- 18 replies
- 3699 views
- 7 replies
- 909 views
- 8 replies
- 515 views
- 1 reply
- 302 views
Stumped with Fuel Problem engine cutting out... Please help. SOLVED!!!
By starquest87jp,
Ok im going to describe the problem as best as I can and tell you guys what I have already done. First it is an 1987 conquest and it has been sitting for over a year. before I parked it, it ran strong on the newly rebuild motor. when I went to move it to another place it fired up with no problem. when i press the gas full throttle it will not rev up but sputters and wants to die on me. If i give it a little gas slowly it will rev up to about 3000 to 3500 rpms and cut out. The car will drive with
Need a quick fix to make front a-c, fan come on.
By Dad,
We are in pigeon Forge TN and I have an 87Quest with fan shroud and fan clutch. Any easy way I can get the front a-c fan to run? . The fan is good. If I put 12 volts to it it will come on. Any way I can easily make thise work? I have limited access since I can only get on Internet with a tablet. Dad
front deck garnish removal
By 88-cnqst-tsi,
How can a remove it without a special tool and without breaking it
Engine sputters to a stop when shut off
By ghinckley68,
Its kinda sputters for a sec or two not long but i have to old the clutch in till i am shure its stopped. My guess is Leakey injectors, but so for every one has been on the nose so any thoughts.
