- 1 reply
- 733 views
- 531 views
- 1078 views
- 1 reply
- 895 views
D50 and Quest steering box
By Turbo Cary,
I know people use the truck steering box to convert to manual steering but have to modify the column to make it work. Is it possible to just take the quest gear box apart, remove the shaft that connects to the column and install it in a manual gear box? That way the column doesnt need to be modified. Or are the internals completly different? Here is an exploded view of a MM gearbox. Part number 10 is the shaft I am talking about interchanging. http://www.mitsubishipartswarehouse.com/media
turbo silicone for sale
By boston,
i have son silicone hose i don't need $ 20 for all 4 1 2.5 to 2.25 straigth i use this and mixer housing 1 2.5 to 2.25 90degree i use this and mixer housing 1 1.75 to 1.75 90degree for the stock intercooler 1 2.5 to 1.75 straigth i use and the intercooler piping http://i1072.photobucket.com/albums/w366/carlosa76/Mobile%20Uploads/image_zpskjyhnpzs.jpg http://i1072.photobucket.com/albums/w366/carlosa76/Mobile%20Uploads/image_zpsutzpd9ub.jpg
Fiberglass Interior parts
By Turbo Cary,
I have been debating recently on making some fiberglass parts. My drivers door panel has hole on the arm rest part of it. Basically the board has deteriorated. My thought is to strip the cloth, use fiberglass to reinforce and make a mold from it. That way if I ever need to I could make a new one. I also want to do the same with my center console and radio section. I could make it one peice where the radio is, so it could be cut however fit or left open with factory style center trim. An
Fuel Return Line diameter?
By movin on,
I am looking for the diameter of the fuel return line from the fuel rail. I would like to know what is the correct size barb to use for the stock return line with a a modded fuel rail.
