- 7 replies
- 1403 views
- 4224 views
- 1 reply
- 1733 views
- 9 replies
- 1102 views
Lots of wheels.. SHP and others
By AndyW,
Time to clear out the garage even more. I have individual pictures of each as well i just have to resize them. I will try and do that at lunch 2 - 16x9 rears. 130 Each 4 - 16x8 fronts. 125 Each 4 - 16X8 rears 80 each Will work on price the more you buy of coarse
88/89 KM132 Transmission Bearing P/N's and Info
By kev,
This is in conjunction to a rebuild thread that I'm in the process of creating for an 88/89 KM132 manual transmission.
Below are part numbers, actual dimensions, and some other info for the internal transmission bearings.
Note: Inch measurements were taken using calipers. mm was converted from the actual inch measurements.
THIS INFORMATION WAS COLLABORATED FOR AN 88/89 CONQUEST/STARION KM132 MANUAL TRANSMISSION. EARLIER MODELS MAY DIFFER.
Needle R
Transmission Gasket - seal part numbers
By importwarrior,
Information Provided by: psu_Crash Finished up cleaning the tranny and all ready to put it back in the car. I decided that since I had it apart I might as well change the input shaft seal. So I did. The original seal looked fine but I changed it anyways just for peace of mind. So when I pressed in the new seal it didn't seem to press in as far as the old seal. I think it must have been a slightly thicker seal. I checked the ID and OD ... but not the thickness. So here is what it looks like
16g
By noob87tsi,
Ive got a 16g in 12a housings. The 16g compressor wheel is bad. Any idea where i can find a good one new or used? Thanks
