- 956 views
- 1181 views
- 10 replies
- 1348 views
- 6 replies
- 1026 views
Blower motor problems
By 03CL55AMG,
A couple of months ago my blower motor quit working….or rather when I hit the fan switch…it’s not coming on. I pulled the electric schematics, and I see there’s a blower motor relay before the blower motor. Where is the blower motor relay located?
Knock sensor?
By LordOverboost,
Ok so this is a bit simple in title, but it’s not actually.
Vehicle: My car is a 1987 (I know they’re the most problematic 😫) Conquest TSi, with an HKS Exhaust, HKS Turbo inlet kit, TEP Down Pipe and mid pipe, and a FP Blue from a WRX, modified to work on my hot housing. It’s essentially a TDO5-16G.
The car has been laid up for a few years, so I went through it to put it back on the road. Installed the following:
255 Walbro Fuel Pump
New R/C injectors (750 primary, 1
Mookeeh 35-1 trigger wheel
By Mike7447,
I bought one of these because it fits the pulley and will be easier to mount it. But after doing some reading on the mega-manual for Megasquirt, it looks to me like a 35-1 wheel isn’t supported because the tooth count isn’t divisible evenly when trying to place the crank trigger sensor. Anybody got any input about this?
What is required for the cruise control to work when swapping to mpfi?
By Mike7447,
As stated, I’m converting over to a DIY made mpfi intake manifold. I’ll be using a universal 65 mm throttle body.
Since I’m making the intake, I can design the thing to mount the TB where I want it. While I haven’t looked closely at the old throttle body, I’m sure I’m going to have to try and adapt the cruise control servo/solenoid/actuator to the new TB.
Ignition will no longer rely on the old distributor, and the coil will go in favor of a crank trigger/coil near plug system con
