    Can a collapsed lifter cause engine vibration?
    quickStarion
    By quickStarion,
    I have a vibration from 1200rpm-2400 or so, then it gets less pronounced. It is very noticeable in that rpm range and I can feel it in the chassis and through the shifter. Its there when the clutch is in and out, both idling and moving, so I know know its not the rear end, driveshaft, or tranny. Its somewhere in the engine or flywheel.
    Left Dash Light switch assembly **** 19 year old needs!!
    austinyoung420
    By austinyoung420,
    Im looking for the right side of the dash with the tree switches for my 1988 conquest.
    Work in a shop? Which scan tool?
    ESTurbo4
    By ESTurbo4,
    I'm looking for a new scanner for the shop. The garage I came from used the OTC Genisys (both the old gray one and the newer blue non-touch one). Here, my partner and I are currently using Matco pocket scanners but they lack all the features of thier larger counterparts. Budget is low as we are a new garage and start-up costs have ate into the budget. So the $9,000 new Matco elite or Snap-On $8,000 scanner will be on hold for now. So, I was debating on the cheaper Autel Maxidas 708 or the tri
    Wow! 600hp TT Diesel Hybrid Onyx Concept
    NikoFab
    By NikoFab,
    Pretty cool looking...even though it's a Peugeot   More here: Onyx Concept   http://db.carbuzz.com/images2/270000/6000/800/276855.jpg
