- 16 replies
- 2068 views
- 1031 views
- 6 replies
- 981 views
- 846 views
Coolant temp problems
By Ryan S,
Hello, I’m new to Starquest’s so maybe someone can point me in the right direction of my problems.
My coolant temp gauge seems to work but very little. It usually goes just above the line above “cold.” Then when I start driving it goes to just about cold. If I sit still and rev it (instead of idle) for a little while it’ll start to get to the middle where I’m guessing it’s supposed to sit. I’ve replaced temp sensor for gauge and kinda looked over the wiring. Everything seems good. Is th
Coolant bleeding procedure
By Rev383,
What is the proper coolant bleeding procedure and does it have coolant bleed screw? I’ve looked everywhere I can’t find anything on it.
Requesting help for finding a Starion
By Jim787878,
Hello all,
I am relatively new to Starions/Conquests and I am wondering if any of the members have a Starquest they are selling? Btw, I am on an extreme budget (lower than you'd think) so I'm looking for cheapos. Would prefer with engine and trans, would be best if it was just sitting for a while and nothing was done to it or nobody wrecked it. I would also like to know, to your knowlege, on average, how much does one sell for?
Best
Car bucking when it gets warm
By Rev383,
Okay so I've been putting miles on my Conquest it just started bucking when the car gets warm the secondary fan does not come on but the car doesn't go past half way and i'm not sure if the temp gauge is right. The radiator is upgraded with a thick aluminum radiator but you can't put your hand on it. If i can get pointed in the right direction that could help me , I've got a fuel filter on order i may swap the fuel pump my thoughts is maybe the pump is getting hot and fuel pressure is dipping. C
