- 8 replies
- 2816 views
- 18 replies
- 2039 views
- 38 replies
- 5014 views
Camshaft Identification * lots of pics
By mbruneaux,
The current cam is junk and I have 2 other cams of unknown origin I got with the car. I've taken pictures and documented measurements to put out there in case anyone can tell me what I have. I appreciate feedback on which one I should use or neither. One camshaft I call "standard" because it has an "A" stamped on the end which tells me, from my research, that it as a hydraulic camshaft but has wear on the " fuel pump" lobe. The other is a "mystery" camshaft because the end is longer and ha
Mitsumark's former car-1988 Starion ESI-R on eBay auction. Lots new!
By stesir,
This is Mitsumark's former car up for sale on eBay right now..it is a 1988 Mitsubishi Starion ESI-R with many new parts and improvements. $500 opening bid...low-reserve SOLD
boost problem no boost or little 4PSI thats it ~~RESOLVED!!~~
By importwarrior,
well for starters modified 86 FIP TBi pro with ignition. problem is when driving normal there is no real boost. even floored it only makes 4 Psi maybe 5 under heavy load. things that have been done... new exhaust manifold gasket, studs, nuts, washers. manifold has been surfaced. new turbo TD06 20G, waste gate, turbine housing all new. checked all intercooler couplers and clamps tight. new manifold to turbo gasket. new turbine to down pipe gasket. vacuum when idling and under cruise is norm
