVC hardpipe with HKS SSQV, GM 3" MAF, 1G DSM MAF Translator, 88-89 knock box, black silicone vacuum lines, ABS & Cruise Control delete, 3" HKS Super Power Flow, wire tucked... kinda :/, NRG adjustable shift knob, MSD Blaster 2, tucking tire in the rear and zero wheel gap in fronts on D2's, aaaaaaaannddddd stickaaaaaassssss for that booooooooost!
Interested in: CF 83 style hood, CF air daayyuum. Ohh and turbo-to-intercooler hardpipe.
#2 importwarrior
  • 18,334 posts
Posted 23 September 2015 - 05:30 AM
contact scott87star and have him convert the FIP to a ms1 or MS2.
amazing things scott can do with that!
great price as well for the conversion.
#3 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 23 September 2015 - 06:25 AM
What are you using for your signal? CR125? EDIS?
87 Starion 2jz
#4 scott87star
scott87star
  • 5,045 posts
Posted 23 September 2015 - 08:41 AM
BOHO is on the right track, you won't get the injectors to fire without an incoming rpm signal.  FIP actually used a few different rpm input styles, CR125, GM 4 pin HEI module, rpm output from an MSD 6 series, you'll have to tell us what yours is now.
#5 CarlosFley
CarlosFley
  • 622 posts
Posted 23 September 2015 - 09:05 AM
I am using a GM 4 pin HEI, brand new btw, got some gas on my old one and that's when she started acting up so I thought it was the module and bought a brand new one. Still nothing. Stock ignition system. Red Blaster coil, 89 knock box.
#6 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 23 September 2015 - 09:39 AM
I never used that setup so maybe Scott can help you out. But Its definitely your rpm signal as he stated. Broken wire - bad ground - bad module - etc.
87 Starion 2jz
#7 scott87star
scott87star
  • 5,045 posts
Posted 23 September 2015 - 09:43 AM
If the connectors to everything are crimped go back and solder them all.  Connect a laptop to the ECU, you can use Tuner Studio and it will find that old turd firmware.  Crank it over and look for rpm on the laptop gauges.
#8 CarlosFley
CarlosFley
  • 622 posts
Posted 23 September 2015 - 10:18 AM
Scott they're not crimp together they have connectors crimped onto each end. That's how I got it, and for ease of installation and removal I never thought of soldering them together. Does soldering actually help with continuity more than male and female connectors do? I heard someone mention that by soldering connections you can end up adding resistance to the existing circuit possibly hurting it. But, you're the Guru, I'm just wondering.
#9 scott87star
scott87star
  • 5,045 posts
Posted 23 September 2015 - 03:36 PM
You don't solder the connectors to the module, you solder the wires to the connectors.  It does make a difference.
#10 CarlosFley
CarlosFley
  • 622 posts
Posted 23 September 2015 - 06:53 PM
So you're saying to solder the connectors on instead of crimp them?
#11 TexasQuest
  • 9,082 posts
Posted 23 September 2015 - 07:20 PM
Always solder your connections instead of using crimp on butt connectors.
88 Fiji Blue -TSi
#12 CarlosFley
CarlosFley
  • 622 posts
Posted 23 September 2015 - 07:28 PM
Ohhhhhh okay, I'll do that then. Any links to good quality solder connectors, or are O'Reilly / autozone ones okay?
#13 CarlosFley
CarlosFley
  • 622 posts
Posted 23 September 2015 - 07:34 PM
Wait, I wasn't speaking about butt connectors. The connectors that are on the harness and and that I crimped on r spade connectors both male and female, are those still not good for connections? Do they have  Spade connectors that you solder on?
#14 TexasQuest
  • 9,082 posts
Posted 23 September 2015 - 08:48 PM
Those are better but not what they are being used for on your car. Get some srink wrap sleeve and some solder and a soldering iron and solder the wires together, then slide the heat shrink wrap over your work and then your done.
88 Fiji Blue -TSi
#15 importwarrior
  • 18,334 posts
Posted 24 September 2015 - 04:53 AM
a picture could help out.
#16 FuelinjectionPro
FuelinjectionPro
  • 336 posts
  • Interests:CARS!
Posted 20 November 2015 - 01:19 PM
If ECU light is not flashing check the IAM as shown in the drawing.
#17 Funky Phil
Funky Phil
    Super Pooper
  • 6,447 posts
Posted 21 November 2015 - 01:07 AM
wt....!!!!! Where have you been???
#18 importwarrior
  • 18,334 posts
Posted 21 November 2015 - 11:23 AM
i agree!!!! long time no see.... :blink:
#19 TexasQuest
  • 9,082 posts
Posted 21 November 2015 - 08:32 PM
Are you guys still in buisness?
88 Fiji Blue -TSi
#20 importwarrior
  • 18,334 posts
Posted 22 November 2015 - 11:19 AM
Nope. Don't think so...
