- 4 replies
- 1132 views
- 1030 views
- 11 replies
- 2051 views
- 937 views
Engine Runs very "Weird" Audio attached
By sqall12001,
Ok, very brief history, owned since like '03? Large turbo, ect ect. Sat for several years,3-8 years ago, some trips in between (maybe 50 miles) last 2 years, maybe 3 small trips. Had Turbo heat shields off Got going a week or so ago to play with for the last month of season, Got Gas, on interstate to work, on it a couple times. Then started to Missfire, but sounding unlike what i'm used to in her. So far, checked and cleaned plugs (Trying cheap new one's tomorrow just to see, Comp
ESIRFlattie
By TexasQuest,
Great guy to do buisness with. Bought an intercooler from him and it was packaged up great.
Charging issues
By ColdScrip,
Car was fine 2 years after a restore. I would notice the volt meter would bounce a lot but not too bad. (Clock light would flicker). Come recently my car stopped dead due to a dead battery. I replaced the alternator with a remanned one from autozone even though it tested okay. The bearings sounded kind of rough though. The battery tested okay as well. I also cleaned the negative battery cable grounds to the body and engine. I took apart the fusible links connector to sand each prong. I sanded as
1987 tsi
By bubsinsc,
1987 Chrysler conquest tsi / Mitsubishi Starion 85000 miles Clean title Southern car all 28 years No ac No power steering No cruise No abs New motor parts purchased from dad aka randy gains in the star quest community. New Pistons ,rings , bearings all new seals , arp head studs , lightened rods with arp bolts , micro polished crank , polished value cover , 83 crank pully , custom alternator bracket , spec stage two clutch , modified intake polished internally, modded throttle body , n
