- 4 replies
- 691 views
- 542 views
- 47 replies
- 6013 views
- 8 replies
- 2262 views
mpi intake
By john_conquest,
Looking for an MPI intake with the fuel rail and throttle body already connected...
radiator fans rotation direction?
By G54Bstore,
One of the previous owners have cut trashed and run jumper wires with speaker wire and crap. Wondering since its overheating..are my fans supposed to pull air through the radiator or push air through? They are currently spinning counter clockwise if u look at them from the back side of the radiator pulling air through into the engine bay. I feel dumb asking this but not sure and want to make it all good.
Mazda tps upgrade kits available again!
By boostinmini,
PLEASE PM me if you need a kit. These are a great upgrade for a older one with faster response or to replace a dead one. Option 1 NO TPS, Tps adapter plate, with pigtail, and mounting hardware, all you need to do is supply a tps sensor. $75.00 shipped in north america. NONE available Option 2 Used but tested TPS, Tps adapter plate, with pigtail, and mounting hardware. $125.00usd shipped in north america. Option 3 NEW New aftermarket TPS Sensor, Tps adapter plate, with pigtail, and m
Vacuum Advance Vs. Retard
By MTQuest,
So awhile back my vac advance went out. Start doing the horrible clackity clack on acceleration. Checked timing, was right on the money. Good vacuum source coming from the first of the three vac ports on the TB. So off to the parts store to buy a new vac advance pot. The noise was still there, if anything it was worse. Checked the timing while raising the idle until the noise started to come back and I noticed the timing was steadily advancing the timing as it saw more vacuum, and off the char
