- 1319 views
- 1002 views
- 1 reply
- 826 views
- 8 replies
- 3155 views
Can only print 1/2 of page
By Bob,
When I print a page from the forums, the left column is blank and only the left 1/2 of the reply prints. Is it possible to move the info to the left or condense the whole page to fit in the screen? Bob
inline water pump
By heefner,
While I was talking about EIP in another post it made me think of this. I got an additional inline water pump thats on a timer from them. Its at the back of my head on that hose next to the firewall. Its electric of course and it runs after you shut the motor off. The whole thing is smaller than a Red Bull can and the best part is after you shut down, it pulls water through your head to continue cooling . ie. prevent head from warping and cracking. If anyone is interested I can look up the
find members by location
By wastegate,
It would be really cool to know who is local around you. It would be a great help
in planning meets to know who to contact in the area. Thanks!
-wastegate-
Headlights won't go down
By SQF,
  This is a VERY common problem.  The headlights will go off but the popups refuse to drop.  If you run into this problem run out to the car depress the OFF switch and "wiggle" the ON switch.  Normally this will get the popups to drop.  The cause is that the switch contacts get corroded and lose contact. Â
  If the popups drop when you "wiggle" the On switch then the following proceedure will more than likely cure the problem.
Remove the left bank of switches (remove screws and
