83stariontravis
About 83stariontravis
  • Birthday 01/01/1915
    Oregon
  • ICQ
  • AIM
    NutschLatry
    97302
    1983
  • Factory Color
    Serbia Black
    Black-Gray
3972 profile views
83stariontravis's Achievements
  1. make sure your injector wires aren't grounding to each other or the throttle body. had this issue recently... stupid soldered injector wires...
  2. fuel pressure stays up at 50psi and adding the diode back in removes fuel cut...
  3. What are u smoking?!?! I removed diode because I found one of those tsb harness and I get fuel cut 9psi...
  4. the balljoint mount is removable and very different between the two along with the length of the tie rods. Strut husings/spindle are the same except I think one pair of mine was taller and the strut inserts from my flatbody struts would not fit into the widebody housings... IIRC. I'm running pretty low now with quite a bit of camber up front. Same as a widebody lowered without camber plates tho I believe.
  5. Floating ground. Right signal circuit is grounding through both sets of running light filaments all in series. Lowest resistance filament is lighting. Can't ground through there when the running lights are on... explaining your specific case. Trailer lights can be a pain and a half. Intermittant Floating grounds with LED trailer lights are my favorite because the brightness is basically the same when its broke to when it's intermittantly working right. Gotta add to watch out for these(below) because I've had to track them down burried under miles of electrical tape to fix trailer light wiring at least four times. I really have no idea why lots of wiring install kits come with them and uhaul and other places that install trailer light wiring insist there is nothing wrong with them dispite my suffering and the obvious "fail" plainly seen at a glance. Seriously... I'd rather see a wire nut. http://www.kuramashop.com/ebay2011/Toppier/Cable%20Gland/KW03.JPG
  6. I would like a wider track on the front of my 83. Just did the 5 lug swap. I'm running widebody spindles with flatbody control arms. Kept the steering arms from the flatbody too. If I go to widebody control arms I probably need to swap steering arms i'm guessing. Would this also make my camber more negative?
  7. Any chance of taking some close up pictures? Can you visually see what electronic components it has?
  8. Looked at the picture wrong I meant the compressor wheel. Something go through the intake?
  9. What happened to the turbo's exhaust turbine?
  10. I figured someone would say that. Ill try that today. Plugs look rich so i put in a hacked stock maf. Problem still there but afr looks better. Heat range looks as good as it can get and i see no evidence of detonation.
  11. I am running a 4 pin HEI ignitor for ignition and a brand new stock replacement coil. Wondering if the HEI requires a different spec coil. At full throttle I get a very slight studder that goes away if I back off a little bit. 16g turbo at 10lbs of boost. Runs great otherwise. AFR gauge shows full rich during the studdering. I am running the NGK 7031 plugs that are recommended. Maybe I need a different heat range? Going to pull plugs now to inspect. 4 pin HEI ignitor install discussed here: http://www.starquestclub.com/forum/index.php?showtopic=140828&st=20&hl=knock#entry1459419
  12. So I started thinking and the 83 fuel system for sure compensates for altitude by switching a solenoid when the key goes to the on position and letting ambient air instead of intake source. Started to think I must be wrong and that the signal must go beyond my current findings into the ecu but now I am thinking that the map sensor must self calibrate at the same time as the solenoid is switched upon receiving power. So this compensation would happen outside of the ecu...(in the map sensor.)
  13. Can you post a pic of the harness you are talking about? Same as this? http://www.starquestclub.com/forum/index.php?showtopic=145097 Ok so when tracing the boost sensor signal into the ecu it doesn't seem to go very far. Looks like it goes to an ~80k ohm resistor to sensor ground and in parallel with the resistor there is also a diode to ground with the anode facing ground. I am unable to find any other places the boost signal goes inside the ecu at all... I would take a guess and say when the diode voltage is exceeded it shorts to ground killing anything that is relying on the sensor ground. If the diode was removed would I need to keep the resistor for any reason? And if this is the only place this goes in the ecu how about just cut the wire...?
  14. I've got a hunch the factory fuel cut is in the MAP sensor. After reverse engineering the digi cluster I took a look inside the factory MAP sensor and found a few things to try. Nothing has worked yet but it almost looks like there are provisions for alternate circuitry in the sensor. Just a guess but I'm thinking there might be a mod that can easily be done for the 83 to remove the factory fuel cut. So anyone who has an 83 they think does not have factory fuel cut... I know I've talked to a couple people before.. but speak up and if you can post the part number on your map sensor that would be great for starters. Mine shows X5T20471 on the case but X5T20177 on the circuit board. Thanks!
  15. I went and took a look at this car. It's pretty spotless except one little ding in the crease on the driver door. I don't know what I would do with this car or I would probably have to get it. Cleanest and lowest mile starquest I've ever seen for whatever that's worth. Narrow body Red leather interior Automatic 1985 Looks like nothing has ever been apart on this car.
